Sunset light switch does not work
jellex87
Post by jellex87 »
I’m very new to Domoticz and Blockly, so can anyone tell me why this script isn’t working?
jellex87
Re: Sunset light switch does not work
Post by jellex87 »
‘Sunset actief’ is a dummy switch that turns on at sunset.
Treve
Domoticz version: v4.11474
Post by Treve »
Try, if time = sunset then .......
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
jellex87
Post by jellex87 »
allready tried this one, but does not work as well.
jellex87 wrote: Friday 28 June 2019 13:43 allready tried this one, but does not work as well.
  • Time = sunset
is only valid one minute a day. So if you want this to be true after sunset then try this.
impuls
impuls
jellex87
Post by jellex87 »
waaren wrote: Friday 28 June 2019 14:15
  • Time = sunset
Allready tried it... does not work. Is the script good?
jellex87 wrote: Friday 28 June 2019 14:23 [Already tried it... does not work. Is the script good?
You should also look where the AND is placed. In your first post it is in the wrong place.
If you can share the exported blockly I can test
jellex87
Post by jellex87 »
waaren wrote: Friday 28 June 2019 14:58
Googled for it, but can't find the way to export the Blocky. Please let me know.
jellex87 wrote: Friday 28 June 2019 15:46 can't find the way to export the Blocky. Please let me know.
Press the export button, [ctrl]a, [ctrl]c, goto forum, [ctrl] v, strip garbage before <xml, strip out last line (Ok)
Impuls export
Impuls export
jellex87
Post by jellex87 »
Don't have that menu on Synology. I will look for an update first.
jellex87 wrote: Friday 28 June 2019 16:04 Don't have that menu on Synology. I will look for an update first.
You could use the time in between to split-up the Blockly.
So create a small Blockly where you only check if time > sunset and write something to the log and a second small blockly where you check the other condition and write something to the log. If they both work you can try with an AND between the two conditions.
