unwanted devices in dashticz
pvklink
Domoticz version: latest b
Post by pvklink »
Hi, i jyst added a zwave sensor to my dashticz that displays the wattage of my washing machine/ I measure this for testing if my machine is ready and then gives a message by let my google assistant speaks an turning a led lamp red.
i want to display this to check if my algoritmes are working.
But when i add this device (it is displaying) i get two more devices (kwh and onother one)..
How do i delete these from dashticz?
Jablotron connection, Ikea
EdwinK
Re: unwanted devices in dashticz
Post by EdwinK »
I think the device is giving 2 or more data-streams. So you have one with the kwh and another one. You can use the following (adapt the idx to your idx ;))
'IDX_1'
pvklink
Post by pvklink »
i tried 982-1 and 982_1 no switch at all
EdwinK
Post by EdwinK »
Try with '928_1' with the ' at the beginning and end
pvklink
Post by pvklink »
yep works! thanks!
pvklink
Post by pvklink »
1) Is there an other way to give the icons for devices with a datastream another color?
2) also hide_data does not work...
my trials:
blocks['982_1'] = {}
blocks['982_1']['title'] = 'Was machine';
blocks['982_1']['icon'] = 'fas fa-bolt';
blocks['982_1']['hide_data'] = true;
blocks['982_1']['width'] = 3;
and in css
.fa-bolt.on {color: red !important;}
.fa-bolt.off {color: green !important;}
last part does not work...
this also does not work
.block_982_1 .fa-bolt.on {color: red;}
.block_982_1 .fa-bolt.off {color: lightgrey;}
HansieNL
Post by HansieNL »
Can you try: .fas.fa-bolt.on {color: red !important;}
Blah blah blah
pvklink
Post by pvklink »
thanks, but did not work...
/* .fa-bolt.on {color: red !important;} */
/* .fa-bolt.off {color: green !important;} */
.fas.fa-bolt.on {color: green !important;}
HansieNL
Post by HansieNL »
@pvklink: Can you try: .block_982_1 .icon.on {color: red;}
Blah blah blah
pvklink
Post by pvklink »
noop, still does not work..
here is my config...
i did remove de /* ... */ to activate it...
these are all the trials...
the attached image is a little bit older then the config (no update date anymore , i added: last_update....
blocks['982_1']['switch'] = true;
blocks['982_1']['last_update'] = false;
blocks[1025] = {}
blocks[1025]['title'] = 'Zolder radiator';
blocks[1025]['hide_data'] = true;
blocks[1025]['switch'] =true;
blocks[1025]['width'] = 3;
blocks[1025]['last_update'] = false;
css
/* .block_982 .fa-bolt.on {color: red;} WERKT NIET */
/* .block_982 .fa-bolt.off {color: lightgrey;} WERKT NIET*/
/* .block_982_1 .icon.on {color: red !important;} WERKT NIET */
/* .block_982_1 .icon.off {color: red !important;} WERKT NIET */
/* .fa-bolt.on {color: red !important;} WERKT NIET*/
/* .fa-bolt.off {color: green !important;} WERKT NIET*/
/* .fas.fa-bolt.on {color: red !important;} WERKT NIET*/
/* .fas.fa-bolt.on {color: green !important;} WERKT NIET*/
Lokonli
Post by Lokonli »
pvklink wrote: Monday 08 July 2019 16:07 noop, still does not work..
blocks[1025] = {}
css
If you want to change the icon color for block 982_1 add the following to custom.css:
.block_982_1 .col-icon {
If device 982 is a power measurement device then it doesn't have a state (like a switch), so it doesn't have the on/off class attached to it.
If you want to change the color depending on the data, then first add a class to the block via the afterGetDevices() function in custom.js:
function afterGetDevices(){
	var device = alldevices['982'];
	console.log(device);
	var usage = parseFloat(device['Usage']);
	console.log(usage);
	if( usage >20){
		$('div.block_982_1').addClass('warning');
	 else {
		$('div.block_982_1').removeClass('warning');
And to apply the right styling add the following to custom.css to change the color of the icon:
.warning .col-icon {
    color: blue !important
In the example above I assumed the measured data is reported via the 'Usage' parameter. You might have to change this to another parameter, depending on the specific device you have. The two console.log statements will show the device info In the developer window of Chrome (press F11). You can use this to find the right parameter name.
If it's working you can remove the two console.log statements.
pvklink
Post by pvklink »
when i arrive on my holiday address..i am going to try it..thanks!
