On action execution error!
tboy72
Domoticz version: 4.10717
Post by tboy72 »
Greetings!
I ran into an interesting problem within Domoticz.
By default, there is a kitchen counter light controlled by an RF relay controlled by an RF link.
Normal pre-counter lighting goes from a Sonoff T1 Eu to Tasmota (6.6.0).
The problem is the following is the ON action when Sonoff is turned on: http: //192.168.xx.xx: 8080 / json.htm? Type = command & param = switchlight & idx = 116 & switchcmd = On
Whatever you do, if I set the switch in Domoticz. (Turns on kitchen counter light via RF link)
However, if I use the physical switch to turn on the Sonoff T1, even if it changes its status in Domoticz, it will not execute the ON action.
What makes this possible?
