Pass2PHP
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
sl = set level.
So that is:
sl('Dimmer', 50);
Trigun
Domoticz version: 4.10717
Re: Pass2PHP
Post by Trigun »
Nice!! thnx :)
Trigun
Re: Pass2PHP
Post by Trigun »
Hi Guys,
I have a PIR in my bathroom so when I enter the bathroom at night the light is only at 30% instead of the full 100%.
I have the following script to do so:
Device script:
<?php
if($status=='On'&&TIME>=strtotime('T20:00')){
sl('Badkamer', 30, true);
_cron60 script:
if ($d['Badkamer']['s']>='1'&&$d['Auto']['s']=='Off'&&$d['PIR_Badkamer']['s']=='Off'&&past('Badkamer')>60) {
	sl('Badkamer', 0);
for some reason it keeps triggering the set level to 0 which causes my logfile to fill up with these requests.
I have more PIR's in my hous and they don't act this way.
the only difference is that the light in the bathroom is a dimmer and not a switch.
is there a chance you can help me out to prevent this from happening?
thnx!
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
quick fix:
if not off after 60 sec... $d['Badkamer']['s']!='Off' and the rest of the requirements is true...
sw('Badkamer', ' Off');
should do the trick
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Egregius
Re: Pass2PHP
Post by Egregius »
Your cron60 has an error:
	sl('Badkamer', 0);
That should be:
if ($d['Badkamer']['s']>=1&&$d['Auto']['s']=='Off'&&$d['PIR_Badkamer']['s']=='Off'&&past('Badkamer')>60) {
	sl('Badkamer', 0);
Remove the quotes around numbers. With quotes numbers are treated as string and can't be evaluated with >=
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Sunday 28 July 2019 21:32
I can't seem to get my head around it.
the script is as following:
<?php
if($status=='On'/*&&TIME<=strtotime('T08:00')&&TIME>=strtotime('T19:00')*/){
Elseif($status=='On'&&TIME>=strtotime('T08:00')&&TIME<=strtotime('T19:00')){
sl('Badkamer', 90, true);
and the cronjob is as following:
if ($d['Badkamer']['s']>=1&&$d['PIR_Badkamer']['s']=='Off'&&past('Badkamer')>60) {
	sl('Badkamer', 0);
with this setup the light does not automatically go off but is cron job is definitely running, since its working for te rest.
What did I mis? :(
Egregius
Re: Pass2PHP
Post by Egregius »
Look in the database for the exact names and values. Code looks good.
Egregius
Re: Pass2PHP
Post by Egregius »
Or add a lg function just in front of it and keep the logfile open in tail:
lg('Badkamer='.$d['Badkamer']['s'].', PIR='.$d['PIR_Badkamer']['s'].', past='.past('Badkamer'));
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Saturday 03 August 2019 21:20 Look in the database for the exact names and values. Code looks good.
ive added the lg function which works good and it gives me the values as expected but the cron doesnt work(for the others it works ok though)
i checked the database, the name is correct but the value in the database says: ”Set Level: 57 %” instead of just 57.
could this be the reason?
Egregius
Re: Pass2PHP
Post by Egregius »
Then it doesn't give values as expected.
The logfile should be something like this then:
Badkamer = Set Level: 57 %... instead of Badkamer = 57.
You must check what version of Pass2php you're using:
In older versions there was a array in the pass2php file that had to be filled with the names of dimmers.
In the latest versions that's handled in the sql database, the dt field should be 'dimmer'.
For the dimmer devices this is done:
if ($d[$device]['dt']=='dimmer'||$d[$device]['dt']=='rollers'||$d[$device]['dt']=='luifel') {
    if ($status=='Off'||$status=='Open') {
        $status=0;
    } elseif ($status=='On'||$status=='Closed') {
        $status=100;
    } else {
        $status=filter_var($status, FILTER_SANITIZE_NUMBER_INT);
the filter_var strips all characters that aren't numeric.
Trigun
Pass2PHP
Post by Trigun »
I have php version 7.0.33-0 which is the latest right?
You are right! The log file says: Badkamer = Set Level: 57 %
I really need it to numeric as it is much easier to work with instead of set level etc etc
BTW. If I quote the value like this: >'1'
 if ($d['Badkamer']['s']>'1'/*&&$d['PIR_Badkamer']['s']=='Off'*/&&past('Badkamer')>60){
	sl('Badkamer', 20);
It does workImageImage
What is going on?? Haha
Egregius
Re: Pass2PHP
Post by Egregius »
Post the code of pass2php.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote: Tuesday 06 August 2019 9:47 Post the code of pass2php.
the code of the pass2php.php file is as following(You mean this file right?:
<?php
 * Pass2PHP
 * php version 7.3.3-1
 * @category Home_Automation
 * @package  Pass2PHP
 * @author   Guy Verschuere <[email protected]>
 * @license  GNU GPLv3
 * @link     https://egregius.be
require '/var/www/config.php';
require 'functions.php';
$device=$_REQUEST['d'];
$status=$_REQUEST['s'];
$username='Domoticz';
if (endswith($device, '_Temperature')) {
    die('Nothing to do');
} elseif (endswith($device, '_Utility')) {
if (in_array(
    $device, array(
            'PIR-Bijkeuken',
            'zithoek',
            'kamer',
            'tobi',
            'alex',
            'terras',
            'lichtbadkamer',
            'Xvol',
            'Rliving',
            'Rbureel',
            'RkeukenL',
            'RkeukenR',
            'RkamerL',
            'RkamerR',
            'Rtobi',
            'Ralex',
            'luifel'
        store($device, 0);
        store($device, 100);
    } else {
        store($device, $status);
} elseif (in_array($device, array('badkamer_temp'))) {
    $status=explode(';', $status);
    $status=$status[0];
} elseif ($device=='achterdeur') {
    if ($status=='Open') {
        $status='Closed';
    } else {
        $status='Open';
} else {
lgsql('Domoticz',$device,$status);
lg($device.' = '.$status);
@include 'pass2php/'.$device.'.php';
The function: $d['Badkamer']['s']>'1' doesn't work though, it seems that the script skipt it. Unfortunately there is no error in the NginX error.log though
Trigun
Re: Pass2PHP
Post by Trigun »
I saw that more values within the database are not broken down in separate values.
2019-08-06 16_08_07-192.168.1.200 _ localhost _ domotica _ devices _ phpMyAdmin 4.6.6deb4.png
2019-08-06 16_08_07-192.168.1.200 _ localhost _ domotica _ devices _ phpMyAdmin 4.6.6deb4.png (30.96 KiB) Viewed 2018 times
2019-08-06 16_08_53-192.168.1.200 _ localhost _ domotica _ devices _ phpMyAdmin 4.6.6deb4.png
2019-08-06 16_08_53-192.168.1.200 _ localhost _ domotica _ devices _ phpMyAdmin 4.6.6deb4.png (34.74 KiB) Viewed 2018 times
Egregius
Re: Pass2PHP
Post by Egregius »
Either you update to the latest pass2php version where devicetypes are stored in the dt column of the database or you fill the array with your own devices:
$device, array(
            'PIR-Bijkeuken',
            'zithoek',
            'kamer',
            'tobi',
            'alex',
            'terras',
            'lichtbadkamer',
            'Xvol',
            'Rliving',
            'Rbureel',
            'RkeukenL',
            'RkeukenR',
            'RkamerL',
            'RkamerR',
            'Rtobi',
            'Ralex',
            'luifel'
PIR-Bijkeuken shouldn't be in there. That array holds the devices of wich the data has to be filtered to numbers.
For the other devices you'll have to make something like I did for my badkamer_temp:
    $status=$status[0];
explode splits a string into a array.
Trigun
Re: Pass2PHP
Post by Trigun »
What is the latest PHP version?
If I do a regular apt-get update and upgrade, it says everything is up to date?
Egregius
Re: Pass2PHP
Post by Egregius »
I didn't wrote the last php version, but the last pass2php version.
That's always on my Github.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote:I didn't wrote the last php version, but the last pass2php version.
I only see a reference to php 7.0 based on the pass2php topic. Is there another topic or a link to share?
Egregius
Re: Pass2PHP
Post by Egregius »
Please read my previous reply carefully.
Trigun
Re: Pass2PHP
Post by Trigun »
Egregius wrote:Please read my previous reply carefully.
Of course I can enter all the device in the array but I would rather have the latest PHP version. I checked your github page Image but couldn’t find the php version
