contact sensor multiple notifications
maia
Post by maia »
I have xiaomi door sensor mounted on my garage door, with open/close notifications enabled. everything works fine, except every time door open/close it fires 3 times.... so i receive 6 notifications each door cycle.
door opening:
13:23 garage open
13:23 garage close
13:23 garage open
door closing:
13:25 garage close
13:25 garage open
13:25 garage close
heared somewhere - "you should put 1sec delay on your sensor" but i have no such option in domoticz edit sensor interface.... please, advice how not to be burried under tons of notifications, not really want write python script with manual notification... and also prefer see in logs two lines instead of 6...
2018-12-12 09:03:57 Off
2018-12-12 09:03:57 On
2018-12-12 09:03:13 On
2018-12-12 09:03:13 Off
teemurama
Re: contact sensor multiple notifications
Post by teemurama »
I have same problem. Any solution for this one ?
Gerwin
Post by Gerwin »
Hello.
You can make a dummy switch and switch these on and of with a blocky script
If garage is open and dummy is off
Set : dummy on for 20sec
Message garage door is open
And also for close
Gerwin
