[Experimental] New graph module. Testers needed.
Re: [Experimental] New graph module. Testers needed.
Latest version does not work on my Chinese Android tablet running WallPanel. Also tested FullyKiosk, no luck. It gets stuck at "loading 10%" or "Could not load graph!"
on PC with Mozilla evrything is ok.
Additional: the three time range buttons at the top consume a lot of space and are rarely used. Is it possible to hide them, or make them smaller?
Lokonli
niceGianni wrote: Thursday 29 August 2019 22:19 update to v 3.0.6
get the newest graph.js
add some colors to my js and everything works fine
Lokonli
In the latest graphjs version they already shift to the upper right (if it fits).renerene wrote: Thursday 29 August 2019 22:22 Latest version does not work on my Chinese Android tablet running WallPanel. Also tested FullyKiosk, no luck. It gets stuck at "loading 10%" or "Could not load graph!"
You can also hide them completely via custom.css. I'll update the documentation.
Lokonli
Did it work before? Until when?renerene wrote: Thursday 29 August 2019 22:22 Latest version does not work on my Chinese Android tablet running WallPanel. Also tested FullyKiosk, no luck. It gets stuck at "loading 10%" or "Could not load graph!"
I've started to use some more modern js functionalities (ES6, css flex)
Probably you need to update your browser. FullyKiosk uses Webview. WallPanel probably as well. Do you already have the latest webview module? You can download it from the Google play store. If you update Chrome you get the latest webview as well.
Gianni
@lokonli is it possible to set the graph into 24 h and not am/pm
Lokonli
It can be done now already by manually overriding the graph options:Gianni wrote: Friday 30 August 2019 8:35 @lokonli is it possible to set the graph into 24 h and not am/pm
blocks['graph_6'] = {
options : {
scales: {
xAxes: [{
time: {
displayFormats: {
'minute': 'HH:mm',
'hour': 'H',
Maybe I'll make it a bit easier to configure in the future.
Gianni
dashticz keep loading
checked all my open en close tags and it's seen correct.
//graph
blocks['graph_126'] = {
title: 'Zonnepanelen',
width: 12,
type: 'bar',
datasetColors: ['yellow']
options : {
scales: {
xAxes: [{
time: {
displayFormats: {
'minute': 'HH:mm',
'hour': 'H',
Gianni
i have a little bit experience wit Java oop programming so i did try to fix it and go on a search
Found out on Stack this.
I found that this wasn't possible for Chart.js so I moved to Highcharts.js instead, which supports this functionality.
Here below is my code for the solution:
Lokonli
You have to add a comma behind the datasetColors line:Gianni wrote: Friday 30 August 2019 12:35 dashticz keep loading
checked all my open en close tags and it's seen correct.Code: Select all
// //graph // blocks['graph_126'] = { title: 'Zonnepanelen', width: 12, type: 'bar', datasetColors: ['yellow'] options : { scales: { xAxes: [{ time: { displayFormats: { 'minute': 'HH:mm', 'hour': 'H', } } }] } } };
datasetColors: ['yellow'],
Lokonli
It's working with chart.js on my system with the code I provided.Gianni wrote: Friday 30 August 2019 12:43 i have a little bit experience wit Java oop programming so i did try to fix it and go on a search
Solved. The problem was inDid it work before? Until when?
range: '24 hours',
filter: '8 hours',-
Lokonli
Good, thanks. Probably I've to add some checks on valid values.renerene wrote: Friday 30 August 2019 21:57Solved. The problem was inDid it work before? Until when?
Probably you need to update your browser. FullyKiosk uses Webview. WallPanel probably as well. Do you already have the latest webview module? You can download it from the Google play store. If you update Chrome you get the latest webview as well.After changing the first line to range: 'day' the could not load graph error was gone.Code: Select all
range: '24 hours', filter: '8 hours',
/* P1 power gas*/
blocks['graph_428'] = {
type: 'line',
datasetColors: ['white'],
width:6
};2019-08-30 22:17:39.314 (stroommeter-USB1) P1 Smart Meter (Stroom)
2019-08-30 22:17:39.315 (stroommeter-USB1) Usage (Usage L1)
2019-08-30 22:17:39.315 (stroommeter-USB1) Usage (Delivery L1)
2019-08-30 22:17:39.326 (stroommeter-USB1) P1 Smart Meter (Gas)
Lokonli
If you select 'vandaag' you should receive the same amount of data as in the Domoticz graph.
What is your Domoticz setting for 'Log geschiedenis' -> 'Korte log sensoren'?
Probably it's 4 days.
A gasmeter can't measure the flow. It only shows the used amount. Domoticz stores the used amount per hour.
Gianni
Damn i hate thisYou have to add a comma behind the datasetColors line:
does remind me at my college and need to debug 10 time's to find out i forget of ;
thx works now
Hmm, i'm a bit puzzled here. Since a few days, dashticz crashes after ca. 1/2 hour. Don't know the exact time. It happens both on Wallpanel and Fullykiosk. After a while there is the startup screen on my tablet. Thought the cause was in the graphs, but after not displaying them (modify columns declaration), the problem remains. Is there something else modified that could cause a crash?
I will do a 'git checkout beta' and keep you updated.
Lokonli
You had the crash with the chartjs branch? or with the beta branch?renerene wrote: Wednesday 04 September 2019 7:39 Hmm, i'm a bit puzzled here. Since a few days, dashticz crashes after ca. 1/2 hour. Don't know the exact time. It happens both on Wallpanel and Fullykiosk. After a while there is the startup screen on my tablet. Thought the cause was in the graphs, but after not displaying them (modify columns declaration), the problem remains. Is there something else modified that could cause a crash?
You had the crash with the chartjs branch? or with the beta branch?-
Lokonli
With the new graph module, a first version is available via the chartjs branch, you can create a custom graph.madradrakie wrote: Wednesday 11 September 2019 21:36 My water usage graph in dashticz does not show liters but m3. In domoticz the values are reported in liters (x1000). Is there a possibility to adjust the graph so it shows liters instead of m3?
It's still a bit experimental, but I expect the following will work:
First find the value name. You can do that as follows (assuming the device id is 6) :
graph: 'bar',
legend: true
}Then you can create a custom graph:
graph: 'bar',
legend: true,
custom : {
"last day": {
range: 'day',
filter: '24 hours',
data: {
liter: 'd.v*1000' }
madradrakie
- Target OS: -
it works! Thank you so much!
