Domotics touchscreen remote
ledfreak3d
Domoticz version: 3.8025
Re: Domotics touchscreen remote
Post by ledfreak3d »
I can help you with that send me an email and ill help you to get it working
Unleashe the magic smoke ;)
ledfreak3d
basicly you can make the gui anything you like its not to hard to customize
but realy need some extra hands to get it the way i want.
might port it to the esp32 so it can go into very low power consumption mode
with a full charge i can keep it running for 14 hours but prety sure i cna get a lot more out of it
dozen
Post by dozen »
I have 3d Printed a case and its connected and working :)
I have renamed the buttons that i use and now i wanted to do some more changes in the Nextion Editor.
But i dont know to update on the Nextion.
After i made some changes like renaming a button, i click on compile and it says succesful with no errors.
Then i click upload(its com3) and there is: Connection Failed, Forced interrupt!
Dont know what im doing wrong....
Gesendet von iPhone mit Tapatalk
dozen
Post by dozen »
Found it
I must use the tft File not the hmi
ledfreak3d
Yep thats correct
ackcsaba
Post by ackcsaba »
Hello!
I have a little problem .
It only works correctly when I load the firmware. As soon as I restart the D1 mini it seems as if it would not find a Wifi network (No SSID and No IP text will appear on the home screen). If I refill the firmware again, the correct SSID and IP address will appear as well as the switches react.
Please help!
Thanx
Best Regards
Csaba
ledfreak3d
That should not be to hard to fix ive not seen that issue before yet
