I'm looking to retrieve the ID and UnitCode from my somfy automatic blinds that I have setup in Domoticz.
Is there any possibility to get those from domoticz?
This in order to prevent that I have to program my blinds again, in case of.
kind regards,
Pieter
Retrieve used ID and UnitCode from somfy blinds Topic is solved
Iedipipeau
- waaren
Re: Retrieve used ID and UnitCode from somfy blinds
It's all in the domoticz.dbIedipipeau wrote: Wednesday 24 July 2019 20:48 I'm looking to retrieve the ID and UnitCode from my somfy automatic blinds that I have setup in Domoticz.
on the CLI
sudo cp <domoticz dir>/domoticz.db workcopy.db
sudo sqlite3 workcopy.db
sqlite> .header on
sqlite> .tables
sqlite> select Name, ID, DeviceID, Unit from devicestatus where type = 26; -- or if your type is different select them with ID as search key
sqlite> select Name, ID, DeviceID, Unit, type from devicestatus where ID = 292;
sqlite> .quit
sudo rm workcopy.dbDebian buster, bullseye on RPI-4, Intel NUC.
Iedipipeau
Hi!
Thx a lot for the information.
In fact... stupid me! I had downloaded a backup of the database from domoticz and read it with DBBrowser for SQLlite.
It never came into my mind that the answer was in front of me
Thanks anyway for the command line solution!
