Bad value alarm/indicator for kWh meters
kimhav
Domoticz version: 2023.2
Post by kimhav »
A feature which would be to have a alarm/notification for meters when a certain value is meet. Could be for example when the meter receives for example an update for kWh usage which deviates more than a certain percent or goes higher than a certain per-defined value.
Bad values seems to be an issue once a while for various reasons and sometimes I do notice them and other time I miss them and get bad statistics. So this request would also support this and this one.
kimhav
Re: Bad value alarm/indicator for kWh meters
Post by kimhav »
Would be possible to script to monitor this?
kimot
Domoticz version: v3.8153
Post by kimot »
DzVents sripts, maybe blockly too.
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
kimhav wrote: Sunday 24 February 2019 21:06 Would be possible to script to monitor this?
Can you try this and report your findings ?
Thx.
-- updateAlarm
    enter in the description fields of the sensors you want to check the string
    updateAlarm:
    followed by a JSON formatted string with the dzVents fields you want to check and the max. percentage that an update can deviate without sending a notification
    like
    updateAlarm: { "WhTotal": "0.5%","WhActual": 5000 }    -- example is for a kWh device meaning the WhTotal can deviate max 0.5% and WhActual can deviate max 5000
    updateAlarm: { "usage": "0.1%","usageDelivered": 200 } -- example is for a P1 device meaning the usage can deviate max 0.1% and usagedelivered can deviate max 200
    updateAlarm: { "counter": "3", "counter": "20"  }      -- example for counter or Gas devices; the counter can deviate max 3% and also for max 20
    updateAlarm: { "temperature": "10"  }                  -- example for temperature-sensor; the temperature can deviate max 10 degrees
local updateAlarmDevices =  { 1636,1628 }        -- List of all devices you want to have monitored by this script
            on     =    { devices           = updateAlarmDevices },
        logging    =    {   level           =  domoticz.LOG_DEBUG,
                            marker          =  "updateAlarm"
         data      =   {    updateAlarms    = { initial = {} }},   --Array with deviceNames, fields and last seen values
    execute = function(dz,item)
        local function logWrite(str,level)             -- Support function for shorthand debug log statements
            dz.log(tostring(str),level or dz.LOG_DEBUG)
        local myNotificationTable   = {                 -- table with one or more notification system.
                                                        -- Can be one or more of
                                                        -- dz.NSS_GOOGLE_CLOUD_MESSAGING,
                                                        dz.NSS_PUSHOVER,
                                                        -- dz.NSS_HTTP,
                                                        -- dz.NSS_KODI,
                                                        -- dz.NSS_LOGITECH_MEDIASERVER,
                                                        -- dz.NSS_NMA,
                                                        -- dz.NSS_PROWL,
                                                        -- dz.NSS_PUSHALOT,
                                                        -- dz.NSS_PUSHBULLET,
                                                        -- dz.NSS_PUSHOVER,
                                                        -- dz.NSS_PUSHSAFER,
                                }                                                             -- uncomment the subsystem(s) you want to be used
        controlSettings = item.description:match("updateAlarm: ({.*})") or ""       -- look for line with updateAlarm: { "fieldName" : "maxDelta setting" } in description field
        controlSettings = controlSettings:gsub("updateAlarm:","")                   -- extract JSON string from line with updateAlarm: from description field
        if controlSettings == "" then
            logWrite('No controlSettings found in description field. I expected something like updateAlarm: {"usage":"0.1","usageDeliverd":"2%" } ',dz.LOG_ERROR)
            return
        rt = dz.utils.fromJSON (controlSettings)                            -- load json in table
        for key, value in pairs(rt) do
            if dz.data.updateAlarms[item.name] == nil then
                dz.data.updateAlarms[item.name] = {}                        -- init var as table
            if dz.data.updateAlarms[item.name][key] ~= nil then             -- If we have a value
                local maxDelta = tostring(value):gsub("%%","")              -- remove % if any
                if tostring(value) == tostring(maxDelta) then
                    maxDelta = maxDelta * dz.data.updateAlarms[item.name][key] / 100 -- maxDelta is defined as percentage
                if math.abs((dz.data.updateAlarms[item.name][key] - item[key])) > tonumber(maxDelta) then
                    logWrite("delta > " .. value .. "  You have been warned.")
                    dz.notify("Update alarm","device " .. item.name .. "; old " ..  key .. ": " .. dz.data.updateAlarms[item.name][key] .. ";  Now: ".. item[key] ,nil,nil,"",  myNotificationTable )
                    logWrite("delta < " .. value .. "; All OK")
            dz.data.updateAlarms[item.name][key] = item[key]                 -- load value in dz.data table
kimhav
Post by kimhav »
Thanks for the above and I've missed this response totally and haven't played around with DzVents, yet. About the alarm triggering and actually rethinking this. Why would I actually want an alarm where it would be better to have the system to react on totally bad sensor input. in 100% of my so called erroneous sensor data it's ridiculous values which the system could react on by itself by either 1) just ignore the value and set the value to zero (0) or 2) replace the value with an average input over a certain period or just re-use the last know value.
Whether this would be possible DzVents that would be nice but even better if it was built into Domoticz as an auto error correction feature which could be enabled for a device/sensor.
Typicall error which I see from my pulse counters is often something like this:
