Problem with Zwave Devices Roller Shutters
mastadook
Domoticz version: 2022.1
Post by mastadook »
I hava a Problem again with my Domoticz.
Some Time ago I pressed the wrong butten on Zwave Device,
and all my registered Devices where gone.
So bad, I had to register everthing new, new learn every Device.
Ok, this done now, I take the same Names, so my dzvents Scripts should working fine.
One Day long, everything was ok.
Then, I did not know what happend, my Shutters begin to shut down complete,
some Minutes later, they going up complete open.
Some Minutes, sometimes more than 30 Minutes, then they shut down again, and going up again some minutes later.
All 3 at the same Time.
When I look at he logs, I see only something like this:
2019-08-11 09:49:51.544 (RFLink01) Temp + Humidity (Cresta)
2019-08-11 09:49:51.551 (RFXCOM) Temp + Humidity (Terrasse)
2019-08-11 09:49:51.718 (DomoticzSlave01) General/Percentage (Unknown)
2019-08-11 09:49:51.848 (ZWave) Usage (Unknown)
2019-08-11 09:49:51.852 (ZWave) General/kWh (Verbrauch Rolladen Theo)
2019-08-11 09:49:51.890 (ZWave) Usage (Unknown)
2019-08-11 09:49:51.895 (ZWave) General/kWh (Verbrauch Rolladen Schlafzimmer)
2019-08-11 09:49:51.903 (ZWave) Usage (Unknown)
2019-08-11 09:49:51.909 (ZWave) General/kWh (Verbrauch Rolladen Nassia)
2019-08-11 09:49:53.911 (ZWave) Light/Switch (Unknown)
2019-08-11 09:49:53.790 Status: OpenZWave: Received timeout notification from HomeID: 4113634733, NodeID: 13 (0x0d)
2019-08-11 09:49:54.950 (RFLink01) Temp + Humidity (Cresta)
2019-08-11 09:49:54.962 (RFXCOM) Temp + Humidity (Vorgarten)
2019-08-11 09:49:55.021 (ZWave) Usage (Unknown)
2019-08-11 09:49:55.024 (ZWave) General/kWh (kWh Meter)
2019-08-11 09:49:55.065 (ZWave) Usage (Unknown)
2019-08-11 09:49:55.068 (ZWave) General/kWh (kWh Meter)
2019-08-11 09:50:00.274 OpenZWave: Domoticz has send a Switch command! NodeID: 10 (0x0a)
2019-08-11 09:50:00.280 (ZWave) Usage (Verbrauch Heizung Bad OG)
2019-08-11 09:50:00.282 (ZWave) General/kWh (kWh Meter)
2019-08-11 09:50:00.292 (ZWave) Light/Switch (Heizung Bad OG)
2019-08-11 09:50:00.293 OpenZWave: Domoticz has send a Switch command!, Level: 0, NodeID: 12 (0x0c)
2019-08-11 09:50:00.294 (ZWave) Usage (Unknown)
2019-08-11 09:50:00.299 (ZWave) General/kWh (Verbrauch Rolladen Schlafzimmer)
2019-08-11 09:50:00.305 (ZWave) Light/Switch (Rolladen Schlafzimmer)
2019-08-11 09:50:00.571 (ZWave) Light/Switch (Rolladen Schlafzimmer)
or
But I never pressed any buton and I cant find any Script (dzvents, Blockly or anything) that caused this action.
Please, Help, I have no Ideas, and it really stresses me.
BR
Clemens
________________________________________________________________________
global chief of permanent lightning and strike detonator
mastadook
Re: Problem with Zwave Devices Roller Shutters
Post by mastadook »
Update:
Yesterday, I excluded one of the Shutters and Included again.
The Error was gone for some hours...
Today in the Morning at 5:30... all Shutters gegin again toopen and shut down again some times.
I was realy pissed off of that Situation in the Morning, so I use a Temux Session (terminal on Mobilephone) to shut down the Raspi with Domoticz.
30 Minutes later, the Shutters went down and up again, without a running Domoticz Maschine,
OK, maybe the Zwave Stick still was powered on, I don know, whats happen when shutdown the Raspi with Power still connected.
But you see, maybe there is a hidden Camera Joking me, but I have no Idea.
At 8 about, I restart the Raspi, and all went fine until 10, then the Problem come back again.
Anyone with any Idea?
mastadook
Post by mastadook »
Update:
Today, I resett the Gen5 Stick and still, the Shutters going up and down...
whats up here? Any Idea?
mastadook
Post by mastadook »
Is my Question wrong?
Or has no one an Answer?
Or did I miss something?
Ron
Domoticz version: 2.2284
Post by Ron »
Could it be you connected some Z-Wave modules to the shutter modules by association ?
In that case a switch or device associated to the shutter module could control the shutter without a controller like Domoticz.
mastadook
Post by mastadook »
I removed all Devices from Zave Stick, resett everything to Factory Settings and add the Devices again.
3x 4 in One Sensor Temp,Lux,Movement,Humidity
3x Roller Shutter Fibaro
4x Cyrus Wall Plug with Energymeter
Then, one week everything was fine, since 2 Days, it startet again with this Ghost Switching.
Maybe this is something that happend butif, then by mistake.
I use the "Add Device" Button in Domoticz, add the Device, and rename it from Unknown to a correct Name.
Any Idea how I can cut this "Assosciation" between the Devices?
It is not switched by Domoticz, it must came from within the Z Wave Network.
