Since some weeks now, the Dashticz V3 beta stationclock and weather forecast is not/partly showing in Fullykiosk on my tablet. Firefox shows them correct.
Are there any (autostart) alternative for fullscreen display of dashticz? Maybe witht tasker?
FullyKiosk alternative? Station clock not working
Lokonli
Re: FullyKiosk alternative? Station clock not working
Which weather forecast do you use? Can you share your block/button definition? I'll check.renerene wrote: Friday 23 August 2019 8:00 Since some weeks now, the Dashticz V3 beta stationclock and weather forecast is not/partly showing in Fullykiosk on my tablet. Firefox shows them correct.
jaaap
If you have a license for fully kiosk, then you also have a license for fully app kiosk (or something like that name. It's the from the same maker).
You can tell this program to launch an app on start up and launch it full screen. You can select Firefox for this, et voila!
Verstuurd vanaf mijn POCOPHONE F1 met Tapatalk
Problem solved by using another app : WallPanel
I am using the darksky weather forecast, which was partly visible in FullyKiosk
Station Clock was invisible in FullyKiosk
frames.weather = {refreshiframe:1800000,height:224,frameurl:"http://forecast.io/embed/#lat=51.003076&lon=5.772562&name=Utrecht&lang=nl&color=#00aaff&font=Helvetica&fontcolor=#ffffff&units=si",width:12}
