hi all,
Have an issue trying to get the SolarEdge API up and running.
Following the Wiki and two previous comunity-posts haven't helped me yet.
The wiki tells me that I should fill two fields: API key and SiteID. The former I did, the latter... isn't there?
Obviously this is not going to work. The API key is working, I checked a manual API URL. But only with the correct SiteID.
Any solutions, pointers, ideas?
SolarEdge Web API: not SiteID field
- madpatrick
- Domoticz version: 2026.1
Re: SolarEdge Web API: not SiteID field
Should work with only the API key.
Mine is working like this.
zedd
OK - thanks and you're right: it works.
It only took some time... After adding the SolarEdge hardware, it took more than half a day for the devices to appear.
But they're there now!
