- switch the device on and off.
- measure, in regular intervals, the power (W), energy (Wh), voltage (V), current (mA).
- The homematic IP system used is a RaspberryMatic operating system running the HomeMatic Central-Control-Unit (CCU).
- The CCU has the additional software XML-API CCU Addon installed.
- Communication between Domoticz and the CCU is via HTTP XML-API requests with HTTP XML response.
- Read or download here.
This is my first attempt (learning) to create a Domoticz plugin for a HomeMatic device connected to a CCU (RaspberryMatic) - not easy must say.
There might be better ways, but so far this solution is working ok ... and will be refined whilst working on next devices (i.e. HMIP-eTRV-2 ...).
Any hints appreciated.
In progress
To add as a function in my Domoticz Home Automation Workbook.
