Timer events more frequent then once a minute  [Solved]
joran
Domoticz version: 3.8153
Post by joran »
I'm trying to call a python script using dzVents, this works great but there is one problem. I want to call the script once every 10 seconds, is this possible using the timer trigger? I read on the wiki that dzVents scans the timer events only once a minute but I was wondering if someone found a workaround for this. If this isn't possible I will be making a custom plug-in but I would like to use dzVents. I don't want to use a dummy device for triggering the script. I hope you can help me.
code:
timer = { 'every minute' }
local cmd1 = ('/home/pi/domoticz/scripts/adc.py 72 0 32')
domoticz.log('adc read')
os.execute(cmd1)
Re: Timer events more frequent then once a minute  [Solved]
joran wrote: Monday 29 July 2019 22:53 I want to call the script once every 10 seconds, is this possible using the timer trigger?
Not with ONLY a timer. This a restriction from the domoticz event system.
This should do it
local scriptTrigger = 'frequentFlyer'
return
    on =
        timer = { 'every 5 minutes' },
        httpResponses = { scriptTrigger },
    execute = function(dz, item)
        if item.isTimer then
            url = dz.settings['Domoticz url'] .. "/json.htm?type=command&param=addlogmessage&message=" .. scriptTrigger .. "_script_trigger"
            for seconds = 10, 290, 10 do -- start with 10 step 10 until 290
                dz.openURL({url = url, callback = scriptTrigger }).afterSec(seconds)
        dz.log('adc read')
        os.execute(cmd1)
joran
Post by joran »
This works great, thank you so much. This saves me a lot of work, I had to make a custom plugin if this wasn't an option. This is certainly something to keep in mind when doing other implementations.
Users browsing this forum: Google [Bot] and 0 guests
