Zigate aqara wall switch Topic is solved
tjabas
Post by tjabas »
I have managed to pair a double aqara wall switch to domoticz via zigate, but the aqara only shows as one device in the device list, how is it possible to make a blocky with only one visable switch in the device list?
I noticed that the switch in domoticz changes with the push of right or left, but it is still only one switch in the device list. Hope you understand what i mean.
pipiche
Re: Zigate an aqara wall switch
Post by pipiche »
I believe you get a Widget which is Selector Widget, so you have a Status for each Switch action. It is indeed a bit different than having 2 switches, but you can do the same with LUA/dzVent or Blocky based on the value of the switch
tjabas
Re: Zigate aqara wall switch
Post by tjabas »
ok, i have tried several settings in blocky, but i cant really figure out how to set the selector switch in blocky to aktivate another switch, i know how to get a "normal" wall switch to activate another switch, but with that selector switch om totally lost.
if i go into "edit" in the selector switch i have "level" and "levelname" under level i have :
0 Off
10 Left Click
20 Left Double Clink
30 Left Long Click
40 Right Click
50 Right Double Click
60 Right Long Click
70 Both Click
80 Both Double Click
90 Both Long Click
but how can i in blocky get the left klick to activate lets say, a lamp?
pipiche
Post by pipiche »
I think you are not in the right forum to get support as this is not a Zigate issue.
You should see in forum where they address scripting ( lus, d’avent, blocky) instead
pipiche
Post by pipiche »
This would be the right place for your question:
https://www.domoticz.com/forum/viewforum.php?f=62
tjabas
Post by tjabas »
Sorry, youre right, ill ask there.
