How can I activate a door solenoid for 30 sec? Topic is solved
kxtronic
Post by kxtronic »
I have Domoticz running for a couple of months already and the light in our living room turns on relative to sunset and turns off at 23:00. My system runs on a Raspberry and the light is controlled by a GPIO pin that connects to a relay that switches AC power on/off to the lamp. Very nice :-)
Now I would like to create a switch (or another object) to activate a door solenoid for 30 secs. I would use another GPIO pin with a relay that switches power to the solenoid. Ideally I would go to Domoticz using my mobile or laptop, click on a switch in the dashboard and the solenoid would activate for 30 sec and then turn off by itself.
I have been googling and reading forum posts but could not find an answer to this problem.
Any suggestions?
kxtronic
Re: How can I activate a door solenoid for 30 sec?
Post by kxtronic »
Solved!
It is so easy that I didn't see it...
Just set the On Delay of the switch to 0 and the Off delay to 30 (or whatever).
I had wrongly assumed that the "Off delay" meant go off x seconds after the command.
