Alexicz - FREE Domoticz to Alexa Integration
Alexa, Google Home and Siri
abaratian
Domoticz version: 2021.1
Re: Alexicz - FREE Domoticz to Alexa Integration
Post by abaratian »
I Followed the very well written documment to create the alexa skill. When i test the script in the website it is OK. I can discover devices and read temperature sensor but. when i add the skill on my phone it doesn't discover any devices. any help?
philchillbill
Post by philchillbill »
Sounds like a region vs locale issue. Alexa discovers devices for the ARN location linked to the Amazon store account of the echo in use. So e.g. if you are in Germany and your store is Amazon.de, the ARN for discovery is EU-west-1 (Ireland). If your skill was created with US-east-1 and is en-US, you will not discover any devices. Hope that's clear.
abaratian
Post by abaratian »
philchillbill wrote: Saturday 25 May 2019 9:19 Sounds like a region vs locale issue. Alexa discovers devices for the ARN location linked to the Amazon store account of the echo in use. So e.g. if you are in Germany and your store is Amazon.de, the ARN for discovery is EU-west-1 (Ireland). If your skill was created with US-east-1 and is en-US, you will not discover any devices. Hope that's clear.
Hi, my arn is eu-west-1 and my location is sweden. I also checked my amazon account country and it is set to sweden. I also tried with arn us-west-2 and account location set to us. still no luck
philchillbill
Hmm. Do you work with room plans? Only devices in room plans are discovered. If you don’t use them then a tiny change to the Python is necessary.
abaratian
Post by abaratian »
philchillbill wrote: Saturday 25 May 2019 18:45 Hmm. Do you work with room plans? Only devices in room plans are discovered. If you don’t use them then a tiny change to the Python is necessary.
yes, i use room plans. as i said in my first post when i run the test discovery script in the lambda management console it works fine and it discovers my devices. i also tried to read a temp sensor and the value was right. the problem is with the alexa not discovering the devices when i add the skill.
abaratian
Post by abaratian »
Hi again,
It was a region issue indeed! Curiously enough, for me, it only works when region is set to N. Virginia!! I had to try possible combinations to make it work.
Does anyone know how can I query status of a device or switch? I can see a light is 'Off' or a door is 'Closed' by tapping on the device in the alexa app. But when i ask her what's the status of the DEVICENAME? Or is the DEVICENAME open? or is DEVICENAME on? It doesn't work and alexa replies DEVICENAME doesn't support that. How can i make it work?
Another thing is that when i ask alexa what is the temperature inside, the temperature she says is around 5 degrees less than the average temperature of my sensors. (i.e. all my sensors are in the 24.x range and she reports a temp in 19.x range.) My thermostat is set at 24.5 now. (Just to clarify that is not what she reports)
philchillbill
It's not mentioned in the Amazon docs and it took me a long time to find it, but querying state ("Alexa, is the front door open?") only works when the endpoint device in question has the Alexa.EndpointHealth interface included during discovery.
In AlexaSmartHome.py, you need to paste:
@INTERFACES.register('Alexa.EndpointHealth')
class AlexaEndpointHealth(AlexaInterface):
    def name(self):
        return 'Alexa.EndpointHealth'
    def propertiesSupported(self):
        return [{'name': 'connectivity'}]
and in the code for the method serializeProperties, add the line
  if prop_name == 'connectivity': prop_value = { 'value': 'OK' }
in DomoticzHandler.py, add this line to the __init__ for class Domoticz (it then gets added to all endpoints):
  self.addCapability(AlexaEndpointHealth(self, 'Alexa.EndpointHealth',[{'name': 'connectivity'}]))
Now re-discover devices and state-querying should work. I've asked Amazon to update their docs with this.
Note that you cannot request the state of a switch as it's simply not (yet) supported by Alexa. Querying only works for devices of type Alexa.ContactSensor and Alexa.MotionSensor.
Regarding your thermostat temperature reporting, take a look in the Cloudwatch logs to see if you can debug. In DomoticzHandler.py the getProperty method has a test "elif prop == 'temperature'" and whatever that is returning must be incorrect.
abaratian
Post by abaratian »
philchillbill wrote: Thursday 13 June 2019 10:15 It's not mentioned in the Amazon docs and it took me a long time to find it, but querying state ("Alexa, is the front door open?") only works when the endpoint device in question has the Alexa.EndpointHealth interface included during discovery.
    def name(self):
THANKS A MILLION!
just adding addCapability to Domoticz class raises error. I added it to ContactSensor part and worked fine.
checking cloudwatch logs shows that when asked for "temperature inside" alexa polls every temp sensor and thermostat in home and calculates average temp. any ideas how can i prevent thermostats from being included in average temp calculation?
philchillbill
Glad that worked. Yes, when you ask for the 'inside' temperature all your temp sensors are averaged, You can of course just ask for one specific location such as Livingroom and then you will just get that.
If you want to actually omit a thermostat during the discovery process (or any device in fact) you can put the following code in the discovery loop just under the for device in devices statement in DomoticzHandler.py
            matchObj = re.match( r'.*no_alexa', device['Description'], re.M|re.I|re.DOTALL)
            if matchObj:  continue
Now, if you have the text no_alexa in the Domoticz device description field, that device will be skipped during discovery. I personally use this approach instead of limiting to discovering devices in roomplans as I don't use roomplans myself.
Similarly, you can skip certain categories of Domoticz devices you'd never want Alexa to interface with (such as your P1 meter) with an array of types as follows:
            devType = device['Type']
            if devType in (''General', 'Lux', 'P1 Smart Meter', 'RFXMeter', 'Temp + Humidity', 'Usage'): continue
abaratian
Post by abaratian »
philchillbill wrote: Saturday 15 June 2019 20:45 Glad that worked. Yes, when you ask for the 'inside' temperature all your temp sensors are averaged, You can of course just ask for one specific location such as Livingroom and then you will just get that.
I use room plans and i have an "alexa" room plan that i have all my alexa devices in it. The problem is I want to use these thermostats with alexa (i have 3, 2 are dummy ones i use to control my IR controlled ACs so that when i set the thermostat to 23 an event is triggered and the IR code for 23 degrees is sent to AC and they are usually set to 0. I'm using thermostats instead of selector switches because they are not usable with alexa ). Is there a way to exclude thermostats from average temp calculations? Is there an actualTemp property for thermostats in domoticz? And will alexa read it? So i can update it with my average temp.
philchillbill
Nope, there's no way to influence the average calculation - it's just something she does 'herself'. You could 'fool' her as to what temp to use for a specific device. If device name == whatever then return fake value instead of actual value read from Domoticz. Play around with the code for the getProperty method in DomoticzHandler.py.
chrispazz
Post by chrispazz »
Hi, after first setup I added more switches in Domoticz but they are not visible in domoticz.
How to update Alexa devices to get new switches?
ty
philchillbill
Say “Alexa, discover devices”. If you didn’t put them in the correct room plan, they will not appear either.
chrispazz
Post by chrispazz »
I did not have a specific room id, (-1).
In first setup it discovered all my devices.....
philchillbill
No idea what it might be. Did you try to disable the skill, then re-enable and rediscover devices? Might help.
chrispazz
Post by chrispazz »
Yes I did but no luck....
chrispazz
Post by chrispazz »
Ok, for Alexics no roomplan is different from any roomplan.
I added it to a roomplan and now the device has been discovered!
philchillbill
You can easily change that in the code if it’s not what you want...
grasuoare
Post by grasuoare »
Hi there!
Thank you for this integration. It works like a charm!
Could you please tell me if it is possible to use it with pivpn? If yes, how?
Thank you!
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
At the beginning I get problems. When I want create a Security Profile I always get a message:
Invalid security profile
What can that be?
