http command
Sagitarius
http command
As you can add multipple devices to a scene, would be great to have also the option to add multipple http commands
- Egregius
- Domoticz version: v2024.7
Re: http command
Put them in a script and execute that script.
Sagitarius
dzvents openURL command domoticz
Hi All,
I'm trying to get PV information from Benning device via dzvents into domoticz.
The IE http command like "http://<IP PV>/getentry.cgi?&oid=10" works fine.
Result e.g.
"oid" : 10,
"label" : "UserConfig.Inverter.Info.SystemName", "type" : "S",
"val" : "PVINV110",
"uitext" : "System name", "savetype" : 1,
"factor" : 1.000000, "unit" : "", "portal" : 1,
"AutoZero" : 0,
"fb" : 1
but to be honest, I have no clue how the dzvents "openURL" command should look like
Anyone out there to help ?
Many thanks
Rgds
Sagitarius
Result e.g.
"oid" : 10,
"val" : "PVINV110",
"AutoZero" : 0,
"fb" : 1
Many thanks
Rgds
Sagitarius
Sagitarius
Re: http command
Hi Rob,
thanks, I had a view on this but the 2nd part, looks like, is a bit complex for me yet.
That's what I have so far
Log:
Original :
Any further detailed information is really appreciated
Many thanks
Rgds
Paul
timer = {'every 1 minutes'},
httpResponses = { 'oid' }
execute = function(dz, item)
if (item.isTimer) then
dz.openURL({
url = 'http://192.168.178.20/getentry.cgi?&oid=10',
method = 'GET',
callback = 'oid',
if (item.isHTTPResponse) then
if (item.ok) then
local pv_data = dz.utils.toJSON(item.data)
dz.log('PVSW30 ' .. pv_data, dz.LOG_ERROR)
dz.log('PVSW30 not OK', dz.LOG_ERROR)
}Code: Select all
2021-05-11 16:57:00.621 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2021-05-11 16:57:01.082 Status: dzVents: Info: Handling httpResponse-events for: "oid
2021-05-11 16:57:01.082 Status: dzVents: Info: ------ Start internal script: PVSW30 dz: HTTPResponse: "oid"
2021-05-11 16:57:01.086 Status: dzVents: Error (2.4.19): PVSW30 "-1"
2021-05-11 16:57:01.086 Status: dzVents: Info: ------ Finished PVSW30 dz
{ "oid" : 10, "label" : "UserConfig.Inverter.Info.SystemName", "type" : "S", "val" : "PVSW30", "uitext" : "System name", "savetype" : 1, "factor" : 1.000000, "unit" : "", "portal" : 1, "AutoZero" : 0, "fb" : 1 }Many thanks
Rgds
Paul
- waaren
Re: http command
Can you try this one? It is not complete but should point you in the right directionSagitarius wrote: Tuesday 11 May 2021 17:08 thanks, I had a view on this but the 2nd part, looks like, is a bit complex for me yet.
local scriptVar = 'oid'
return
on =
timer =
'every 1 minutes'
httpResponses =
scriptVar,
logging =
level = domoticz.LOG_DEBUG,
marker = scriptVar,
if item.isTimer then
dz.openURL(
method = 'GET',
callback = scriptVar,
elseif item.isHTTPResponse and item.ok then
dz.log('item.data: ' .. item.data, dz.LOG_FORCE)
dz.utils.dumpTable(item) -- only during debug
local pv_data = dz.utils.fromJSON(item.data) -- you want to convert a JSON to a Lua table
dz.utils.dumpTable(pv_data) -- only during debug
Sagitarius
Re: http command
Thanks Waaren, will spend some time over the weekend
Sagitarius
Re: http command
Hi Waaren
that's what I get, but I'm not sure what kind of information would help.
The http command via IE works fine. It collects data from a XML database where I do not have the name from.
But anything I tried so far, the result via openURL would be -1, which means wrong oid no. and the JSON object
is not shown.
2021-05-14 11:38:01.038 Status: dzVents: Info: oid: ------ Start internal script: Script #2: HTTPResponse: "oid"
2021-05-14 11:38:01.038 Status: dzVents: !Info: oid: item.data: -1
2021-05-14 11:38:01.038 Status: dzVents: > isHTTPResponse: true
2021-05-14 11:38:01.038 Status: dzVents: > _contentType: text/html
2021-05-14 11:38:01.038 Status: dzVents: > isGroup: false
2021-05-14 11:38:01.038 Status: dzVents: > isJSON: false
2021-05-14 11:38:01.038 Status: dzVents: > ok: true
2021-05-14 11:38:01.038 Status: dzVents: > statusText: OK
2021-05-14 11:38:01.038 Status: dzVents: > trigger: oid
2021-05-14 11:38:01.038 Status: dzVents: > callback: oid
2021-05-14 11:38:01.038 Status: dzVents: > protocol: HTTP/1.1
2021-05-14 11:38:01.038 Status: dzVents: > isSecurity: false
2021-05-14 11:38:01.038 Status: dzVents: > isTimer: false
2021-05-14 11:38:01.038 Status: dzVents: > data: -1
2021-05-14 11:38:01.038 Status: dzVents: > headers:
2021-05-14 11:38:01.038 Status: dzVents: > Server: Benning Web Server
2021-05-14 11:38:01.038 Status: dzVents: > Content-Type: text/html
2021-05-14 11:38:01.038 Status: dzVents: > Connection: close
2021-05-14 11:38:01.038 Status: dzVents: > isVariable: false
2021-05-14 11:38:01.038 Status: dzVents: > statusCode: 200
2021-05-14 11:38:01.039 Status: dzVents: > isDevice: false
2021-05-14 11:38:01.039 Status: dzVents: > isScene: false
2021-05-14 11:38:01.039 Status: dzVents: > baseType: httpResponse
2021-05-14 11:38:01.042 Status: dzVents: Error (2.4.19): oid: An error occured when calling event handler Script #2
2021-05-14 11:38:01.043 Status: dzVents: Error (2.4.19): oid: /home/pi/domoticz/dzVents/runtime/Utils.lua:182: bad argument #1 to 'pairs' (table expected, got number)
2021-05-14 11:38:01.043 Status: dzVents: Info: oid: ------ Finished Script #2
I could not find a hint in regards to bad argument .......
is not shown.
- waaren
Re: http command
The call only returns -1 so not much to work with. It should return the same information as what comes back if you enter this http in your browser. Can you try to do this from an incognito browser page and post the result?Sagitarius wrote: Friday 14 May 2021 11:58 that's what I get, but I'm not sure what kind of information would help.
Sagitarius
Re: http command
I tested Chrome and Firefox in private mode, Firefox has no problem but Chrome
has problem with oid's below 10000, they are not working but above some.
I did the same test with Domoticz and got the same result like with Chrome.
