However, the bug report is closed with the conclusion of a problem with the libcrypto. Domoticz would require version 1.0 instead of 1.1. I suppose the conclusion comes from the crash report that states:
However when investigating on my RPI, I find that libcrypto1.0 is installed aside libcrypto1.1. See below. So I don't see the issue.Thread 35 (Thread 0x62eff430 (LWP 951)):
#0 0x76db34cc in __waitpid (pid=952, stat_loc=0x62efd5c8, options=0) at ../sysdeps/unix/sysv/linux/waitpid.c:29
#1 0x0010c6a0 in dumpstack_gdb(bool) ()
#2 0x0010cc8c in signal_handler(int, siginfo_t*, void*) ()
#3 <signal handler called>
#4 raise (sig=<optimized out>) at ../sysdeps/unix/sysv/linux/raise.c:51
#5 <signal handler called>
#6 0x69e73794 in RSA_verify () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
#7 0x69e7206c in ?? () from /usr/lib/arm-linux-gnueabihf/libcrypto.so.1.1
Backtrace stopped: previous frame identical to this frame (corrupt stack?)
Don't know how I could force Domoticz using the version 1.0... Of course, I would prefer that my loging, HTTPS, ... keeps on working. After a bit of searching in the forum, I saw that the absence of the libcrypto generates such kind of problems.pi@MyRaspberrypi:/usr/lib/arm-linux-gnueabihf $ ls -al libcrypt*
-rw-r--r-- 1 root root 41292 jan 14 2018 libcrypt.a
-rw-r--r-- 1 root root 1123644 nov 2 2017 libcrypto.so.1.0.0
-rw-r--r-- 1 root root 1497376 mrt 29 2018 libcrypto.so.1.0.2
-rw-r--r-- 1 root root 1827956 mrt 29 2018 libcrypto.so.1.1
lrwxrwxrwx 1 root root 38 jan 14 2018 libcrypt.so -> /lib/arm-linux-gnueabihf/libcrypt.so.1
The plugin that generates the problem is to detect chromecast devices on my network. The plugin itself is also published in the bug report, together with the crash report.
Thanks for your help!
Filip
