Presence detection for Fritzbox script v2.0: using TR064 protocol communication to your router
Re: Presence detection for Fritzbox script v2.0: using TR064 protocol communication to your router
Damn .... this created a Kazillion log entries as every time it sets the switch off and on .......
Somehow i liked the iDetect way but thats history as the Asus went out
So back to the roots and looking for a other way.
- Domoticz version: newest
Wich Logging do you mean it can be switched off
It's the presence switch and it's flooding the logs by every time on/off when a phone is there.
(The phone is not flipping like this )
- Domoticz version: 12467
Hi Prutsium,
You made a mistake in your blockly.That is why your log is running wild.
If presence is {on} AND ( phone1 = {off) AND phone2 = {off} AND phone3 = {off} )
Do presence is {Off}
Like in my earlier post:
The Or's between the phones should be AND's. Otherwise Else If is almost always true
If 'Anyone home' = Off AND Phone1 = On OR Phone2 = On OR Phone3 = On
Set 'Anyone home = On
Else If 'Anyone home' = On AND Phone1 = Off AND Phone2 = Off AND Phone3 = Off
Set 'Anyone home = Off
Thanks thought already so as it's easy to mess up in Blockly.AllesVanZelf wrote: ↑Tuesday 27 August 2019 17:09 Hi Prutsium,
Like in my earlier post:The Or's between the phones should be AND's. Otherwise Else If is almost always trueCode: Select all
If 'Anyone home' = Off AND Phone1 = On OR Phone2 = On OR Phone3 = On Set 'Anyone home = On Else If 'Anyone home' = On AND Phone1 = Off AND Phone2 = Off AND Phone3 = Off Set 'Anyone home = Off
Will check this when back home but based on the manual trigger it looks like it's not spamming the log
New forum user here. Apologies beforehand if any question I ask was already answered. I did search the forum and could not find them, so here it goes.
First, love the concept of this script. The wizard-like setup especially.
I encounter two issues. First, my domoticz (rpi) is user/password protected at login. I found I had to remove that protection to make this script work. The passcode for lightswitch protection entered in the config was not sufficient. Is there a way to pass username/password along with the domoticz URL? Is their a required syntax? Or is there another line required in the config.txt?
Second. I find that my devices are seen as on, even when no longer active on WLAN. Is this because of my specific Fritz boxes (7360 router and 4040 repeater)? This script is able to query the WLAN table, finds the devices, but sees them as active, while fritz.box console shows them as not connected. Is there something I am doing wrong?
Here is the debug output from manually running the script after I manually set both dummy devices to OFF in domoticz
Presence detection for Domoticz using Fritzbox version 2.3
checking:iPhonePaul
Mon 23 Dec 10:02:43 UTC 2019status router is not simular to status domoticz. We change status domoticz for iPhonePaul to On
debug information:
status domoticz:
Off
status fritzbox:
FritzHosts:
version: 0.6.2
model: FRITZ!Box Fon WLAN 7360
ip: 192.168.178.1
Details for host: ***MAC1***
NewActive : 1
NewIPAddress : 192.168.178.96
NewInterfaceType : 802.11
NewHostName : iPhonevPBijlsma
NewAddressSource : DHCP
NewLeaseTimeRemaining : 0
status repeater:
FritzHosts:
version: 0.6.2
model: FRITZ!Box 4040
ip: 192.168.178.49
NewActive : 0
NewInterfaceType : None
NewHostName : d1109fcc-c9e4-48e8-87fa-3601136c4d3b1
NewAddressSource : Static
checking:iPhoneMachteld
Mon 23 Dec 10:02:56 UTC 2019status router is not simular to status domoticz. We change status domoticz for iPhoneMachteld to On
debug information:
status domoticz:
Off
status fritzbox:
FritzHosts:
version: 0.6.2
ip: 192.168.178.1
Details for host: ***MAC2***
NewActive : 0
NewIPAddress : 192.168.178.50
NewHostName : iMCV5s
status repeater:
FritzHosts:
version: 0.6.2
ip: 192.168.178.49
NewActive : 1
NewIPAddress : None
NewInterfaceType : Ethernet
dependencies installed:
installed python version:
Python 2.7.16
installed JQ version:
jq-1.5-1-a5b5cbe
config file variables:
ip_fritzbox=192.168.178.1
pass_fritzbox=******
ip_repeater=192.168.178.49
ip_domoticz=192.168.178.27:8080
domoticzpasscode=
device_names=(iPhonePaul iPhoneMachteld)
device_macs=(***MAC1*** ***MAC2***)
device_idx=(459 460)
checking:iPhonePaul
debug information:
status domoticz:
Off
status fritzbox:
FritzHosts:
version: 0.6.2
ip: 192.168.178.1
NewActive : 1
status repeater:
FritzHosts:
version: 0.6.2
ip: 192.168.178.49
NewActive : 0
debug information:
status domoticz:
Off
status fritzbox:
FritzHosts:
version: 0.6.2
ip: 192.168.178.1
NewActive : 0
status repeater:
FritzHosts:
version: 0.6.2
ip: 192.168.178.49
NewActive : 1
NewIPAddress : None
Python 2.7.16
jq-1.5-1-a5b5cbe
domoticzpasscode=
hi Paul
Some questions first:
1. As i can see the script is retrieving information from domoticz, that works. But does the script setting your dummy switches correctly? Are the idx ok? Maybe something went wrong bij making the dummie switches by the scripts since your Domoticz was password protected?.
2. The script works also with the WLAN table in your example the New active:1 means that its online and the Newactive:0 means it’s offline. Sometimes there is a lag of a minute. Or the repeater ip is not set.
What you can do it remove the dummy switches inside Domoticz, remove the config.txt , remove the password protection of the lightswitches. And do a reinstall.
After that run in debug mode and see if there are any errors. If so you can send me an pm with the complete logfile and I will look to it.
There is also a complete faq on: https://github.com/hydex80/presence_det ... /README.md
Yes, it created the dummy switches after I disabled username/password protection of domoticz. However, I need that to be enabled, because I also access Domoticz from outside my networkfunky wrote: ↑Monday 23 December 2019 13:25 1. As i can see the script is retrieving information from domoticz, that works. But does the script setting your dummy switches correctly? Are the idx ok? Maybe something went wrong bij making the dummie switches by the scripts since your Domoticz was password protected?.
The repeater IP is set. Problem was is set my devices to active while the fritz console shows them as not connected (also after 1 hour). The script is able to find the correct switches, because when I manually change the value to OFF (in domoticz webgui) the script will change them back to active/ON (as shown in de debug I shared)
I do not have password protection on the switches, I have password protection on Domoticz login.
I would like to know if username/password can be passed along (not just the password for switch protection). If not, I am afraid I won't be able to use the script.
I would send you a PM, but as a new member I am not allowed
Did you managed it to work.
Set in my own domesticz user name and password protection and script seems to work.
Please try:
For example:
if you get:
"status" : "OK",
"title" : "SwitchLight"
it should be working. otherwise plz post here error code.
Please try:
http://domoticz ip/json.html?type=commandtype=command¶m=switchlight&idx=<IDX OFF DEVICE YOU WANT TO SET&switchcmd=<ON of OFF>&passcode=Lightswitch pasword.
http://192.168.178.33:8080/json.htm?type=command¶m=switchlight&idx=494&switchcmd=Off&passcode=test1234
"status" : "OK",
- Domoticz version: 2020beta
i'm running Domoticz on a Synology.
How can I install this on a Synology.
When I start the installer it says Dependencies should be installed, but then I got an error about apt-get.
What to do?
What to do?
You can try pip to install the dependencies manually:
pip install python
pip install lxml
pip install jq
pip install requests
Or you can try easy install
easy install python
Easy install lxml
Easy install jq
Easy install requests
both commands 'pip' and 'easy' are not recognized.
And easy_install
Forgot the underscore
And if that’s not working install pip first
http://domoticx.com/synology-nas-python ... stalleren/
Easy_install did the job.
But still got an error on jq:
checking for cl.exe... no
configure: error: in `/tmp/easy_install-AUWES3/jq-0.1.6/onig-5.9.6':
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details
File "/bin/easy_install", line 9, in <module>
load_entry_point('setuptools==25.1.6', 'console_scripts', 'easy_install')()
File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 2271, in main
**kw
File "/usr/lib/python2.7/distutils/core.py", line 151, in setup
dist.run_commands()
File "/usr/lib/python2.7/distutils/dist.py", line 953, in run_commands
self.run_command(cmd)
File "/usr/lib/python2.7/distutils/dist.py", line 972, in run_command
cmd_obj.run()
File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 409, in run
self.easy_install(spec, not self.no_deps)
File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 664, in easy_install
return self.install_item(spec, dist.location, tmpdir, deps)
File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 694, in install_item
dists = self.install_eggs(spec, download, tmpdir)
File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 875, in install_eggs
return self.build_and_install(setup_script, setup_base)
File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1114, in build_and_install
self.run_setup(setup_script, setup_base, args)
File "/usr/local/lib/python2.7/site-packages/setuptools/command/easy_install.py", line 1100, in run_setup
run_setup(setup_script, args)
File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 249, in run_setup
raise
File "/usr/lib/python2.7/contextlib.py", line 35, in __exit__
self.gen.throw(type, value, traceback)
File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 197, in setup_context
yield
File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 168, in save_modules
saved_exc.resume()
File "/usr/local/lib/python2.7/site-packages/setuptools/sandbox.py", line 142, in resume
type, exc = map(pickle.loads, self._saved)
File "/usr/lib/python2.7/pickle.py", line 1388, in loads
return Unpickler(file).load()
File "/usr/lib/python2.7/pickle.py", line 864, in load
dispatch[key](self)
File "/usr/lib/python2.7/pickle.py", line 1139, in load_reduce
value = func(*args)
TypeError: __init__() takes at least 3 arguments (1 given)[/quote][/quote]
Maybe try to install pip first and try to install it then. I self don’t have a synalogy. I see they are using custom Linux distribution. So im not sure if it works. But you can try. If it works plz let us know. Good luck
Hey,
i have the same issue on my System.
I managed to get the System working on System1 without User&Password.
But how can i fix the issue on System2 where i have a User&Password?
Best wishes,
percy
P.S.:
A perfect Tool how far i could do some test!
Perfect documentation and a easy installation guide.
Best wishes,
percy
P.S.:
pauwauw wrote: ↑Tuesday 24 December 2019 12:17
Users browsing this forum: MikeVanD and 0 guests
