As I am new to Domoticz, I probably do something wrong. I searched the forum, but did not find an answer to my problem.
I recently installed Domoticz on a Raspberry Pi 4. Everything worked fine and I added switches (KaKu) and some virtual devices.
Then it was time to add these to a floorplan. I created rooms and added devices to the rooms. But when I go to Settings-More Options-Plans-Floorplan, I see the option Add, but this option is not working.
Then I uninstalled Domoticz and deleted every Domoticz folder and installed it again.
With an empty database, I tried to create at first a floorplan, but still the option to add a floorplan is not working.
In the images directory there is an example.jpg, but this is als not visible in the Floorplan Editor or the Floorplan dashboard.
Can anyone help me with it?
Thanks in advance
[SOLVED] Floorplan not working
Jurgen67
Re: [SOLVED] Floorplan not working
An update: I think it has to do with the option in Settings to enable Floorplans in the menu. By default this option is disabled. I enabled it, without having rooms or floorplans. I was then unable to create floorplans. I disabled the option to show the Floorplan menu and was then able to add a Floorplan under More Options - Plans
Users browsing this forum: Arjan2019 and 1 guest
