Zigate - errors after updating to 4.5
domogijs
Post by domogijs »
I updated to 4.5 but now i am getting errors.
Basis error is did not receive firmware version. As I understood this is a communication error
I already tried:
Set giopin in run mode (using tool and gio pin commands)
Restart plugin
Restart domoticz
No luck so far
Any ideas
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
pipiche
Re: Zigate - errors after updating to 4.5
Post by pipiche »
Please provide logs in order to see the full picture
pipiche
Post by pipiche »
I understood that is a pizigate, if so what are the results of using the test tools ?
domogijs
Post by domogijs »
Hi Pipiche
Hereby the log when restart the plugin.
2019-08-04 10:22:07.194 Status: (Zigate ) Started.
2019-08-04 10:22:07.792 Status: (Zigate ) Entering work loop.
2019-08-04 10:22:07.794 Status: (Zigate ) Initialized version 4.5, author 'zaraki673 pipiche38'
2019-08-04 10:22:07.804 Status: (Zigate ) Zigate plugin stable-4.5.1 started
2019-08-04 10:22:07.804 Status: (Zigate ) Python Version - 3.4.2 (default, Feb 10 2019, 17:57:51)
2019-08-04 10:22:07.804 [GCC 4.9.2]
2019-08-04 10:22:07.804 Status: (Zigate ) Switching Heartbeat to 5 s interval
2019-08-04 10:22:07.804 Status: (Zigate ) DomoticzVersion: 4.11062
2019-08-04 10:22:07.804 Status: (Zigate ) DomoticzHash: 77d4961e5
2019-08-04 10:22:07.805 Status: (Zigate ) DomoticzBuildTime: 2019-07-29 12:39:01
2019-08-04 10:22:07.805 Status: (Zigate ) load PluginConf
2019-08-04 10:22:07.807 Status: (Zigate ) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-08-04 10:22:07.807 Status: (Zigate ) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-08-04 10:22:07.807 Status: (Zigate ) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-29.json
2019-08-04 10:22:07.808 Status: (Zigate ) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-04 10:22:07.808 Status: (Zigate ) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-08-04 10:22:07.808 Status: (Zigate ) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-08-04 10:22:07.808 Status: (Zigate ) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-08-04 10:22:07.808 Status: (Zigate ) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-04 10:22:07.808 Status: (Zigate ) Opening DomoticzDB in raw
2019-08-04 10:22:07.818 Status: (Zigate ) Plugin Database: DeviceList-29.txt
2019-08-04 10:22:07.854 Status: (Zigate ) DeviceConf loaded
2019-08-04 10:22:07.855 Status: (Zigate ) load ListOfDevice
2019-08-04 10:22:08.004 Status: (Zigate ) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-29.txt : 9
2019-08-04 10:22:08.017 Status: (Zigate ) Transport mode: PI
2019-08-04 10:22:08.049 Status: (Zigate ) Python version: ['3.4.2 (default, Feb 10 2019, 17:57:51) ', '[GCC 4.9.2]'] dist: ('debian', '8.0', '') linux_distribution: ('debian', '8.0', '') system: Linux machine: armv7l platform: Linux-4.1.18-v7+-armv7l-with-debian-8.0 uname: uname_result(system='Linux', node='raspberrypi', release='4.1.18-v7+', version='#846 SMP Thu Feb 25 14:22:53 GMT 2016', machine='armv7l', processor='') version: #846 SMP Thu Feb 25 14:22:53 GMT 2016 mac_ver: ('', ('', '', ''), '')
2019-08-04 10:22:08.055 Error: (Zigate ) 'onStart' failed 'ImportError':'cannot import name 'run''.
2019-08-04 10:22:08.055 Error: (Zigate ) ----> Line 786 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-04 10:22:08.055 Error: (Zigate ) ----> Line 303 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-04 10:22:08.055 Error: (Zigate ) ----> Line 69 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/piZigate.py', function switchPiZigate_mode
2019-08-04 10:22:17.459 (Gateway 16) Light/Switch (Motion woon 2)
2019-08-04 10:22:17.823 (Zigate ) No Firmware Version received from Zigate
2019-08-04 10:22:17.629 Status: dzVents: Info: Handling events for: "Motion woon 2", value: "Off"
2019-08-04 10:22:17.630 Status: dzVents: Info: ------ Start internal script: Iemand thuis final: Device: "Motion woon 2 (Gateway 16)", Index: 639
2019-08-04 10:22:17.630 Status: dzVents: Info: ------ Finished Iemand thuis final
2019-08-04 10:22:19.626 (Thermosmart) Thermostat (Setpoint)
2019-08-04 10:22:19.634 (Thermosmart) Temp (room temperature)
2019-08-04 10:22:19.645 (Thermosmart) Temp (outside temperature)
2019-08-04 10:22:22.832 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-04 10:22:22.832 Error: (Zigate ) ----> Line 814 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:22.832 Error: (Zigate ) ----> Line 556 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:22.832 Error: (Zigate ) ----> Line 84 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-04 10:22:27.841 (Zigate ) No Firmware Version received from Zigate
2019-08-04 10:22:32.801 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-04 10:22:32.801 Error: (Zigate ) ----> Line 814 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:32.801 Error: (Zigate ) ----> Line 556 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:32.801 Error: (Zigate ) ----> Line 84 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-04 10:22:37.128 (RF Link) Temp (Oregon Temp 1)
2019-08-04 10:22:37.811 Status: (Zigate ) ZigateConf setting Channel(s) to: 0
2019-08-04 10:22:37.812 Status: (Zigate ) setChannel - Channel set to : 00000000
2019-08-04 10:22:37.812 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-04 10:22:37.812 Error: (Zigate ) ----> Line 814 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:37.812 Error: (Zigate ) ----> Line 558 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:37.812 Error: (Zigate ) ----> Line 59 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function start_Zigate
2019-08-04 10:22:37.812 Error: (Zigate ) ----> Line 1019 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function setChannel
2019-08-04 10:22:37.812 Error: (Zigate ) ----> Line 84 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-04 10:22:42.821 (Zigate ) No Firmware Version received from Zigate
2019-08-04 10:22:46.438 (RF Link) Temp (Oregon Temp 2)
2019-08-04 10:22:47.831 (Zigate ) No Firmware Version received from Zigate
2019-08-04 10:22:50.034 (Thermosmart) Thermostat (Setpoint)
2019-08-04 10:22:50.056 (Thermosmart) Temp (room temperature)
2019-08-04 10:22:50.064 (Thermosmart) Temp (outside temperature)
2019-08-04 10:22:52.840 (Zigate ) No Firmware Version received from Zigate
2019-08-04 10:22:52.840 (Zigate ) Try to get Firmware version once more HB:8
2019-08-04 10:22:52.840 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-04 10:22:52.840 Error: (Zigate ) ----> Line 814 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:52.840 Error: (Zigate ) ----> Line 565 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-04 10:22:52.840 Error: (Zigate ) ----> Line 84 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-04 10:22:57.498 (Gateway 16) Light/Switch (Motion Bathroom)
2019-08-04 10:22:57.850 (Zigate ) No Firmware Version received from Zigate
2019-08-04 10:22:57.687 Status: dzVents: Info: Handling events for: "Motion Bathroom", value: "On"
I have also issues withe the test tools:
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate$ git clone https://github.com/fairecasoimeme/PiZiGate-tools.git
Cloning into 'PiZiGate-tools'...
remote: Enumerating objects: 39, done.
remote: Counting objects: 100% (39/39), done.
remote: Compressing objects: 100% (31/31), done.
remote: Total 39 (delta 12), reused 27 (delta 7), pack-reused 0
Unpacking objects: 100% (39/39), done.
Checking connectivity... done.
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate$ cd PiZiGate-tools
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate/PiZiGate-tools$
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate/PiZiGate-tools$ cd test
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate/PiZiGate-tools/test$ make
gcc -c main.c -o main.o
gcc main.o -o PiZiGate_test -lwiringPi
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate/PiZiGate-tools/test$ chmod + x PiZiGate_test $ ./PiZiGate_test / dev / ttyAMA0
chmod: cannot access ‘x’: No such file or directory
chmod: cannot access ‘$’: No such file or directory
chmod: changing permissions of ‘/’: Operation not permitted
chmod: cannot access ‘dev’: No such file or directory
chmod: cannot access ‘ttyAMA0’: No such file or directory
Greets Gijs
pipiche
Post by pipiche »
Si please check the Zigate.fr/forum and/or wiki.
You need first to have the pizigate working in standalone.
You can also check the plugin wiki and especially that section
https://github.com/pipiche38/Domoticz-Z ... llation.md
domogijs
Post by domogijs »
I checked the zigate forum and the domoticz forum for several hours but i am clearly missing something.
This is what i did (a few times :))
steps for update on the wiki page
Run: git pull DONE (if i do it again i get the message "already up to date")
Run: sudo chmod +x plugin.py DONE
Restart Domoticz DONE
also
Checked giopins (Tools/pi-zigate.sh run) result 2 times OK DONE
restart plugin DONE
I am lost :( can you give me a hint?
Greets Gijs
pipiche
Post by pipiche »
Did you check that one ? https://github.com/pipiche38/Domoticz-Z ... ookbook.md
(1) is user pi part of group gpio ?
sudo usermod -a -G gpio pi
(1) https://zigate.fr/documentation/tester-sa-pizigate/
If the command
./PiZiGate_test /dev/ttyAMA0
doesn't work, I suspect that you have access right issue
You might try to run it like :
sudo ./PiZiGate_test /dev/ttyAMA0
(2) for the plugin issue, it seems that you are using a pretty old version of python3 ( python3.4).
try the following command:
pip3 install run
domogijs
Post by domogijs »
I solved the commucation issue. It was giopin related.
There is still een problem updating python. But that is not zigate related.
Greets Gijs
pipiche
Post by pipiche »
domogijs wrote: Sunday 04 August 2019 23:22 Thanks!
Greets Gijs
Coul you share , how you solve the communication issue ?
And what is the problem left ?
domogijs
Post by domogijs »
i did not use this "? https://github.com/pipiche38/Domoticz-Z ... ookbook.md" because i have a pi2 ans the title is about p3 (maybe change the title?)
Solved issue one (communication)
I did a manual change of the giopins. In domoticz we ui is an option restart system. I misunderstood this for the same as sudo service domoticz.sh restart but it is reboot the pi. So the giopins are back to default. (i am not able to put in in the boot)
Remaining isssue is this error:
2019-08-05 21:39:07.460 Error: (Zigate ) 'onStart' failed 'AttributeError':''NoneType' object has no attribute 'pluginConf''.
2019-08-05 21:39:07.460 Error: (Zigate ) ----> Line 786 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-05 21:39:07.460 Error: (Zigate ) ----> Line 200 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-05 21:39:07.460 Error: (Zigate ) ----> Line 524 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/tools.py', function loggingPlugin
i tried pip3 install run
but gives this error:
NameError: name 'file' is not defined
Complete output from command python setup.py egg_info:
File "<string>", line 17, in <module>
File "/tmp/pip-build-56v1n47y/run/setup.py", line 12, in <module>
long_description=file('README').read(),
for me there is no clear answer how to fix it when i google it.
I tried to install python 3.7 this way:
sudo apt-get update -y
sudo apt-get install build-essential tk-dev libncurses5-dev libncursesw5-dev libreadline6-dev libdb5.3-dev libgdbm-dev libsqlite3-dev libssl-dev libbz2-dev libexpat1-dev liblzma-dev zlib1g-dev libffi-dev -y
wget https://www.python.org/ftp/python/3.7.0 ... 7.0.tar.xz
tar xf Python-3.7.0.tar.xz
cd Python-3.7.0
./configure
make -j 4
sudo make altinstall
But when finished it is still running on 3.4
Greets Gijs
pipiche
Post by pipiche »
can you try pip3 install subprocess
domogijs
Post by domogijs »
I tried i get this:
pi@raspberrypi:~$ pip3 install subprocess
Downloading/unpacking subprocess
Could not find any downloads that satisfy the requirement subprocess
Cleaning up...
No distributions at all found for subprocess
Storing debug log for failure in /home/pi/.pip/pip.log
pipiche
Post by pipiche »
Do you mind switching to beta version to test one thing ?
If yes here is what to do:
- Stop domoticz
- go to the Domoticz-Zigate directory
git pull
git checkout beta
git pull
- Restart Domoticz
And let me know . If you can attached Log file that would be great (if it works, I'll see to retrofit this change to stable branche)
PS/ It looks like the Python version that you are having is lacking a number of modules that we are using since the new version of the plugin.
To return to 'stable' branch, you have simply to do
- Stop domoticz
- git to the Domoticz-Zigate directory/folder
git pull
git checkout stable
git pull
- Restart Domoticz
domogijs
Post by domogijs »
sure
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate$ git pull
remote: Enumerating objects: 82, done.
remote: Counting objects: 100% (82/82), done.
remote: Compressing objects: 100% (37/37), done.
remote: Total 67 (delta 50), reused 47 (delta 30), pack-reused 0
Unpacking objects: 100% (67/67), done.
From https://github.com/sasu-drooz/Domoticz-Zigate
   bcf9780..5307b95  beta       -> origin/beta
Already up-to-date.
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate$ git checkout beta
Branch beta set up to track remote branch beta from origin.
Switched to a new branch 'beta'
Already up-to-date.
pi@raspberrypi:~/domoticz/plugins/Domoticz-Zigate$ sudo service domoticz.sh restart
2019-08-06 19:50:18.358 (Zigate ) Device Name: 'Japan Klein'
2019-08-06 19:50:18.358 (Zigate ) Device nValue: 0
2019-08-06 19:50:18.358 (Zigate ) Device sValue: 'Off'
2019-08-06 19:50:18.358 (Zigate ) Device LastLevel: 67
2019-08-06 19:50:18.358 (Zigate ) Device Options: {}
2019-08-06 19:50:18.358 (Zigate ) Device: 5 - ID: 793, Name: 'Muurlamp T', nValue: 0, sValue: 'Off'
2019-08-06 19:50:18.358 (Zigate ) Device ID: '793'
2019-08-06 19:50:18.358 (Zigate ) Device Name: 'Muurlamp T'
2019-08-06 19:50:18.358 (Zigate ) Device LastLevel: 14
2019-08-06 19:50:18.359 (Zigate ) Device Options: {}
2019-08-06 19:50:18.359 (Zigate ) Device: 6 - ID: 798, Name: 'BadkamerT', nValue: 1, sValue: '100'
2019-08-06 19:50:18.359 (Zigate ) Device ID: '798'
2019-08-06 19:50:18.359 (Zigate ) Device Name: 'BadkamerT'
2019-08-06 19:50:18.359 (Zigate ) Device nValue: 1
2019-08-06 19:50:18.359 (Zigate ) Device sValue: '100'
2019-08-06 19:50:18.359 (Zigate ) Device LastLevel: 100
2019-08-06 19:50:18.359 (Zigate ) Device: 7 - ID: 806, Name: 'Zigate jezus - Voltage-0017880104f29cc9-02', nValue: 0, sValue: ''
2019-08-06 19:50:18.359 (Zigate ) Device ID: '806'
2019-08-06 19:50:18.359 (Zigate ) Device Name: 'Zigate jezus - Voltage-0017880104f29cc9-02'
2019-08-06 19:50:18.359 (Zigate ) Device nValue: 0
2019-08-06 19:50:18.359 (Zigate ) Device sValue: ''
2019-08-06 19:50:18.359 (Zigate ) Device LastLevel: 0
2019-08-06 19:50:18.359 (Zigate ) Device: 8 - ID: 807, Name: 'Zigate jezus - LvlControl-0017880104f29cc9-02', nValue: 0, sValue: ''
2019-08-06 19:50:18.359 (Zigate ) Device ID: '807'
2019-08-06 19:50:18.360 (Zigate ) Device Name: 'Zigate jezus - LvlControl-0017880104f29cc9-02'
2019-08-06 19:50:18.360 (Zigate ) Device nValue: 0
2019-08-06 19:50:18.360 (Zigate ) Device sValue: ''
2019-08-06 19:50:18.360 (Zigate ) Device LastLevel: 0
2019-08-06 19:50:18.360 (Zigate ) Device Options: {}
2019-08-06 19:50:18.360 (Zigate ) Device: 9 - ID: 808, Name: 'Zigate jezus - LvlControl-0017880104f29cc9-01', nValue: 0, sValue: ''
2019-08-06 19:50:18.360 (Zigate ) Device ID: '808'
2019-08-06 19:50:18.360 (Zigate ) Device Name: 'Zigate jezus - LvlControl-0017880104f29cc9-01'
2019-08-06 19:50:18.360 (Zigate ) Device: 10 - ID: 820, Name: 'BadkamerTT', nValue: 1, sValue: '100'
2019-08-06 19:50:18.360 (Zigate ) Device ID: '820'
2019-08-06 19:50:18.360 (Zigate ) Device Name: 'BadkamerTT'
2019-08-06 19:50:18.360 (Zigate ) Device nValue: 1
2019-08-06 19:50:18.361 (Zigate ) Device sValue: '100'
2019-08-06 19:50:18.361 (Zigate ) Device LastLevel: 100
2019-08-06 19:50:18.361 (Zigate ) Device Options: {}
2019-08-06 19:50:18.361 (Zigate ) Device: 11 - ID: 867, Name: 'Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01', nValue: 1, sValue: '100'
2019-08-06 19:50:18.361 (Zigate ) Device ID: '867'
2019-08-06 19:50:18.361 (Zigate ) Device Name: 'Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01'
2019-08-06 19:50:18.361 (Zigate ) Device nValue: 1
2019-08-06 19:50:18.361 (Zigate ) Device LastLevel: 0
2019-08-06 19:50:18.361 (Zigate ) Device: 12 - ID: 868, Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01', nValue: 1, sValue: '100'
2019-08-06 19:50:18.361 (Zigate ) Device ID: '868'
2019-08-06 19:50:18.361 (Zigate ) Device Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01'
2019-08-06 19:50:18.362 (Zigate ) Device Options: {}
2019-08-06 19:50:18.362 (Zigate ) Device: 13 - ID: 869, Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01', nValue: 1, sValue: '100'
2019-08-06 19:50:18.362 (Zigate ) Device ID: '869'
2019-08-06 19:50:18.362 (Zigate ) Device Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01'
2019-08-06 19:50:18.362 (Zigate ) Device nValue: 1
2019-08-06 19:50:18.362 (Zigate ) Device sValue: '100'
2019-08-06 19:50:18.362 (Zigate ) Device LastLevel: 0
2019-08-06 19:50:18.601 (Zigate ) runmode_with_osgpiocommand
2019-08-06 19:50:18.601 (Zigate ) + Checkint GPIO PINs
2019-08-06 19:50:18.342 Status: (Zigate ) Entering work loop.
2019-08-06 19:50:18.344 Status: (Zigate ) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-08-06 19:50:18.355 Status: (Zigate ) Zigate plugin beta-4.6.003 started
2019-08-06 19:50:18.362 Status: (Zigate ) Python Version - 3.4.2 (default, Jul 11 2019, 21:54:59)
2019-08-06 19:50:18.362 [GCC 4.9.2]
2019-08-06 19:50:18.362 Status: (Zigate ) Switching Heartbeat to 5 s interval
2019-08-06 19:50:18.362 Status: (Zigate ) DomoticzVersion: 4.11062
2019-08-06 19:50:18.362 Status: (Zigate ) DomoticzHash: 77d4961e5
2019-08-06 19:50:18.362 Status: (Zigate ) DomoticzBuildTime: 2019-07-29 12:39:01
2019-08-06 19:50:18.362 Status: (Zigate ) load PluginConf
2019-08-06 19:50:18.365 Status: (Zigate ) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-06 19:50:18.365 Status: (Zigate ) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-08-06 19:50:18.365 Status: (Zigate ) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-08-06 19:50:18.365 Status: (Zigate ) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-06 19:50:18.366 Status: (Zigate ) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-08-06 19:50:18.366 Status: (Zigate ) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-08-06 19:50:18.366 Status: (Zigate ) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-08-06 19:50:18.366 Status: (Zigate ) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-29.json
2019-08-06 19:50:18.366 Status: (Zigate ) Opening DomoticzDB in raw
2019-08-06 19:50:18.367 Status: (Zigate ) Plugin Database: DeviceList-29.txt
2019-08-06 19:50:18.406 Status: (Zigate ) DeviceConf loaded
2019-08-06 19:50:18.406 Status: (Zigate ) load ListOfDevice
2019-08-06 19:50:18.556 Status: (Zigate ) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-29.txt : 9
2019-08-06 19:50:18.567 Status: (Zigate ) Transport mode: PI
2019-08-06 19:50:18.596 Status: (Zigate ) Python version: ['3.4.2 (default, Jul 11 2019, 21:54:59) ', '[GCC 4.9.2]'] dist: ('debian', '8.0', '') linux_distribution: ('debian', '8.0', '') system: Linux machine: armv7l platform: Linux-4.1.18-v7+-armv7l-with-debian-8.0 uname: uname_result(system='Linux', node='raspberrypi', release='4.1.18-v7+', version='#846 SMP Thu Feb 25 14:22:53 GMT 2016', machine='armv7l', processor='') version: #846 SMP Thu Feb 25 14:22:53 GMT 2016 mac_ver: ('', ('', '', ''), '')
2019-08-06 19:50:18.757 Status: Python EventSystem: Initalizing event module.
2019-08-06 19:50:18.758 Status: EventSystem: Started
2019-08-06 19:50:18.758 Status: EventSystem: Queue thread started...
2019-08-06 19:50:18.601 Error: (Zigate ) Error while importing run from python module subprocess, fall back to os module
2019-08-06 19:50:18.601 Error: (Zigate ) 'onStart' failed 'TypeError'.
2019-08-06 19:50:18.601 Error: (Zigate ) ----> Line 788 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-06 19:50:18.601 Error: (Zigate ) ----> Line 297 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onStart
2019-08-06 19:50:18.601 Error: (Zigate ) ----> Line 34 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/piZigate.py', function switchPiZigate_mode
2019-08-06 19:50:18.602 Error: (Zigate ) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/piZigate.py', function runmode_with_gpiocommand
2019-08-06 19:50:18.602 Error: (Zigate ) ----> Line 115 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/piZigate.py', function runmode_with_osgpiocommand
2019-08-06 19:50:19.237 (RF Link) Temp (Oregon Temp 2)
2019-08-06 19:50:19.602 Status: Thermosmart: Login successfull!...
2019-08-06 19:50:20.003 (Thermosmart) Thermostat (Setpoint)
2019-08-06 19:50:20.023 (Thermosmart) Temp (room temperature)
2019-08-06 19:50:20.031 (Thermosmart) Temp (outside temperature)
2019-08-06 19:50:23.410 (Netatmo) Temp + Humidity + Baro (Indoor)
2019-08-06 19:50:23.429 (Netatmo) Air Quality (CO2)
2019-08-06 19:50:23.437 (Netatmo) General/Sound Level (DB)
2019-08-06 19:50:28.371 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:50:33.381 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-06 19:50:33.381 Error: (Zigate ) ----> Line 816 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:50:33.381 Error: (Zigate ) ----> Line 549 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:50:33.381 Error: (Zigate ) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-06 19:50:35.849 Error: OpenZWave: Driver Failed!!
2019-08-06 19:50:38.390 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:50:43.350 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-06 19:50:43.350 Error: (Zigate ) ----> Line 816 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:50:43.350 Error: (Zigate ) ----> Line 549 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:50:43.350 Error: (Zigate ) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-06 19:50:48.359 Status: (Zigate ) ZigateConf setting Channel(s) to: 0
2019-08-06 19:50:48.360 Status: (Zigate ) setChannel - Channel set to : 00000000
2019-08-06 19:50:48.360 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-06 19:50:48.360 Error: (Zigate ) ----> Line 816 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:50:48.360 Error: (Zigate ) ----> Line 551 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:50:48.360 Error: (Zigate ) ----> Line 59 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function start_Zigate
2019-08-06 19:50:48.360 Error: (Zigate ) ----> Line 1062 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function setChannel
2019-08-06 19:50:48.360 Error: (Zigate ) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-06 19:50:50.449 (Thermosmart) Thermostat (Setpoint)
2019-08-06 19:50:50.468 (Thermosmart) Temp (room temperature)
2019-08-06 19:50:50.477 (Thermosmart) Temp (outside temperature)
2019-08-06 19:50:52.359 (RF Link) Temp (Oregon Temp 1)
2019-08-06 19:50:53.370 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:50:58.232 (RF Link) Temp (Oregon Temp 2)
2019-08-06 19:50:58.379 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:03.388 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:03.388 (Zigate ) Try to get Firmware version once more HB:8
2019-08-06 19:51:03.388 Error: (Zigate ) 'onHeartbeat' failed 'AttributeError':''NoneType' object has no attribute 'sendData''.
2019-08-06 19:51:03.389 Error: (Zigate ) ----> Line 816 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:51:03.389 Error: (Zigate ) ----> Line 558 in '/home/pi/domoticz/plugins/Domoticz-Zigate/plugin.py', function onHeartbeat
2019-08-06 19:51:03.389 Error: (Zigate ) ----> Line 87 in '/home/pi/domoticz/plugins/Domoticz-Zigate/Modules/output.py', function sendZigateCmd
2019-08-06 19:51:08.398 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:13.357 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:18.367 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:18.367 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:18.367 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:18.367 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:18.367 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:20.858 (Thermosmart) Thermostat (Setpoint)
2019-08-06 19:51:20.878 (Thermosmart) Temp (room temperature)
2019-08-06 19:51:20.886 (Thermosmart) Temp (outside temperature)
2019-08-06 19:51:23.376 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:23.376 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:23.377 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:23.377 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:23.377 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:28.385 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:28.385 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:28.385 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:28.386 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:28.386 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:31.367 (RF Link) Temp (Oregon Temp 1)
2019-08-06 19:51:33.395 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:33.395 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:33.395 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:33.395 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:33.395 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:37.233 (RF Link) Temp (Oregon Temp 2)
2019-08-06 19:51:38.404 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:38.404 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:38.404 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:38.404 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:38.404 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:43.362 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:43.362 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:43.363 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:43.363 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:43.363 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:47.882 (Gateway 16) Light/Switch (Motion woon 2)
2019-08-06 19:51:48.378 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:48.083 Status: dzVents: Info: Handling events for: "Motion woon 2", value: "On"
2019-08-06 19:51:48.084 Status: dzVents: Info: ------ Start internal script: Iemand thuis final: Device: "Motion woon 2 (Gateway 16)", Index: 639
2019-08-06 19:51:48.086 Status: dzVents: Info: ------ Finished Iemand thuis final
2019-08-06 19:51:48.089 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-08-06 19:51:48.378 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:48.378 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:48.378 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:48.378 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:51.297 (Thermosmart) Thermostat (Setpoint)
2019-08-06 19:51:51.318 (Thermosmart) Temp (room temperature)
2019-08-06 19:51:51.326 (Thermosmart) Temp (outside temperature)
2019-08-06 19:51:51.771 (Gateway 16) Light/Switch (Motion gang)
2019-08-06 19:51:51.945 Status: dzVents: Info: Handling events for: "Motion gang", value: "On"
2019-08-06 19:51:51.945 Status: dzVents: Info: ------ Start internal script: Iemand thuis final: Device: "Motion gang (Gateway 16)", Index: 509
2019-08-06 19:51:51.947 Status: dzVents: Info: ------ Finished Iemand thuis final
2019-08-06 19:51:51.950 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-08-06 19:51:53.387 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:53.388 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:53.388 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:53.388 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:53.388 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:51:54.816 (Gateway 16) Light/Switch (Motion Sensor Kitchen Pink)
2019-08-06 19:51:54.990 Status: dzVents: Info: Handling events for: "Motion Sensor Kitchen Pink", value: "On"
2019-08-06 19:51:54.990 Status: dzVents: Info: ------ Start internal script: Iemand thuis final: Device: "Motion Sensor Kitchen Pink (Gateway 16)", Index: 537
2019-08-06 19:51:54.993 Status: dzVents: Info: ------ Finished Iemand thuis final
2019-08-06 19:51:54.996 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2019-08-06 19:51:58.397 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:51:58.397 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:51:58.397 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:51:58.397 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:51:58.397 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:52:03.407 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:52:03.407 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:52:03.407 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:52:03.407 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:52:03.407 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:52:08.367 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:52:08.367 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:52:08.367 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:52:08.367 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:52:08.367 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:52:10.358 (RF Link) Temp (Oregon Temp 1)
2019-08-06 19:52:13.377 (Zigate ) No Firmware Version received from Zigate
2019-08-06 19:52:13.377 Error: (Zigate ) Plugin is not started ...
2019-08-06 19:52:13.377 Error: (Zigate ) - Communication issue with the Zigate
2019-08-06 19:52:13.377 Error: (Zigate ) - restart once the plugin, and if this remain the same
2019-08-06 19:52:13.377 Error: (Zigate ) - unplug/plug the zigate
2019-08-06 19:52:16.233 (RF Link) Temp (Oregon Temp 2)
2019-08-06 19:52:18.386 (Zigate ) No Firmware Version received from Zigate
No firmware version received from zigate is also back ;(
the giopins seems to be right
 +-----+-----+---------+------+---+---Pi 2---+---+------+---------+-----+-----+
 | BCM | wPi |   Name  | Mode | V | Physical | V | Mode | Name    | wPi | BCM |
 |     |     |    3.3v |      |   |  1 || 2  |   |      | 5v      |     |     |
 |   2 |   8 |   SDA.1 |   IN | 1 |  3 || 4  |   |      | 5v      |     |     |
 |   3 |   9 |   SCL.1 |   IN | 1 |  5 || 6  |   |      | 0v      |     |     |
 |   4 |   7 | GPIO. 7 |   IN | 1 |  7 || 8  | 1 | ALT0 | TxD     | 15  | 14  |
 |     |     |      0v |      |   |  9 || 10 | 1 | ALT0 | RxD     | 16  | 15  |
 |  17 |   0 | GPIO. 0 |  OUT | 1 | 11 || 12 | 0 | IN   | GPIO. 1 | 1   | 18  |
 |  27 |   2 | GPIO. 2 |  OUT | 1 | 13 || 14 |   |      | 0v      |     |     |
 |  22 |   3 | GPIO. 3 |   IN | 0 | 15 || 16 | 0 | IN   | GPIO. 4 | 4   | 23  |
 |     |     |    3.3v |      |   | 17 || 18 | 0 | IN   | GPIO. 5 | 5   | 24  |
 |  10 |  12 |    MOSI |   IN | 0 | 19 || 20 |   |      | 0v      |     |     |
 |   9 |  13 |    MISO |   IN | 0 | 21 || 22 | 0 | IN   | GPIO. 6 | 6   | 25  |
 |  11 |  14 |    SCLK |   IN | 0 | 23 || 24 | 1 | IN   | CE0     | 10  | 8   |
 |     |     |      0v |      |   | 25 || 26 | 1 | IN   | CE1     | 11  | 7   |
 |   0 |  30 |   SDA.0 |   IN | 1 | 27 || 28 | 1 | IN   | SCL.0   | 31  | 1   |
 |   5 |  21 | GPIO.21 |   IN | 1 | 29 || 30 |   |      | 0v      |     |     |
 |   6 |  22 | GPIO.22 |   IN | 1 | 31 || 32 | 0 | IN   | GPIO.26 | 26  | 12  |
 |  13 |  23 | GPIO.23 |   IN | 0 | 33 || 34 |   |      | 0v      |     |     |
 |  19 |  24 | GPIO.24 |   IN | 0 | 35 || 36 | 0 | IN   | GPIO.27 | 27  | 16  |
 |  26 |  25 | GPIO.25 |   IN | 0 | 37 || 38 | 0 | IN   | GPIO.28 | 28  | 20  |
 |     |     |      0v |      |   | 39 || 40 | 0 | IN   | GPIO.29 | 29  | 21  |
pi@raspberrypi:~$ sudo service domoticz.sh restart
pipiche
Post by pipiche »
can you try once more:
git pull (from the Plugin folder)
and then restart. I fixed an issue at startup
domogijs
Post by domogijs »
It works!' Happy happy happy, thanks!
2019-08-06 21:15:19.521 Civil twilight start: 05:28:00 Civil twilight end: 22:05:00
2019-08-06 21:15:19.521 Nautical twilight start: 04:34:00 Nautical twilight end: 22:59:00
2019-08-06 21:15:19.521 Astronomical twilight start: 03:20:00 Astronomical twilight end: 00:13:00
2019-08-06 21:15:19.685 Active notification Subsystems: gcm, kodi (2/13)
2019-08-06 21:15:19.702 Starting shared server on: :::6144
2019-08-06 21:15:19.454 Status: Domoticz V4.11062 (c)2012-2019 GizMoCuz
2019-08-06 21:15:19.454 Status: Build Hash: 77d4961e5, Date: 2019-07-29 12:39:01
2019-08-06 21:15:19.454 Status: System: Raspberry Pi
2019-08-06 21:15:19.454 Status: Startup Path: /home/pi/domoticz/
2019-08-06 21:15:19.668 Status: PluginSystem: Started, Python version '3.4.2'.
2019-08-06 21:15:19.687 Status: WebServer(HTTP) started on address: :: with port 8080
2019-08-06 21:15:19.696 Status: WebServer(SSL) started on address: :: with port 443
2019-08-06 21:15:19.701 Status: Camera: settings (re)loaded
2019-08-06 21:15:19.703 Status: TCPServer: shared server started...
2019-08-06 21:15:19.703 Status: RxQueue: queue worker started...
2019-08-06 21:15:21.806 Kodi: (Kodi) Starting thread.
2019-08-06 21:15:21.907 Kodi: Starting I/O service thread.
2019-08-06 21:15:21.705 Status: Kodi: Started
2019-08-06 21:15:21.705 Status: Harmony Hub: Worker thread started...
2019-08-06 21:15:21.704 Status: Thermosmart: Worker started...
2019-08-06 21:15:21.707 Status: XiaomiGateway (ID=21): Delaying worker startup...
2019-08-06 21:15:21.914 Status: RFLink: Using serial port: /dev/ttyUSB0
2019-08-06 21:15:22.204 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2019-08-06 21:15:22.302 Status: OpenZWave: Starting...
2019-08-06 21:15:22.303 Status: OpenZWave: Version: 1.6-808-gbb0a4bf7-dirty
2019-08-06 21:15:22.834 Status: RFLink: Controller Initialized!...
2019-08-06 21:15:22.909 Status: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2019-08-06 21:15:26.707 Status: XiaomiGateway (ID=21): Selected as main Gateway
2019-08-06 21:15:26.713 Status: (Zigate ) Started.
2019-08-06 21:15:26.713 Status: XiaomiGateway (ID=21): Worker started...
2019-08-06 21:15:26.713 Status: Netatmo: Worker started...
2019-08-06 21:15:26.713 Status: XiaomiGateway (ID=21): Using 192.168.178.19 for local IP address.
2019-08-06 21:15:26.714 Status: EventSystem: reset all events...
2019-08-06 21:15:26.718 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Iemand thuis final.lua
2019-08-06 21:15:26.718 Status: XiaomiGateway: RGB Gateway Detected
2019-08-06 21:15:26.718 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Koffie Off iemand thuis.lua
2019-08-06 21:15:26.719 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Koffie on iemand thuis.lua
2019-08-06 21:15:26.719 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bell.lua
2019-08-06 21:15:26.719 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Woon Japan Klein toggle.lua
2019-08-06 21:15:26.720 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bell tussen.lua
2019-08-06 21:15:26.720 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Sleepbridge.lua
2019-08-06 21:15:26.720 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Gang click.lua
2019-08-06 21:15:26.721 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Verwarming aan beweging.lua
2019-08-06 21:15:26.721 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bathroom Click T.lua
2019-08-06 21:15:26.721 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Bathroom off iemand thuis T.lua
2019-08-06 21:15:26.722 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Gang off iemand thuis.lua
2019-08-06 21:15:26.722 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/nu wel.lua
2019-08-06 21:15:26.722 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/japan oefen.lua
2019-08-06 21:15:26.723 Status: EventSystem: reset all device statuses...
2019-08-06 21:15:26.708 Error: Harmony Hub: Cannot connect to Harmony Hub. Check IP/Port.
2019-08-06 21:15:27.791 (Zigate ) Device count: 13
2019-08-06 21:15:27.791 (Zigate ) Device: 1 - ID: 789, Name: 'Zigate jezus - Zigate Status 29', nValue: 0, sValue: 'Startup'
2019-08-06 21:15:27.791 (Zigate ) Device ID: '789'
2019-08-06 21:15:27.791 (Zigate ) Device Name: 'Zigate jezus - Zigate Status 29'
2019-08-06 21:15:27.791 (Zigate ) Device nValue: 0
2019-08-06 21:15:27.791 (Zigate ) Device sValue: 'Startup'
2019-08-06 21:15:27.792 (Zigate ) Device LastLevel: 0
2019-08-06 21:15:27.792 (Zigate ) Device Options: {}
2019-08-06 21:15:27.792 (Zigate ) Device: 2 - ID: 790, Name: 'Zigate jezus - Zigate Notifications 29', nValue: 0, sValue: 'Zigate Channel: 11'
2019-08-06 21:15:27.792 (Zigate ) Device ID: '790'
2019-08-06 21:15:27.792 (Zigate ) Device Name: 'Zigate jezus - Zigate Notifications 29'
2019-08-06 21:15:27.792 (Zigate ) Device nValue: 0
2019-08-06 21:15:27.792 (Zigate ) Device sValue: 'Zigate Channel: 11'
2019-08-06 21:15:27.792 (Zigate ) Device: 3 - ID: 791, Name: 'Gang T', nValue: 1, sValue: '100'
2019-08-06 21:15:27.793 (Zigate ) Device ID: '791'
2019-08-06 21:15:27.793 (Zigate ) Device Name: 'Gang T'
2019-08-06 21:15:27.793 (Zigate ) Device nValue: 1
2019-08-06 21:15:27.793 (Zigate ) Device sValue: '100'
2019-08-06 21:15:27.793 (Zigate ) Device LastLevel: 100
2019-08-06 21:15:27.793 (Zigate ) Device Options: {}
2019-08-06 21:15:27.793 (Zigate ) Device: 4 - ID: 792, Name: 'Japan Klein', nValue: 0, sValue: 'Off'
2019-08-06 21:15:27.793 (Zigate ) Device ID: '792'
2019-08-06 21:15:27.793 (Zigate ) Device Name: 'Japan Klein'
2019-08-06 21:15:27.793 (Zigate ) Device nValue: 0
2019-08-06 21:15:27.793 (Zigate ) Device sValue: 'Off'
2019-08-06 21:15:27.793 (Zigate ) Device LastLevel: 67
2019-08-06 21:15:27.793 (Zigate ) Device: 5 - ID: 793, Name: 'Muurlamp T', nValue: 0, sValue: 'Off'
2019-08-06 21:15:27.793 (Zigate ) Device ID: '793'
2019-08-06 21:15:27.794 (Zigate ) Device Name: 'Muurlamp T'
2019-08-06 21:15:27.794 (Zigate ) Device nValue: 0
2019-08-06 21:15:27.794 (Zigate ) Device sValue: 'Off'
2019-08-06 21:15:27.794 (Zigate ) Device LastLevel: 14
2019-08-06 21:15:27.794 (Zigate ) Device Options: {}
2019-08-06 21:15:27.794 (Zigate ) Device: 6 - ID: 798, Name: 'BadkamerT', nValue: 1, sValue: '100'
2019-08-06 21:15:27.794 (Zigate ) Device ID: '798'
2019-08-06 21:15:27.794 (Zigate ) Device Name: 'BadkamerT'
2019-08-06 21:15:27.794 (Zigate ) Device nValue: 1
2019-08-06 21:15:27.794 (Zigate ) Device sValue: '100'
2019-08-06 21:15:27.794 (Zigate ) Device LastLevel: 100
2019-08-06 21:15:27.794 (Zigate ) Device: 7 - ID: 806, Name: 'Zigate jezus - Voltage-0017880104f29cc9-02', nValue: 0, sValue: ''
2019-08-06 21:15:27.794 (Zigate ) Device ID: '806'
2019-08-06 21:15:27.794 (Zigate ) Device Name: 'Zigate jezus - Voltage-0017880104f29cc9-02'
2019-08-06 21:15:27.794 (Zigate ) Device sValue: ''
2019-08-06 21:15:27.795 (Zigate ) Device LastLevel: 0
2019-08-06 21:15:27.795 (Zigate ) Device Options: {}
2019-08-06 21:15:27.795 (Zigate ) Device: 8 - ID: 807, Name: 'Zigate jezus - LvlControl-0017880104f29cc9-02', nValue: 0, sValue: ''
2019-08-06 21:15:27.795 (Zigate ) Device ID: '807'
2019-08-06 21:15:27.795 (Zigate ) Device Name: 'Zigate jezus - LvlControl-0017880104f29cc9-02'
2019-08-06 21:15:27.795 (Zigate ) Device nValue: 0
2019-08-06 21:15:27.795 (Zigate ) Device sValue: ''
2019-08-06 21:15:27.795 (Zigate ) Device: 9 - ID: 808, Name: 'Zigate jezus - LvlControl-0017880104f29cc9-01', nValue: 0, sValue: ''
2019-08-06 21:15:27.795 (Zigate ) Device ID: '808'
2019-08-06 21:15:27.795 (Zigate ) Device Name: 'Zigate jezus - LvlControl-0017880104f29cc9-01'
2019-08-06 21:15:27.796 (Zigate ) Device: 10 - ID: 820, Name: 'BadkamerTT', nValue: 1, sValue: '100'
2019-08-06 21:15:27.796 (Zigate ) Device ID: '820'
2019-08-06 21:15:27.796 (Zigate ) Device Name: 'BadkamerTT'
2019-08-06 21:15:27.796 (Zigate ) Device nValue: 1
2019-08-06 21:15:27.796 (Zigate ) Device sValue: '100'
2019-08-06 21:15:27.796 (Zigate ) Device LastLevel: 100
2019-08-06 21:15:27.796 (Zigate ) Device Options: {}
2019-08-06 21:15:27.796 (Zigate ) Device: 11 - ID: 867, Name: 'Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01', nValue: 1, sValue: '100'
2019-08-06 21:15:27.796 (Zigate ) Device ID: '867'
2019-08-06 21:15:27.796 (Zigate ) Device Name: 'Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01'
2019-08-06 21:15:27.796 (Zigate ) Device LastLevel: 0
2019-08-06 21:15:27.797 (Zigate ) Device: 12 - ID: 868, Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01', nValue: 1, sValue: '100'
2019-08-06 21:15:27.797 (Zigate ) Device ID: '868'
2019-08-06 21:15:27.797 (Zigate ) Device Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01'
2019-08-06 21:15:27.797 (Zigate ) Device nValue: 1
2019-08-06 21:15:27.797 (Zigate ) Device sValue: '100'
2019-08-06 21:15:27.797 (Zigate ) Device LastLevel: 0
2019-08-06 21:15:27.797 (Zigate ) Device Options: {}
2019-08-06 21:15:27.797 (Zigate ) Device: 13 - ID: 869, Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01', nValue: 1, sValue: '100'
2019-08-06 21:15:27.797 (Zigate ) Device ID: '869'
2019-08-06 21:15:27.797 (Zigate ) Device Name: 'Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01'
2019-08-06 21:15:27.024 Status: PluginSystem: Entering work loop.
2019-08-06 21:15:27.772 Status: (Zigate ) Entering work loop.
2019-08-06 21:15:27.774 Status: (Zigate ) Initialized version beta-4.6, author 'zaraki673 pipiche38'
2019-08-06 21:15:27.788 Status: (Zigate ) Zigate plugin beta-4.6.003 started
2019-08-06 21:15:27.797 Status: (Zigate ) Python Version - 3.4.2 (default, Jul 11 2019, 21:54:59)
2019-08-06 21:15:27.797 [GCC 4.9.2]
2019-08-06 21:15:27.798 Status: (Zigate ) Switching Heartbeat to 5 s interval
2019-08-06 21:15:27.798 Status: (Zigate ) DomoticzVersion: 4.11062
2019-08-06 21:15:27.798 Status: (Zigate ) DomoticzHash: 77d4961e5
2019-08-06 21:15:27.798 Status: (Zigate ) DomoticzBuildTime: 2019-07-29 12:39:01
2019-08-06 21:15:27.798 Status: (Zigate ) load PluginConf
2019-08-06 21:15:27.801 Status: (Zigate ) pluginConfig set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/
2019-08-06 21:15:27.801 Status: (Zigate ) pluginHome set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-06 21:15:27.801 Status: (Zigate ) pluginWWW set to /home/pi/domoticz/plugins/Domoticz-Zigate/www/
2019-08-06 21:15:27.801 Status: (Zigate ) pluginReports set to /home/pi/domoticz/plugins/Domoticz-Zigate/Reports/
2019-08-06 21:15:27.801 Status: (Zigate ) pluginOTAFirmware set to /home/pi/domoticz/plugins/Domoticz-Zigate/OTAFirmware/
2019-08-06 21:15:27.801 Status: (Zigate ) filename set to /home/pi/domoticz/plugins/Domoticz-Zigate/Conf/PluginConf-29.json
2019-08-06 21:15:27.801 Status: (Zigate ) pluginData set to /home/pi/domoticz/plugins/Domoticz-Zigate/Data/
2019-08-06 21:15:27.801 Status: (Zigate ) homedirectory set to /home/pi/domoticz/plugins/Domoticz-Zigate/
2019-08-06 21:15:27.802 Status: (Zigate ) Opening DomoticzDB in raw
2019-08-06 21:15:27.802 Status: (Zigate ) Plugin Database: DeviceList-29.txt
2019-08-06 21:15:27.841 Status: (Zigate ) DeviceConf loaded
2019-08-06 21:15:27.841 Status: (Zigate ) load ListOfDevice
2019-08-06 21:15:28.061 (Zigate ) runmode_with_osgpiocommand
2019-08-06 21:15:28.062 (Zigate ) + Checkint GPIO PINs
2019-08-06 21:15:28.157 (RF Link) Temp (Oregon Temp 2)
2019-08-06 21:15:28.180 (Zigate ) + Checkint GPIO PINs
2019-08-06 21:15:28.226 (Zigate ) setTimeServer - Setting UTC Time to : 618441328
2019-08-06 21:15:28.009 Status: (Zigate ) Entries loaded from /home/pi/domoticz/plugins/Domoticz-Zigate/Data/DeviceList-29.txt : 9
2019-08-06 21:15:28.026 Status: (Zigate ) Transport mode: PI
2019-08-06 21:15:28.056 Status: (Zigate ) Python version: ['3.4.2 (default, Jul 11 2019, 21:54:59) ', '[GCC 4.9.2]'] dist: ('debian', '8.0', '') linux_distribution: ('debian', '8.0', '') system: Linux machine: armv7l platform: Linux-4.1.18-v7+-armv7l-with-debian-8.0 uname: uname_result(system='Linux', node='raspberrypi', release='4.1.18-v7+', version='#846 SMP Thu Feb 25 14:22:53 GMT 2016', machine='armv7l', processor='') version: #846 SMP Thu Feb 25 14:22:53 GMT 2016 mac_ver: ('', ('', '', ''), '')
2019-08-06 21:15:28.226 Status: (Zigate ) Configure Permit To Join
2019-08-06 21:15:28.227 Status: (Zigate ) Request Accepting new Hardware for ever
2019-08-06 21:15:28.227 Status: (Zigate ) Trigger a Topology Scan
2019-08-06 21:15:28.229 Status: (Zigate ) Trigger a Energy Level Scan
2019-08-06 21:15:28.361 Status: Python EventSystem: Initalizing event module.
2019-08-06 21:15:28.361 Status: EventSystem: Started
2019-08-06 21:15:28.361 Status: EventSystem: Queue thread started...
2019-08-06 21:15:28.553 Status: dzVents: Info: Handling events for: "Bell", value: "On"
2019-08-06 21:15:28.553 Status: dzVents: Info: ------ Start internal script: Bell tussen: Device: "Bell (Gateway 16)", Index: 519
2019-08-06 21:15:28.553 Status: dzVents: Info: ------ Finished Bell tussen
2019-08-06 21:15:28.923 Status: Thermosmart: Login successfull!...
2019-08-06 21:15:28.061 Error: (Zigate ) Error while importing run from python module subprocess, fall back to os module
2019-08-06 21:15:28.412 Error: (Zigate ) onMessage : Frame size is bad, computed = 20 received = 31
2019-08-06 21:15:28.412 Error: (Zigate ) onMessage : Frame CRC is bad, computed = 169 received = 78
2019-08-06 21:15:29.317 (Thermosmart) Thermostat (Setpoint)
2019-08-06 21:15:29.335 (Thermosmart) Temp (room temperature)
2019-08-06 21:15:29.342 (Thermosmart) Temp (outside temperature)
2019-08-06 21:15:32.737 (Netatmo) Temp + Humidity + Baro (Indoor)
2019-08-06 21:15:32.751 (Netatmo) Air Quality (CO2)
2019-08-06 21:15:32.758 (Netatmo) General/Sound Level (DB)
2019-08-06 21:15:37.880 (Zigate ) No Firmware Version received from Zigate
2019-08-06 21:15:42.404 (Zigate ) UTC time is: 618441342, Zigate Time is: 618441328 with deviation of :14
2019-08-06 21:15:42.404 (Zigate ) setTimeServer - Setting UTC Time to : 618441342
2019-08-06 21:15:42.609 (Zigate ) Permit Join status: 01
2019-08-06 21:15:42.609 (Zigate ) ---> self.permitTojoin['Starttime']: 1565118928
2019-08-06 21:15:42.609 (Zigate ) ---> Current time : 1565118942
2019-08-06 21:15:42.609 (Zigate ) ---> self.Ping['Permit'] (prev) : None
2019-08-06 21:15:42.609 (Zigate ) ---> self.Ping['Permit'] (new ) : On
2019-08-06 21:15:42.725 (Zigate ) Initialize Zigate Data Structure 0000 00158d0001eda63f
2019-08-06 21:15:42.869 (Zigate ) No Firmware Version received from Zigate
2019-08-06 21:15:42.609 Status: (Zigate ) Accepting new Hardware: On
2019-08-06 21:15:42.755 Status: (Zigate ) Zigate addresses ieee: 00158d0001eda63f , short addr: 0000
2019-08-06 21:15:42.755 Status: (Zigate ) Network state UP, PANID: 7616 extPANID: 0x817ba5979d023723 Channel: 11
2019-08-06 21:15:42.878 Status: (Zigate ) Number of devices recently active in Zigate = 5
2019-08-06 21:15:43.292 (Zigate ) UTC time is: 618441343, Zigate Time is: 618441343 with deviation of :0
2019-08-06 21:15:43.393 (Zigate ) Decode8045 - Reception Active endpoint response : SQN : 1a, Status ZIGATE - [00] Success, short Addr 0000, List 02, Ep list 010a
2019-08-06 21:15:45.386 Error: OpenZWave: Driver Failed!!
2019-08-06 21:15:47.907 (Zigate ) No Firmware Version received from Zigate
2019-08-06 21:15:52.867 (Zigate ) No Firmware Version received from Zigate
2019-08-06 21:15:52.867 (Zigate ) Try to get Firmware version once more HB:4
2019-08-06 21:15:52.970 Status: (Zigate ) Major Version Num: 0003
2019-08-06 21:15:52.970 Status: (Zigate ) Installer Version Number: 030f
2019-08-06 21:15:57.026 (Gateway 16) Color Switch (Xiaomi RGB Gateway (192.168.192.131))
2019-08-06 21:15:57.054 (Gateway 16) Lux (Xiaomi Gateway Lux)
2019-08-06 21:15:57.885 Status: (Zigate ) Zigate set to Certification : CE
2019-08-06 21:15:57.886 Status: (Zigate ) Start Web Server connection
2019-08-06 21:15:57.929 Status: (Zigate ) Web backend for Web User Interface started on port: 9440
2019-08-06 21:15:57.930 Status: (Zigate ) Plugin with Zigate firmware 030f correctly initialized
2019-08-06 21:15:58.852 Status: (Zigate ) There is a newer Zigate Firmware version available
2019-08-06 21:15:59.737 (Thermosmart) Thermostat (Setpoint)
2019-08-06 21:15:59.752 (Thermosmart) Temp (room temperature)
2019-08-06 21:15:59.759 (Thermosmart) Temp (outside temperature)
2019-08-06 21:16:01.362 (RF Link) Temp (Oregon Temp 1)
2019-08-06 21:16:03.552 (Zigate ) lowlevelAPSFailure - WARNING - received APSFailure d80b 0100 02d80b0101000800000000010000, will wait for a Route Discoverys
2019-08-06 21:16:03.655 (Zigate ) lowlevelAPSFailure - WARNING - received APSFailure d80b 0100 02d80b0101000800000000010000, will wait for a Route Discoverys
2019-08-06 21:16:07.153 (RF Link) Temp (Oregon Temp 2)
2019-08-06 21:16:13.467 (Zigate ) processFrame - New Route Discovery KO, drop 0100 02d80b0101000800000000010000
2019-08-06 21:16:13.468 (Zigate ) Last Commands Queue
2019-08-06 21:16:13.468 (Zigate ) [0] Command: 0100 TimeStamp: Tue Aug 6 21:16:03 2019 (1565118963.4262238)
2019-08-06 21:16:13.469 (Zigate ) [1] Command: 0100 TimeStamp: Tue Aug 6 21:16:03 2019 (1565118963.5509517)
2019-08-06 21:16:13.469 (Zigate ) processAPSFailure - Nwkid: d80b process 1565118963.5509517 InPeriod: True - Cmd: 0100 Payload: 02d80b0101000800000000010000
2019-08-06 21:16:13.469 (Zigate ) processAPSFailure - d80b found cmd: 0100[02d80b0101000800000000010000] in the APS time window, age is: 9.92 sec
2019-08-06 21:16:13.469 (Zigate ) timedOutDevice unit Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01 nwkid: d80b
2019-08-06 21:16:13.475 (Zigate ) processFrame - New Route Discovery KO, drop 0100 02d80b0101000800000000010000
2019-08-06 21:16:13.475 (Zigate ) Last Commands Queue
2019-08-06 21:16:13.476 (Zigate ) [0] Command: 0100 TimeStamp: Tue Aug 6 21:16:03 2019 (1565118963.4262238)
2019-08-06 21:16:13.476 (Zigate ) [1] Command: 0100 TimeStamp: Tue Aug 6 21:16:03 2019 (1565118963.5509517)
2019-08-06 21:16:13.476 (Zigate ) processAPSFailure - Nwkid: d80b process 1565118963.5509517 InPeriod: True - Cmd: 0100 Payload: 02d80b0101000800000000010000
2019-08-06 21:16:13.477 (Zigate ) processAPSFailure - d80b found cmd: 0100[02d80b0101000800000000010000] in the APS time window, age is: 9.92 sec
2019-08-06 21:16:13.580 (Zigate ) lowlevelAPSFailure - WARNING - received APSFailure c3d4 0100 02c3d40101000800000000010000, will wait for a Route Discoverys
2019-08-06 21:16:13.682 (Zigate ) lowlevelAPSFailure - WARNING - received APSFailure c3d4 0100 02c3d40101000800000000010000, will wait for a Route Discoverys
2019-08-06 21:16:13.474 Error: (Zigate ) APS Failure , Command: 0x0100:Read Attribute request for (Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01,d80b,90fd9ffffe32ae6d) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-08-06 21:16:13.477 Error: (Zigate ) APS Failure , Command: 0x0100:Read Attribute request for (Zigate jezus - LED1536G5_LvlControl-90fd9ffffe32ae6d-01,d80b,90fd9ffffe32ae6d) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-08-06 21:16:23.533 (Zigate ) processFrame - New Route Discovery KO, drop 0100 02c3d40101000800000000010000
2019-08-06 21:16:23.534 (Zigate ) Last Commands Queue
2019-08-06 21:16:23.534 (Zigate ) [0] Command: 0100 TimeStamp: Tue Aug 6 21:16:13 2019 (1565118973.4596267)
2019-08-06 21:16:23.534 (Zigate ) [1] Command: 0100 TimeStamp: Tue Aug 6 21:16:13 2019 (1565118973.5799186)
2019-08-06 21:16:23.535 (Zigate ) processAPSFailure - Nwkid: c3d4 process 1565118973.5799186 InPeriod: True - Cmd: 0100 Payload: 02c3d40101000800000000010000
2019-08-06 21:16:23.535 (Zigate ) processAPSFailure - c3d4 found cmd: 0100[02c3d40101000800000000010000] in the APS time window, age is: 9.95 sec
2019-08-06 21:16:23.535 (Zigate ) timedOutDevice unit Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01 nwkid: c3d4
2019-08-06 21:16:23.541 (Zigate ) processFrame - New Route Discovery KO, drop 0100 02c3d40101000800000000010000
2019-08-06 21:16:23.541 (Zigate ) Last Commands Queue
2019-08-06 21:16:23.542 (Zigate ) [0] Command: 0100 TimeStamp: Tue Aug 6 21:16:13 2019 (1565118973.4596267)
2019-08-06 21:16:23.542 (Zigate ) [1] Command: 0100 TimeStamp: Tue Aug 6 21:16:13 2019 (1565118973.5799186)
2019-08-06 21:16:23.542 (Zigate ) processAPSFailure - Nwkid: c3d4 process 1565118973.5799186 InPeriod: True - Cmd: 0100 Payload: 02c3d40101000800000000010000
2019-08-06 21:16:23.543 (Zigate ) processAPSFailure - c3d4 found cmd: 0100[02c3d40101000800000000010000] in the APS time window, age is: 9.96 sec
2019-08-06 21:16:23.540 Error: (Zigate ) APS Failure , Command: 0x0100:Read Attribute request for (Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01,c3d4,d0cf5efffeb400bc) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-08-06 21:16:23.543 Error: (Zigate ) APS Failure , Command: 0x0100:Read Attribute request for (Zigate jezus - LED1536G5_LvlControl-d0cf5efffeb400bc-01,c3d4,d0cf5efffeb400bc) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-08-06 21:16:30.148 (Thermosmart) Thermostat (Setpoint)
2019-08-06 21:16:30.169 (Thermosmart) Temp (room temperature)
2019-08-06 21:16:30.177 (Thermosmart) Temp (outside temperature)
2019-08-06 21:16:40.361 (RF Link) Temp (Oregon Temp 1)
2019-08-06 21:16:46.155 (RF Link) Temp (Oregon Temp 2)
2019-08-06 21:16:53.928 (Gateway 16) Color Switch (Xiaomi RGB Gateway (192.168.192.131))
2019-08-06 21:16:53.956 (Gateway 16) Lux (Xiaomi Gateway Lux)
2019-08-06 21:17:00.994 (Thermosmart) Thermostat (Setpoint)
2019-08-06 21:17:01.021 (Thermosmart) Temp (room temperature)
2019-08-06 21:17:01.032 (Thermosmart) Temp (outside temperature)
2019-08-06 21:17:08.583 (Zigate ) lowlevelAPSFailure - WARNING - received APSFailure 14cb 0100 0214cb0101000800000000010000, will wait for a Route Discoverys
2019-08-06 21:17:08.685 (Zigate ) lowlevelAPSFailure - WARNING - received APSFailure 14cb 0100 0214cb0101000800000000010000, will wait for a Route Discoverys
2019-08-06 21:17:18.518 (Zigate ) processFrame - New Route Discovery KO, drop 0100 0214cb0101000800000000010000
2019-08-06 21:17:18.518 (Zigate ) Last Commands Queue
2019-08-06 21:17:18.519 (Zigate ) [0] Command: 0100 TimeStamp: Tue Aug 6 21:17:08 2019 ( 1565119028.47332)
2019-08-06 21:17:18.519 (Zigate ) [1] Command: 0100 TimeStamp: Tue Aug 6 21:17:08 2019 (1565119028.5824316)
2019-08-06 21:17:18.519 (Zigate ) processAPSFailure - Nwkid: 14cb process 1565119028.5824316 InPeriod: True - Cmd: 0100 Payload: 0214cb0101000800000000010000
2019-08-06 21:17:18.520 (Zigate ) processAPSFailure - 14cb found cmd: 0100[0214cb0101000800000000010000] in the APS time window, age is: 9.94 sec
2019-08-06 21:17:18.520 (Zigate ) timedOutDevice unit Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01 nwkid: 14cb
2019-08-06 21:17:18.525 (Zigate ) processFrame - New Route Discovery KO, drop 0100 0214cb0101000800000000010000
2019-08-06 21:17:18.526 (Zigate ) Last Commands Queue
2019-08-06 21:17:18.526 (Zigate ) [0] Command: 0100 TimeStamp: Tue Aug 6 21:17:08 2019 ( 1565119028.47332)
2019-08-06 21:17:18.526 (Zigate ) [1] Command: 0100 TimeStamp: Tue Aug 6 21:17:08 2019 (1565119028.5824316)
2019-08-06 21:17:18.527 (Zigate ) processAPSFailure - Nwkid: 14cb process 1565119028.5824316 InPeriod: True - Cmd: 0100 Payload: 0214cb0101000800000000010000
2019-08-06 21:17:18.527 (Zigate ) processAPSFailure - 14cb found cmd: 0100[0214cb0101000800000000010000] in the APS time window, age is: 9.94 sec
2019-08-06 21:17:18.524 Error: (Zigate ) APS Failure , Command: 0x0100:Read Attribute request for (Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01,14cb,d0cf5efffe2fa637) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-08-06 21:17:18.527 Error: (Zigate ) APS Failure , Command: 0x0100:Read Attribute request for (Zigate jezus - LED1536G5_LvlControl-d0cf5efffe2fa637-01,14cb,d0cf5efffe2fa637) not correctly transmited. ( d4, NWK - [d4] Unicast frame does not have a route available but it is buffered for automatic resend )
2019-08-06 21:17:19.364 (RF Link) Temp (Oregon Temp 1)
2019-08-06 21:17:25.154 (RF Link) Temp (Oregon Temp 2)
2019-08-06 21:17:26.720 Harmony Hub: Reattempt login.
2019-08-06 21:17:31.467 (Thermosmart) Thermostat (Setpoint)
2019-08-06 21:17:31.477 (Thermosmart) Temp (room temperature)
2019-08-06 21:17:31.484 (Thermosmart) Temp (outside temperature)
2019-08-06 21:17:31.726 Error: Harmony Hub: Cannot connect to Harmony Hub. Check IP/Port.
2019-08-06 21:17:41.848 (Gateway 16) Color Switch (Xiaomi RGB Gateway (192.168.192.131))
pipiche
Post by pipiche »
Thanks for your patience. I'll retrofit the fix to the stable branche.
I'll let you know when it is done, so you'll be able to switch back to 'stable' branch by doing
git pull
git checkout stable
git pull
domogijs
Post by domogijs »
No problem :) I am happy it works again. Thanks for your effort.
pipiche
Post by pipiche »
@domogijs I have pushed the fix on stable branche, so feel free to switch back to stable
git pull
git checkout stable
git pull
