There is no group or scene with that name or id: test. If you just created the scene or group you may have to restart Domoticz to make it become visible to dzVents.
but they exist
I have restart my system within domoticz and putty but still got this error.
If i look in the dzvenst hardware tab there are no scenes only my devices
i would try to use the idx instead of the name but i notice that idx 1 en 2 exist in domoticz and controller?
Is this normal?
2019-09-09 08:24:34.520 Status: User: Admin initiated a switch command (7/Alles_Uit_Living/On)
2019-09-09 08:24:34.613 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 08:24:34.671 Status: dzVents: Debug: Processing device-adapter for Alles_Uit_Living: Switch device adapter
2019-09-09 08:24:34.671 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 08:24:34.671 Status: dzVents: Debug: Event triggers:
2019-09-09 08:24:34.671 Status: dzVents: Debug: - Device: Alles_Uit_Living
2019-09-09 08:24:34.696 Status: dzVents: Info: Handling events for: "Alles_Uit_Living", value: "On"
2019-09-09 08:24:34.697 Status: dzVents: Info: ------ Start internal script: Gaan_Slapen: Device: "Alles_Uit_Living (Controller)", Index: 7
2019-09-09 08:24:34.697 Status: dzVents: Error (2.4.19): There is no group or scene with that name or id: test. If you just created the scene or group you may have to restart Domoticz to make it become visible to dzVents.
2019-09-09 08:24:34.697 Status: dzVents: Error (2.4.19): An error occured when calling event handler Gaan_Slapen
2019-09-09 08:24:34.697 Status: dzVents: Error (2.4.19): ...moticz/scripts/dzVents/generated_scripts/Gaan_Slapen.lua:8: attempt to index a nil value
2019-09-09 08:24:34.697 Status: dzVents: Info: ------ Finished Gaan_Slapen
devices = {"Alles_Uit_Living"}}, -- Change to the name of the switch that you want to use for controlling the group
execute = function(dz,item)
local myScene = "test" -- Change to the name of the group that you want to control
if item.state == "On" then
dz.groups(myScene).switchOff()
item.switchOff().afterSec(3).silent() -- Masterswitch will return to On state after 3 seconds without triggering any script
dz.groups(myScene).switchOn()
Can you try after changing dz.groups to dz.scenes in your script ?
Is this normal?
Yes. Groups and devices have both their own range of ID's starting with 1 (same for uservariables, cameras, scripts, etc )
2019-09-09 08:56:57.698 Status: User: Admin initiated a switch command (7/Alles_Uit_Living/On)
2019-09-09 08:56:57.795 Status: dzVents: Debug: Dumping domoticz data to /home/gianni/domoticz/scripts/dzVents/domoticzData.lua
2019-09-09 08:56:57.840 Status: dzVents: Debug: Processing device-adapter for Alles_Uit_Living: Switch device adapter
2019-09-09 08:56:57.841 Status: dzVents: Debug: dzVents version: 2.4.19
2019-09-09 08:56:57.841 Status: dzVents: Debug: Event triggers:
2019-09-09 08:56:57.841 Status: dzVents: Debug: - Device: Alles_Uit_Living
2019-09-09 08:56:57.865 Status: dzVents: Info: Handling events for: "Alles_Uit_Living", value: "On"
2019-09-09 08:56:57.865 Status: dzVents: Info: ------ Start internal script: Gaan_Slapen: Device: "Alles_Uit_Living (Controller)", Index: 7
2019-09-09 08:56:57.865 Status: dzVents: Error (2.4.19): There is no group or scene with that name or id: test. If you just created the scene or group you may have to restart Domoticz to make it become visible to dzVents.
2019-09-09 08:56:57.865 Status: dzVents: Error (2.4.19): An error occured when calling event handler Gaan_Slapen
2019-09-09 08:56:57.865 Status: dzVents: Error (2.4.19): ...moticz/scripts/dzVents/generated_scripts/Gaan_Slapen.lua:8: attempt to index a nil value
2019-09-09 08:56:57.865 Status: dzVents: Info: ------ Finished Gaan_Slapen
these ar all the devices in the dzvents
how can i use then the idx instead of the name in a script if the idx can exist more time's?
local myScene = 2 -- Change to the name of the group that you want to control
dz.log('Name of dz.scenes(myScene): "' .. dz.scenes(myScene) .. '"',dz.LOG_FORCE )
-- dz.scenes(myScene).switchOff() -- You cannot switch a scene to Off, only groups and devices
dz.scenes(myScene).switchOn()
Gianni wrote: Monday 09 September 2019 10:45
2019-09-09 10:45:12.495 Status: dzVents: Error (2.4.19): ...moticz/scripts/dzVents/generated_scripts/Gaan_Slapen.lua:8: attempt to concatenate a table value
My bad. forgot the .name attribute. The error does already reveal that there is an object. Bug fixed in code below.
dz.log('Name of dz.scenes(myScene): "' .. dz.scenes(myScene).name .. '"',dz.LOG_FORCE )
dz.scenes(myScene).switchOn()-- You cannot switch a scene to Off, only groups and devices
Gianni wrote: Monday 09 September 2019 12:19
i think it's works now
And to answer your earlier question. Irl I am a retired IT guy who did a minor on programming in a previous life (around 1990). Only used that back then professional for a couple of months as a side job. So now only hobby. I am picking it up using Google and looking at domoticz sources and dzVents runtime modules.
