Howto update devices and scenes in Controlicz
rgroothuis
I've added some devices and new scenes in Domoticz, how can I get them in Controlicz so that I can control them through the Google Home device?
- gijsje
- Domoticz version: Stable
Re: Howto update devices and scenes in Controlicz
ok google sync my devices
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
rgroothuis
That is a simple solution
Google is after this voice command indicating that the devices are being synced, but I don't see them yet in Controlicz web-site and/or the Google Home App. Do I need to do something else?
Madgeni
double check your Domoticz user has access to the devices (and that the devices are in a Room Plan)
rgroothuis
Thanks, that was the trick, the user didn't had access to the Room Plan. The devices are now visible in the Controlicz web-server.Madgeni wrote: Monday 26 November 2018 17:19 double check your Domoticz user has access to the devices (and that the devices are in a Room Plan)
Next is, how to get them in the Google Home App ? Did some searching, updates but the new devices are not added and the Home App will also not find them when I search for them.
Madgeni
the Home app (and Home Hub) don't currently show Scenes/Groups - however they will be available for voice command, and you can see them on the Google Assistant (if you have it on your phone).
Mads
I have add scenes to Google (working) could see the scenens under settings/home. Could add Them to rooms ect ect ect.
But then i said hey Google sync My devices. And now it it's gone.
The voice command still work, but cant give then "Nick names" anymore :/
Madgeni
Hi there -
can you contact me from your controlicz profile and i'll check for you
competer
Hello, need some help
Added two z-wave switches to Domoticz. They are visible in Controlicz.
But i do not see them in my Google Home app
Use the voice command to sync devices many times
there are 10 types of people in this world, those who understand binary and those who dont
- Varazir
use the help In the Controlicz control panel.competer wrote: Tuesday 09 July 2019 12:37 Hello, need some help
Raspberry PI 4 with RaZberry Controller 2016 ZWave+ and CC2531(zigbee)
Several IKEA devices/z-wave devices
Madgeni
Hi - drop me a note from your profile, and i'll take a look for you asapVarazir wrote: Tuesday 09 July 2019 12:44use the help In the Controlicz control panel.competer wrote: Tuesday 09 July 2019 12:37 Hello, need some help
competer
Madgeni wrote: Tuesday 09 July 2019 13:31 Hi - drop me a note from your profile, and i'll take a look for you asap
Solved, they are visible!
