neo coolcam motion sensor with temp sensor, unknown in domoticz
tonbor
Re: neo coolcam motion sensor with temp sensor, unknown in domoticz
Post by tonbor »
How to……
put the file in the directory
poudenes
Domoticz version: 3.8993
Post by poudenes »
tonbor wrote: Thursday 04 July 2019 9:24 How to……Directory.jpg
But you also need to edit the manufacturer_specific.xml
<Product type="0003" id="108d" name="Battery Powered PIR Sensor V2" config="shenzen_neo/nas-pd02z.xml"/> <!-- pd02z.xml -->
to
<Product type="0003" id="108d" name="Battery Powered PIR Sensor V2" config="shenzen_neo/nas-pd02ze.xml"/> <!-- pd02z.xml -->
tonbor
Post by tonbor »
Change the manufacturer
manufacturer_specific.xml .jpg (326.05 KiB) Viewed 2057 times
tonbor
Post by tonbor »
Just add a "E" with the name, see picture, config="shenzen_neo/nas-pd02ze.xml"
tonbor
Post by tonbor »
That's it, but problem with ozw 1.6 -> 2019-07-04 09:09:03.438 Error: OpenZWave: Value_Changed: Tried adding value, not succeeded!. Node: 5 (0x05), CommandClass: ALARM, Label: Previous Event Cleared, Instance: 1, Index: 256
but there is work to do voor domoticz team, see other subject about this https://www.domoticz.com/forum/viewtopi ... =6&t=28308
with an new update of domoticz you have to change manufacturer_specific.xml again, I can not help that……….
Openzwave [openzwave] open-zwave Commit: Add support for "temperature" model of NAS-PD02Z https://github.com/OpenZWave/open-zwave/issues/1866
poudenes
Post by poudenes »
Im stay on this version:
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
Go change the line, add the xml, remove my devices, restart Domoticz, add devices again. Then I can turn off LED and do some fine tuning for light.
tonbor
Post by tonbor »
poudenes wrote: Thursday 04 July 2019 9:40 Im stay on this version:
Version: 4.10717
That will work too………, but with the new xml all other index number are correct, including 99
tonbor
Post by tonbor »
And always after this restart Domoticz, start adding a zwavedevice (NO exclude first) and 3x push the device button. The device will be added with the same id number and the new config settings!
tonbor
Post by tonbor »
tonbor wrote: Thursday 04 July 2019 9:43
Version: 4.10717
no remove, stay with the same id number.
renerene
Post by renerene »
temperature resolution update is now at 0.5 degree. ANy way to make the interval less?
tonbor
Post by tonbor »
Well ozw has fixed the config two days ago. index 10 and 11 has different functions according to the version of the pir hardware, with or without temperature. Now domoticz has to pickup this new xml
tonbor
Post by tonbor »
you can download it here
https://github.com/OpenZWave/open-zwave ... henzen_neo , put NAS-PD02Z.xml in the directory domoticz/config/shenzen_neo/ overwriting the existing one. Restart domoticz, include your pir again, do NOT exclude it first, thats all
mauricevw
Post by mauricevw »
Does somebody already use the latest Neo Coolcam Sensor(NAS-PD03Z Battery Powered PIR Sensor V2+) which uses the nas-pd03z.xml? I have included the sensor and it recognizes all the sensors. However when I try to change some of the config nothing works. Pushing buttons on the sensor doesn't make changes.It resets back to the default and sometimes after changing some settings, random settings are used.
Looking forward to some feedback and hopefully a solution
