try:
import simplejson as json
except ImportError:
import jsonModerator: leecollings
try:
except ImportError:
import jsonAfter this error the plugin haven't tried to update this device ? Try to resynchronise it, with reload the plugin : setting/hardware/deconz/update.salopette wrote: Friday 16 August 2019 21:33 2019-08-16 21:14:04.002 Error: (deconz) Websocket error, unknow device > 41 (sensors) Asking for information
2019-08-17 19:27:56.159 (deconz) ### Device > 41 Name:CLIP-Sensor TOOGLE-ON-OFF Type:CLIPGenericFlag Details:{'lastupdated': '2019-08-17T17:27:56', 'flag': False}
2019-08-17 19:27:56.159 Status: (deconz) Adding missing device :41 Type:CLIPGenericFlag
2019-08-17 19:27:56.129 Error: (deconz) Websocket error, unknow device > 41 (sensors) Asking for information
2019-08-17 19:29:30.775 MQTT: Topic: domoticz/in, Message: {"idx":338,"nvalue":0,"svalue":"23.1;55.5;1","Battery":200,"RSSI":6}
2019-08-17 19:29:33.520 (deconz) ### Device > 42 Name:CLIP-Sensor TOOGLE-ON-OFF Type:CLIPGenericFlag Details:{'lastupdated': '2019-08-17T17:29:33', 'flag': True}
2019-08-17 19:29:33.520 Status: (deconz) Adding missing device :42 Type:CLIPGenericFlag
2019-08-17 19:29:33.492 Error: (deconz) Websocket error, unknow device > 42 (sensors) Asking for information
2019-08-17 19:29:37.567 (deconz) ### Device > 44 Name:CLIP-Sensor TOOGLE-ON-OFF Type:CLIPGenericFlag Details:{'lastupdated': '2019-08-17T17:29:37', 'flag': True}
2019-08-17 19:29:37.567 Status: (deconz) Adding missing device :44 Type:CLIPGenericFlag
2019-08-17 19:29:37.537 Error: (deconz) Websocket error, unknow device > 44 (sensors) Asking for information
2019-08-17 19:29:39.977 Error: (deconz) Websocket error, unknow device > 41 (sensors) Asking for information
2019-08-17 19:29:40.007 (deconz) ### Device > 41 Name:CLIP-Sensor TOOGLE-ON-OFF Type:CLIPGenericFlag Details:{'lastupdated': '2019-08-17T17:29:39', 'flag': False}
2019-08-17 19:29:40.007 Status: (deconz) Adding missing device :41 Type:CLIPGenericFlag
2019-08-17 19:29:48.917 (RFLink-Getway) Temp + Humidity (Aussen)Code: Select all
2019-08-18 09:36:31.925 (deconz) ### Device > 59 Name:Xiaomi Terrasse 59 Type:ZHASwitch Details:{'lastupdated': '2019-08-18T07:34:35', 'buttonevent': 3002}Code: Select all
2019-08-18 09:37:31.493 Status: (deconz) Adding missing device :41 Type:CLIPGenericFlag
2019-08-18 09:37:31.462 Error: (deconz) Websocket error, unknow device > 41 (sensors) Asking for information
2019-08-18 09:37:32.912 (deconz) ### Device > 42 Name:CLIP-Sensor TOOGLE-ON-OFF Type:CLIPGenericFlag Details:{'lastupdated': '2019-08-18T07:37:32', 'flag': False}
2019-08-18 09:37:32.912 Status: (deconz) Adding missing device :42 Type:CLIPGenericFlag
2019-08-18 09:37:32.882 Error: (deconz) Websocket error, unknow device > 42 (sensors) Asking for information
2019-08-18 09:37:34.943 (deconz) ### Device > 44 Name:CLIP-Sensor TOOGLE-ON-OFF Type:CLIPGenericFlag Details:{'lastupdated': '2019-08-18T07:37:34', 'flag': False}
2019-08-18 09:37:34.943 Status: (deconz) Adding missing device :44 Type:CLIPGenericFlag
2019-08-18 09:37:34.913 Error: (deconz) Websocket error, unknow device > 44 (sensors) Asking for informationCode: Select all
2019-08-18 09:54:08.511 (deconz) ### WebSocket Data : {'id': '59', 'e': 'changed', 'uniqueid': '00:15:8d:00:02:6b:a5:17-01-0006', 'r': 'sensors', 'state': {'lastupdated': '2019-08-18T07:54:08', 'buttonevent': 1002}, 't': 'event'}
2019-08-18 09:54:08.512 (deconz) ### Update device (deconz - Xiaomi Terrasse 59) : {'nValue': 10, 'sValue': '10'}
2019-08-18 09:54:08.515 (deconz) onMessage called
2019-08-18 09:54:08.516 (deconz) ### WebSocket Data : {'id': '41', 'e': 'changed', 'uniqueid': '00:15:8d:00:02:6b:a5:17-01-0006-toogle-on-off', 'r': 'sensors', 'state': {'lastupdated': '2019-08-18T07:54:08', 'flag': True}, 't': 'event'}
2019-08-18 09:54:08.516 (deconz) Send Command /api/66E1DF16CD/sensors/41 with None (0 in buffer)
2019-08-18 09:54:08.516 (deconz) Making Request : http://192.168.178.93:80/api/66E1DF16CD/sensors/41 with params None
2019-08-18 09:54:08.551 (deconz) Request Return : {"config":{"on":true,"reachable":true},"etag":"b6fbe0244fdde9f8ac49fbce935a01b5","manufacturername":"Phoscon","modelid":"PHOSCON_FSM_FLAG","name":"CLIP-Sensor TOOGLE-ON-OFF","state":{"flag":true,"lastupdated":"2019-08-18T07:54:08"},"swversion":"1.0","type":"CLIPGenericFlag","uniqueid":"00:15:8d:00:02:6b:a5:17-01-0006-toogle-on-off"}
2019-08-18 09:54:08.552 (deconz) Classic Data : {'etag': 'b6fbe0244fdde9f8ac49fbce935a01b5', 'config': {'on': True, 'reachable': True}, 'manufacturername': 'Phoscon', 'uniqueid': '00:15:8d:00:02:6b:a5:17-01-0006-toogle-on-off', 'type': 'CLIPGenericFlag', 'name': 'CLIP-Sensor TOOGLE-ON-OFF', 'state': {'lastupdated': '2019-08-18T07:54:08', 'flag': True}, 'swversion': '1.0', 'modelid': 'PHOSCON_FSM_FLAG'}
2019-08-18 09:54:08.552 (deconz) ### Device > 41 Name:CLIP-Sensor TOOGLE-ON-OFF Type:CLIPGenericFlag Details:{'lastupdated': '2019-08-18T07:54:08', 'flag': True}
2019-08-18 09:54:08.553 (deconz) ### Update device (deconz - CLIP-Sensor TOOGLE-ON-OFF) : {'nValue': 1, 'sValue': 'On'}
2019-08-18 09:54:08.552 Status: (deconz) Adding missing device :41 Type:CLIPGenericFlag
2019-08-18 09:54:08.516 Error: (deconz) Websocket error, unknow device > 41 (sensors) Asking for informationCode: Select all
http://192.168.178.93:80/api/66E1DF16CD/sensors/42
http://192.168.178.93:80/api/66E1DF16CD/sensors/44Code: Select all
2019-08-18 17:21:24.936 (deCONZ) ### WebSocket Data : {'state': {'lastupdated': '2019-08-18T15:21:24', 'buttonevent': 2002}, 'r': 'sensors', 'id': '12', 't': 'event', 'e': 'changed', 'uniqueid': '00:15:8d:00:02:f0:8c:12-01-0012'}
2019-08-18 17:21:26.345 (deCONZ) ### WebSocket Data : {'state': {'lastupdated': '2019-08-18T15:21:26', 'buttonevent': 1002}, 'r': 'sensors', 'id': '12', 't': 'event', 'e': 'changed', 'uniqueid': '00:15:8d:00:02:f0:8c:12-01-0012'}Code: Select all
python ikea-ota-download.pyCode: Select all
dir /home/pi/otau
