MQTT domoticz/out topic on arduino
I am facing an issue with receiving a message on the arduino from the Domoticz server. The arduino is reading the topics that it publishes itself fine, and also reads topics published directly from the raspberry pi mosquitto server.
however it doesn't read any switch statements. I have now made a dummy device to create virtual switches/sensors. the server reads the MQTT message from the arduino and sets the virtual temperature sensor for example, but i can't read any switch commands sent from the domoticz server.
How is this normally done? do I have to define a topic for the message per virtual switch? i thought every topic was domoticz/out.
Can anyone point me in the right direction?
thanks in advance.
thanks in advance.
- waaren
Re: MQTT domoticz/out topic on arduino
Can you describe what you did so far.
Did you add a MQTT Client Gateway with LAN interface as hardware in domoticz ? Settings ?
Where is your broker located ?
My broker is on a raspberry pi in the network. the arduino is also in the network.
I have added the mqtt gateway over LAN and I have communication between the 2. Arduino publishes a temperature and domoticz receives this in a the log correctly and puts it in a virtual temperature gauge. so far so good.
the arduino also subscribes to the domoticz/in topic and that works. it receives the message that it publishes.
the problem is receiving data from a switch or anything on the topic "domoticz out". I have a feeling I am configuring the domoticz virtual switch in a wrong manner because I can see in the log that I have pressed the switch, but I don't see the full mqtt package in the log like the incoming traffic but I don't know if that is normally the case.
Does adding a virtual switch automatically make it publish on domoticz/out over mqtt?
If i publish a message on the command line on the pi with the mosquitto_pub function the arduino also reads it fine (when subscribing to any topic I put in the command ofcourse.
- waaren
If you set your mqtt gateway over LAN settings in domoticz to flat (out) it will publish switch events to domoticz/out
- Spoiler: show
- emme
- Domoticz version: latest
MQTT in domoticz is a sort of console for logs... my understanding is that you cannot issue a command to query the state of a device via MQTT
you have to grab the ID during the event and store it.
OR, query the device via HTTP API/JSON request
hope this is what you are willing to get
"We always done this way"
This goes for any switch? virtual switches as well? is there any way to see the message as the MQTT message in the log so I can be sure that the topic is correct? Is there also a way to assign a user-specified topic to an action as well? say switch_light will be topic "switch_light". also, is it possible to set the state of the switch in Domoticz via an incoming MQTT message?If you set your mqtt gateway over LAN settings in domoticz to flat (out) it will publish switch events to domoticz/out
Thanks for the reply. I don't need to query the state of a device in that manner. I just want to press the switch in the console and send an MQTT message out on the appropriate topic.MQTT in domoticz is a sort of console for logs... my understanding is that you cannot issue a command to query the state of a device via MQTT
hope this is what you are willing to get![]()
- waaren
Not for all sensors (not for a text sensor) but virtual switches: Yes
I useI just want to press the switch in the console and send an MQTT message out on the appropriate topic.
mosquitto_sub -F "%U - %t - %p" -v -h <brokerIP> -p 1883 -t '#'
Alright I will give this a go to see if the domoticz console actually sends out the MQTT message because I am suspecting that part.CODE: SELECT ALL
furthermore there are no settings required for outgoing messages? timeout on the MQTT gateway or anything specific?
I'll let you know how I get on.
Ok I got it running. I made the mistake of asigning the IP address of the arduino in the gateway, but I also had a second gateway with the localhost IP which is the raspberry that runs the server. obviously I shouldn't have put the MQTT gateway for the arduino in there since that is not the broker, but I didn't realize that thourougly what I was doing there.
After this I received the switch commands in the raspberry pi server with the code you mentioned, apart that I had to fill in -T instead of -F and <IPbroker> was localhost.
Furthermore I had to change the header file of the MQTT library of the arduino to accept packages of 512bytes. default was 128 bytes but this was too limited for the messages of the domoticz.
Thanks for the help!
To JanJelle.
Sorry for my English. I have a similar problem like you.
I can send an MQTT message to domoticz from arduino. I can not get the domotics message. Could you send me your sketch arduino, who is reading the switching instruction?
PubClient has a default message size which is 128 bytes. As you probably know json message from domoticz on domiticz/out is much bigger. What you need to do is edit PubSubClient.h and change default size of message.
Just change
#define MQTT_MAX_PACKET_SIZE 128
to
#define MQTT_MAX_PACKET_SIZE 1024
Just change
to
- Westcott
SebaNowy,
Thanks for finding that, and posting the solution!
It needs to be added to the MQTT Wiki.
