simple multiplication  [Solved]
EdddieN
Domoticz version: 4.9700
Post by EdddieN »
I think is one of those days that I'm missing something very obvious... what I'm doing wrong?
Update OIL
        -- timer riggers
        timer = {
            'every 1 minutes'
    -- custom logging level for this script
    logging = {
       level = domoticz.LOG_DEBUG,
       marker = "Update OIL"
   execute = function(domoticz)
   -- domoticz.devices
       domoticz.log('Running OIL updater...', domoticz.LOG_INFO)
            local oilCounter = domoticz.devices('Oil tank')
            local oil = domoticz.devices('AIN1')   -- oil sensor (machinon analogue signal)
            local oilconversion = tonumber(oil) * 14  -- convert to Litres
            if oilconversion ~= oilCounter.value then
                dz.log("OilCounter updated to " .. oilconversion ,dz.LOG_DEBUG)
                oilCounter.updateCustomSensor(oilconversion)
                dz.log("No update of oilCounter necessary. It is still " .. oil ,dz.LOG_DEBUG)
This results on
019-08-10 20:28:00.180 Status: dzVents: Error (2.4.10): Update OIL: ...omoticz/scripts/dzVents/generated_scripts/Oil sensor.lua:27: attempt to perform arithmetic on a nil value
11101101 - www.machinon.com
Thorgal789
Re: simple multiplication
Post by Thorgal789 »
line 27 > local oilconversion = tonumber(oil) * 14 -- convert to Litres
print the oil value to debug, I think the value is "nil"
hoeby
Domoticz version: V2022.1
Post by hoeby »
What gives 'AIN1' for value?
The script says it goes wrong in line 27. But line 27 starts at line 26 with making the local oil. When 'AIN1' is nil, than line 27 will also be nill
Also change dz.log into domoticz.log
Or change everything to dz instead of domoticz.
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
EdddieN
Post by EdddieN »
I'm very very rusty... got lazy and most of my scripts are in Blockly.
Ok, this is what I have now:
Update OIL
        -- timer riggers
        timer = {
            'every 1 minutes'
    logging = {
   execute = function(domoticz, devices)
   -- domoticz.devices
                domoticz.log("SENSOR value is " .. oil)
                domoticz.log("OilCounter updated to " .. oilconversion)
                domoticz.log("No update of oilCounter necessary. It is still " .. oil)
and still gives me
2019-08-10 21:02:00.252 Status: dzVents: Info: Update OIL: ------ Start internal script: Oil sensor:, trigger: every 1 minutes
2019-08-10 21:02:00.252 Status: dzVents: Info: Update OIL: Running OIL updater...
2019-08-10 21:02:00.270 Status: dzVents: Debug: Update OIL: Processing device-adapter for Oil tank: Custom sensor device adapter
2019-08-10 21:02:00.271 Status: dzVents: Debug: Update OIL: Processing device-adapter for AIN1: Voltage device adapter
2019-08-10 21:02:00.271 Status: dzVents: Error (2.4.10): Update OIL: An error occured when calling event handler Oil sensor
2019-08-10 21:02:00.271 Status: dzVents: Error (2.4.10): Update OIL: ...omoticz/scripts/dzVents/generated_scripts/Oil sensor.lua:27: attempt to concatenate local 'oil' (a table value)
2019-08-10 21:02:00.271 Status: dzVents: Info: Update OIL: ------ Finished Oil sensor
cannot even see the value of AIN1, which in domoticz is 59 volts
Thorgal789
local oil = domoticz.devices('AIN1') can't be a value (and a number), it's a table
Try
local oil = domoticz.devices('AIN1').temperature
With replacing "temperature" by the filed you need (Sorry I have never do dzevent, so hard for me to explain ^^)
EdddieN
Post by EdddieN »
Same results. If LUA is raise, happy to use lua.
hoeby
Post by hoeby »
Try this.
I tested the part oil*14 in my domoticz and it gives a value 14x bigger than oil.
I can't run the complete script, because i don't have those devices.
Also look that i added .state in local oilCounter
And removed .value in the IF
Update OIL
        -- timer riggers
        timer = {
            'every 1 minutes'
    logging = {
   -- domoticz.devices
            local oilCounter = domoticz.devices('Oil tank').state
            local oil = domoticz.devices('AIN1').state   -- oil sensor (machinon analogue signal)
            local oilconversion = oil * 14  -- convert to Litres
            if oilconversion ~= oilCounter then
EdddieN
Post by EdddieN »
Getting somewhere now!
 2019-08-11 09:10:00.296 Status: dzVents: Info: Update OIL: ------ Start internal script: Oil sensor:, trigger: every 1 minutes
2019-08-11 09:10:00.297 Status: dzVents: Info: Update OIL: Running OIL updater...
2019-08-11 09:10:00.332 Status: dzVents: Debug: Update OIL: Processing device-adapter for Oil tank: Custom sensor device adapter
2019-08-11 09:10:00.334 Status: dzVents: Debug: Update OIL: Processing device-adapter for AIN1: Voltage device adapter
2019-08-11 09:10:00.334 Status: dzVents: Info: Update OIL: SENSOR value is 59.687
2019-08-11 09:10:00.334 Status: dzVents: Info: Update OIL: OilCounter updated to 835.618
2019-08-11 09:10:00.334 Status: dzVents: Error (2.4.10): Update OIL: An error occured when calling event handler Oil sensor
2019-08-11 09:10:00.334 Status: dzVents: Error (2.4.10): Update OIL: ...omoticz/scripts/dzVents/generated_scripts/Oil sensor.lua:32: attempt to call field 'updateCustomSensor' (a nil value)
2019-08-11 09:10:00.334 Status: dzVents: Info: Update OIL: ------ Finished Oil sensor
Updating the counter with the new value is what it fails now.
EdddieN
Post by EdddieN »
Ok, finally it worked! Thanks so much!!!
Here it is the code
Update OIL
        -- timer riggers
        timer = {
            'every 1 minutes'
    logging = {
   -- domoticz.devices
EdddieN wrote:Ok, finally it worked! Thanks so much!!!
I guess the oil in this line also needs to be changed to oilconversion?
EdddieN
Post by EdddieN »
Yes, and also need to find out to remove the decimals, now I get something like '834.234L' which is far too much resolution. Any suggestions?
EdddieN wrote:Yes, and also need to find out to remove the decimals, now I get something like '834.234L' which is far too much resolution. Any suggestions?
Yes use domoticz.utils.round(your number var,1)
EdddieN
Post by EdddieN »
Like this?
oilconversion = dz.utils.round(oilconversion,1)
EdddieN wrote:Like this?
Yes but in your script you need to change dz to domoticz because that is the name of your parm containing the domoticz object.
I use dz as the name of this object in most of my scripts (too lazy to type the full name every timeImage)
EdddieN
Re: simple multiplication  [Solved]
Post by EdddieN »
Ah! I was wondering what dz, domoticz difference it was... thanks. That did the trick!
Update OIL
        -- timer riggers
        timer = {
            'every 1 minutes'
    logging = {
   -- domoticz.devices
            oilconversion = domoticz.utils.round(oilconversion,1)
            if oilconversion1 ~= oilCounter.value then
                domoticz.log("No update of oilCounter necessary. It is still " .. oilconversion)
