For i moved to a New house, all was working fine, but the sd-card was damaged. I have now installed the latest version of raspbian and Domoticz yesterday. I add the RazBerry controller with some changes to raspbian, as described in https://www.vesternet.com/pages/apnt-85 ... I7cfnXhDqP. The controller is recognized but i can’t add the Fibaro switches. I reset them, but ... the raspberry pi is the b+ Version and it had now a fixed ip-address, and connected with the network by cable.
What i see in the control panel is the following, right after clicking add device and go:
2019-09-01 11:13:46.595 Error, contrlr, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-09-01 11:13:46.596 Always,
2019-09-01 11:13:46.596 Always, Dumping queued log messages
2019-09-01 11:13:46.597 Always,
2019-09-01 11:13:46.598 Always, End of queued log message dump
It look likes it is not waiting for a response. When i try to add a node form the Graphical interface, where i get the message to click on the device it is also not recognized ... the abort button doen’t also work.
Has some one a clue?
Troubles to connect Fibaro wall plug fgwpe-102 with RazBerry v1
