Blinds status wrong when using hardware switch Topic is solved
sailmich
Post by sailmich »
Newest Domoticz beta on Rpi3 with zStick.
My fibaro fgrm222 and philio pan08-1 shows wrong status when open/close or set level with hardware switch. I don't know if it is a bug in Domoticz or OZW.
emme
Domoticz version: latest
Re: Blinds status wrong when using hardware switch
Post by emme »
what exactly you mean with shows wrong status when open/close
are they inverted?
if so there are 2 reasons and solution:
- Wrong wirings ==> adjust wirings
- User INVERTED option in the Domoticz shutter device configuration
ciao
M
"We always done this way"
sailmich
Post by sailmich »
They just stay were they are before I switched hardware switch. E.g. I have a virtual switch for night mode when switch on all blinds are going down to closed position. Next morning I just open a few blinds with hardware switch e.g. blind in bathroom that relay still showing closed as status.
elythomaslumber
Domoticz version: 2023.1
Post by elythomaslumber »
Is your "hardware switch" a RF switch or connected via wires to the blinds?
If it is a RF switch, is the "Zstick" also a receiver or just a transmitter?
sailmich
Post by sailmich »
All are wired switches and working for year's without this issue.
emme
Post by emme »
are you using dzvents?
there were an issue with the open/close command in previous betas..... :P
sailmich
Post by sailmich »
Yes I use dzvents but what is the relationship between dzvents and not sending status of the relay?
sailmich
Post by sailmich »
After restart Domoticz in a terminal all is working again. :o
