Controling a blinder
Varazir
Post by Varazir »
I'm trying to control a blinder
2019-09-02 17_57_14-Domoticz.png (23.4 KiB) Viewed 779 times
2019-09-02 14:00:02	Sun	West	2/20
2019-09-02 17:52:55	Molnighet	18.00	0/18.00
2019-09-02 06:13:01	DayNight	On	1/0
Nothing happens
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
knielen
Re: Controling a blinder
Post by knielen »
Looks like you used a switch called 'Sun', a switch can not have a value. Wat kind of device is 'Sun'?
Varazir
Post by Varazir »
knielen wrote: Wednesday 11 September 2019 15:32 Looks like you used a switch called 'Sun', a switch can not have a value. Wat kind of device is 'Sun'?
As the logs was showing a numeric value I tried that, this is the current one.
The devise is a dummy selector switch.
2019-10-13 11_58_56-Domoticz.png (24.42 KiB) Viewed 723 times
2019-10-13 12_00_59-Domoticz.png (12.19 KiB) Viewed 723 times
knielen
Post by knielen »
Not sure if this works.
But in this case you want to know if the sun in on the same side as your screen. Maybe you can try to make this time based? In your case after midday?
Varazir
Post by Varazir »
knielen wrote: Monday 21 October 2019 14:48 Not sure if this works.
I have a timers on the Sun dummy switch as you can see. It changes the status based on the time
