Zigate problem
tjabas
Zigate problem
Hi!
I just received my zigate usb version, Im running the latest stable version of domoticz.
I have installed the zigate plugin and plugged the zigate device in my raspberry, but i cant seem to connect to the device itself, i get this error message:
2019-08-26 15:42:22.321 Error: (Zigate) - unplug/plug the zigate
2019-08-26 15:42:27.379 Error: (Zigate) Plugin is not started ...
2019-08-26 15:42:27.379 Error: (Zigate) - Communication issue with the Zigate
2019-08-26 15:42:27.379 Error: (Zigate) - restart once the plugin, and if this remain the same
I have tried all of the usb alternatives in the plugin but it wont connect, or do i need to flash the zigate with any firmware before i use it or should it work sout of the box?
I have also tried all of the usb ports in the back of my raspberry with no luck.
Thanks in advance.
Thanks in advance.
Re: Zigate problem
]can you stop domoticz and do the following command:
Can you try the Zigate on a PC with Windows ?
https://zigate.fr/documentation/tester- ... -usb-v1-1/
dmesg | grep ttyhttps://zigate.fr/documentation/tester- ... -usb-v1-1/
tjabas
Re: Zigate problem
Thanks, Im at work right now, but i will test this later tonight. Is it also possible to uppdates the zigate through this Windows software?
tjabas
Re: Zigate problem
What will happend with that command?pipiche wrote: Monday 26 August 2019 16:00 ]can you stop domoticz and do the following command:
Can you try the Zigate on a PC with Windows ?Code: Select all
dmesg | grep tty
dmesg | grep tty-
tjabas
Re: Zigate problem
hi!
i managed to get it to work, but it seems like the version of domoticz that i use: 4.10717 dont work, it seems to freeze some minutes after i have managed to pair an Ikea lightbulb, after that i cant start domoticz without it freezing in the starting fase.
im getting an error message in the log where it says that the webserver doesnt work with my domoticz version,
i have installed the latest beta version of domoticz and the zigate seems to work as it should, but the new problem is that i cant get the z-wave network to work ok, suddenly my z-wave battery modes have disappeard, so i guess that the beta version wont work for me, is there a fix so i can use the old stable domoticz version with Zigate?
Re: Zigate problem
If you have several USB devices connected, you must configure your OS to have always the same device name for each USB devices.
This is an OS Linux configuration. Have a look to udev feature
tjabas
Re: Zigate problem
is there anyone who use zigate with the latest stable version of Domoticz ?
i get som error with that stable version, it says somethimg like a web error in the log.
Re: Zigate problem
Can you share the errors?tjabas wrote:is there anyone who use zigate with the latest stable version of Domoticz ?
tjabas
Re: Zigate problem
i get this error: Error:
(Zigate) ATTENTION: the WebServer part is not supported with this version of Domoticz. Please upgrade to a version greater than 4.10901
and then when i try to ad an zigbee device the whole domoticz freezes and need to be rebooted,
but there must be a way to use zigate with the stable version of domoticz?
tjabas
Re: Zigate problem
well now i have another problem, i was trying to instal an older firmware just to see if i could eliminate the webserver problem, but after update the zigate flashes blue rapidly, and wont connect to domoticz, any sugestions of what could be wrong?
Re: Zigate problem
The webserver message is not an error. The plugin is just telling that the web part is not supported with such version of domoticz.
To get a full supported plugin web part, you need to put a beta version of domoticz.
Re: Zigate problem
Please provide the logs , we cannot really help you without.tjabas wrote:well now i have another problem, i was trying to instal an older firmware just to see if i could eliminate the webserver problem, but after update the zigate flashes blue rapidly, and wont connect to domoticz, any sugestions of what could be wrong?
Just attach the log file ( we need the all context)
tjabas
Re: Zigate problem
Thanks you for your help, ok so it is not the web error i get in the stable version of domoticz, it seems like when i have openzwave (aeotech gen5 stick) and the zigate plugin activated at the same time , then domotics freezes, if i turn of openzwave plugin everything seems to work fine with the zgate, but as soon as i start openzwave domoticz freezes.
here are some of the logs:
2019-08-29 11:42:15.009 Status: (Zigate) Entering work loop.
2019-08-29 11:42:15.010 Status: (Zigate) Initialized version 4.5, author 'zaraki673 pipiche38'
2019-08-29 11:42:15.019 Status: (Zigate) Zigate plugin stable-4.5.4 started
2019-08-29 11:42:15.020 Status: (Zigate) Python Version - 3.4.2 (default, Sep 26 2018, 07:50:08)
2019-08-29 11:42:15.020 [GCC 4.9.2]
2019-08-29 11:42:15.020 Status: (Zigate) Switching Heartbeat to 5 s interval
2019-08-29 11:42:15.020 Status: (Zigate) DomoticzVersion: 4.10717
2019-08-29 11:42:15.020 Status: (Zigate) DomoticzHash: b38b49e5
2019-08-29 11:42:15.020 Status: (Zigate) DomoticzBuildTime: 2019-05-09 13:04:08
2019-08-29 11:42:15.020 Status: (Zigate) load PluginConf
2019-08-29 11:42:15.022 Status: (Zigate) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-08-29 11:42:15.022 Status: (Zigate) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-08-29 11:42:15.022 Status: (Zigate) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-08-29 11:42:15.022 Status: (Zigate) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-14.json
2019-08-29 11:42:15.022 Status: (Zigate) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-08-29 11:42:15.022 Status: (Zigate) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-08-29 11:42:15.022 Status: (Zigate) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-29 11:42:15.022 Status: (Zigate) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-29 11:42:15.022 Status: (Zigate) Opening DomoticzDB in raw
2019-08-29 11:42:15.026 Status: (Zigate) Plugin Database: DeviceList-14.txt
2019-08-29 11:42:15.057 Status: (Zigate) DeviceConf loaded
2019-08-29 11:42:15.057 Status: (Zigate) load ListOfDevice
2019-08-29 11:42:15.068 Status: (Zigate) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-14.txt : 0
2019-08-29 11:42:15.069 Status: (Zigate) Transport mode: USB
2019-08-29 11:42:15.069 Status: (Zigate) Connection Name: Zigate, Transport: Serial, Address: /dev/serial/by-id/usb-Silicon_Labs_ZiGate_0001-if00-port0
2019-08-29 11:42:15.086 Status: (Zigate) Zigate set Time Server
2019-08-29 11:42:15.093 Status: (Zigate) Configure Permit To Join
2019-08-29 11:42:15.093 Status: (Zigate) Request Accepting new Hardware for 254 seconds
2019-08-29 11:42:15.093 Status: (Zigate) Trigger a Topology Scan
2019-08-29 11:42:15.093 Status: (Zigate) Trigger a Energy Level Scan
2019-08-29 11:42:15.093 Status: (Zigate) Network Energy Level Report: 0000
2019-08-29 11:42:15.093 Status: (Zigate) -----------------------------------------------
2019-08-29 11:42:15.095 Status: (Zigate) router <- nwkid Tx Failure 11 15 19 20 25 26
2019-08-29 11:42:15.173 Status: OpenZWave: Value_Added: Unhandled Label: Distance, Unit: m
2019-08-29 11:42:15.202 Status: (Zigate) Major Version Num: 0003
2019-08-29 11:42:15.202 Status: (Zigate) Installer Version Number: 030f
2019-08-29 11:42:15.509 Status: (Zigate) Accepting new Hardware: On
2019-08-29 11:42:15.612 Status: (Zigate) Zigate addresses ieee: 00158d0001edea3c , short addr: 0000
2019-08-29 11:42:15.612 Status: (Zigate) Network state UP, PANID: 168a extPANID: 0x42345bd5086b4cc9 Channel: 11
2019-08-29 11:42:15.716 Status: (Zigate) Number of devices recently active in Zigate = 0
2019-08-29 11:42:15.966 Status: RFXCOM: retrying in 30 seconds...
2019-08-29 11:42:17.209 Status: Incoming connection from: 192.168.1.57
2019-08-29 11:42:18.497 Status: OpenZWave: Received timeout notification from HomeID: 3946733487, NodeID: 20 (0x14)
2019-08-29 11:42:25.034 Status: (Zigate) Zigate set to Certification : CE
2019-08-29 11:42:25.035 Status: (Zigate) Start Web Server connection
2019-08-29 11:42:25.075 Status: (Zigate) Web backend for Web User Interface started on port: 9440
2019-08-29 11:42:25.075 Status: (Zigate) Plugin with Zigate firmware 030f correctly initialized
Re: Zigate problem
I don't see any issue here.
At start, the plugin is setting the Zigate in pairing mode for 254 seconds ( which means the Blue Led will flash during that time , indicating that pairing is possible).
What I see, is for now you don't have any device paired and known by plugin.
As you have Domoticz 4.10717, the plugin webserver is not reachable (you might use a ssh tunnel way to reach it); or upgrade domoticz to a version above 4.10901
Now, I don't know how Zigate behave when downgrading firmware
As I mentioned earlier in the post, as you have 2 or more USB devices connected to your system, you might be in trouble after a restart where the ZWave key is going to the Zigate port and vice-versa.
You need to make sure that after a reboot each of your USB stick stay on the same device-port ( /dev/tty.... ) that could be the reason of your freeze.
https://www.domoticz.com/wiki/Assign_fi ... o_USB_port
tjabas
Re: Zigate problem
Yes, i will try that dev/tty in the weekend.
Strangely enough so everything works great in the latest domoticz beta, no freezes at all, but there is my other problem with the open z-wave. The devices are all fucked up, but ill dive into that to.
tjabas
Re: Zigate problem
I have now assigned the usb ports but domoticz still freezes, but i was thinking if it might be the zigbee channel?, vit is now set to 11, but how can i change it to 12? Just to try?pipiche wrote: Thursday 29 August 2019 13:14 I don't see any issue here.
Re: Zigate problem
To change the Zigbee channel you need to use the Web Admin interface on port 9440 and go to Settings.
For more info, please check teh Wiki:
https://github.com/pipiche38/Domoticz-Z ... terface.md
https://github.com/pipiche38/Domoticz-Z ... igation.md
tjabas
Re: Zigate problem
