save scripts with new name and keep the old
- Domoticz version: 4.11597
After updating to version: 4.10548 it is not possible to save a blockly script in different versions with different names. When I give a script a new name, the old name is just overwritten. How do I keep different versions of a script for testing?
- Domoticz version: 2023.2
Re: save scripts with new name and keep the old
How to import & export? Via clipboard? It does not work as the clipboard remains empty and a "blocking" sign pops up.
Used Z-Wave devices: EUR_SPIRITZ, FGBS001, FGR223, FGS223, FGBS222, ZMNHYD1 Smart Plug 16A, ZWA009 AërQ Sensor, NAS-WR01Z Power plug 12A, ZME_WALLC-S, FGD212, ST812 Flood Detector, PAN04-1 Double Relay Switch, ZMNHND1 Flush 1D relay, ZME_UZB1 USB Stick
- waaren
on event editor screen
choose old script
press export
Click outside the block
[ctrl] a
[ctrl] c
notepad or other editor of your choice
[ctrl] v
select all text between xml tags (beginning with <xml and ending with </xml>)
[ctrl] c
press +
press Blockly and type new name into the name field
press import and paste clipboard into popup
press save
Perfect, thank you! I knew I was only a click away...
May I take the liberty to suggest a faster (lazier) way?
choose old script
Just press export and DON'T Click anywhere else!
[ctrl] a
[ctrl] c
esc
press +
press import
[ctrl] v
press save
choose old script
[ctrl] a
[ctrl] c
esc
press +
press import
[ctrl] v
press save
- waaren
