Zwave Aeotec in domoticz
remko2000
Post by remko2000 »
I have an raspberry with domoticz 4.10717. I have also an zwave dongle (Aeotec) and 3 Aeotec doorsensor recessed version 5.
I don't get it work. First I thougt it was a conflict on my USB-port and my RFlink. So I did a clean install of domoticz on an other raspberry dedicated for my Zwavesensors and nothing else. I reset my dongle serveral times and also reset my doorsensors. I also excluded and included them. Now I succeded to add one sensor but I don't get the status in domoticz (last seen stays the date which I add the sensor). I read somewhere I have to switch the report type. I try to change it in domoticz and also in the Zwave control panel. On both I dont't get the status switched from basic set to binary report. In the Zwave control panel I do see the status switchs from open tot close and back.
My domoticzlogs says:
2019-06-24 10:13:56.438 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2019-06-24 10:13:56.442 OpenZWave: Value_Added: Node: 2 (0x02), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2019-06-24 10:13:56.017 Status: PluginSystem: Entering work loop.
2019-06-24 10:13:56.214 Status: OpenZWave: using config in: /home/pi/domoticz/Config/
2019-06-24 10:13:56.239 Status: OpenZWave: Starting...
2019-06-24 10:13:56.239 Status: OpenZWave: Version: 1.4-3335-g74e05982-dirty
2019-06-24 10:13:56.426 Status: OpenZWave: Driver Ready
2019-06-24 10:13:59.454 Status: OpenZWave: Received timeout notification from HomeID: 3350397246, NodeID: 2 (0x02)
2019-06-24 10:13:59.598 Status: OpenZWave: Awake Nodes queried
2019-06-24 10:14:48.535 Status: OpenZWave: Heal Node command initiated for node: 2 (0x02)...
In domoticz I see a green check mark at the zwave dongle en at the doorsensor I see a moon (sleeping status). The sensor don't wake up.
I'm stuck and I don't know what I can do to solve this problem. I read there where Zwave issues in domoticz but in the previous version of domoticz everythings works Ok. I don't want to downgrade anymore.
remko2000
Re: Zwave Aeotec in domoticz
Post by remko2000 »
I've updating to domoticz 10915 (beta) but no improvement. I can add zwave devices but the doorstatus isn't changing in domoticz. I can't change the field basic set tot binary. Domoticz says my sensors are 'sleeping' .
I also see a note in domoticz under hardware/zwavestick: ' Not all Nodes have been interviewed, OpenZWave has not yet been fully initialized!'
roblom
Post by roblom »
Did you solve this? If yes, how because I have the same problem.
