Pilot: Home Automation Control (iOS app)
- K3rryBlue
- Domoticz version: V4.10xx
Re: Pilot: Home Automation Control (iOS app)
Same here after the update to version 3.0.0, the app crashes when starting up. iPhone6s IOS 12.3. Get a fast glimp of the home screen and then crashes. Removed and reinstalled the application, rebooted iPhone and logged out/in appstore, no succes. It seems related with the connection to Domoticz, Version:https://prnt.sc/nsfs6s. Same issue with previous stable version.
When I kill the 4G and Wifi it starts without a problem, or shutdown domoticz the app works (or starts without crashing)
Domoticz V4.10717, RPi2 -> Linux raspberrypi 4.4.47-v7+ , RFXCOM - RFXtrx433 USB 433.92MHz ,RAZBERRY2 and OpenZWave USB Version: 1.4-2363-g1f10253-dirty
There is something wrong with the way rooms load.K3rryBlue wrote: ↑Thursday 23 May 2019 18:01 Same here after the update to version 3.0.0, the app crashes when starting up. iPhone6s IOS 12.3. Get a fast glimp of the home screen and then crashes. Removed and reinstalled the application, rebooted iPhone and logged out/in appstore, no succes. It seems related with the connection to Domoticz, Version:https://prnt.sc/nsfs6s. Same issue with previous stable version.
That I know. The rest, not so sure yet. I am still trying to find a way to reproduce that bloody bug.
I'll get there tho
Domoticz on iOS: Pilot: Home Automation Control
Hi all.
First of all: Great app! I like the design. Thanks a lot for your efforts.
Have some questions still.
I am using the latest stable domoticz version on a synology. All works and Pilot App finds my domoticz but gets no automatic updates of events. E.g. like when a motion is detected or a switch change state.
Is that normal?
Would it be possible to rename devices in the app? I use longer names within domoticz to easily see which device I am using in scripts but on phone screens those names are too long. Would be great to rename them just locally in the app. That maybe possible with the paid version?
Changing colors and the sorting of the home screen would be great as well. Possible?
When a switch changed status in the app (after I manually reload) I just see it in the switch symbol with the word ‘on’. Possible that this switch icon changes background color or icon when state changed? (Same is for morion detectors).
Thanks a lot.
Is that normal?
Thanks a lot.
- K3rryBlue
Yes thanks for your fast support/reply.patoo77 wrote: ↑Thursday 23 May 2019 22:08There is something wrong with the way rooms load.K3rryBlue wrote: ↑Thursday 23 May 2019 18:01 Same here after the update to version 3.0.0, the app crashes when starting up. iPhone6s IOS 12.3. Get a fast glimp of the home screen and then crashes. Removed and reinstalled the application, rebooted iPhone and logged out/in appstore, no succes. It seems related with the connection to Domoticz, Version:https://prnt.sc/nsfs6s. Same issue with previous stable version.
I'll get there tho![]()
I Will be patient. Now I can at least access the favourites, so i am able to access my switches and some scenes.
When changing tempratures on the slider the app defaults to Farenheit.
Is this a setting somewhere? I'd like to use Celsius notation.
Good find! will have it fixed
Pilot 3.0.1 is available on the App Store.
Update will be automatic if you're willing to wait.
If you're not willing to wait, simply go to the updates tab in the App Store, and grab the update.
More than 50 bug fixes, just give it a try and let me know how it goes.
- gielie
- Domoticz version: latest β
Im a beta user and using TestFlight to install pilot and now I had to reinstall pilot but I don’t have the full version anymore. Is this a bug?
- Aeotec MultiSensor 6
- FIBARO FGS223
- FIBARO FGWPE Wall Plug
- Neo CoolCam Power plug
- Popp Smoke Detector
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
You have to restore the purchase after reinstalling.
That's amazing news!!! Glad I got this bug fixed, it wasn't the easiest to.
@patoo77, have you considered these? Someone else was asking about this tooNautilus wrote: ↑Sunday 05 May 2019 23:45 Hi,
I would like to see utility sensor readings in Pilot to resemble what you see on the Domoticz web UI. For example power consumption meters, counters etc. typically show the daily value. It does not make too much sense to show for example what the total consumption since the beginning of time has been for the house - instead it is interesting to see how much we have consumed today...
edit: and it would also be nice if there could be bar charts / histrograms for those utility types that use it also in Domoticz web UI.
- gielie
Off course i tried that but that doesnt work, noting to restore.
I had this problem before link
I tried to install from appstore and testflight with no luck.
- FIBARO FGS223
- Toon
- Kodi Media Server
- FIBARO FGS223
- Toon
- Kodi Media Server
I Have considered it. Tons of work involved to make something smart out of it, that works for all the kinds of devices that Domoticz supports.Nautilus wrote: ↑Sunday 02 June 2019 23:29@patoo77, have you considered these? Someone else was asking about this tooNautilus wrote: ↑Sunday 05 May 2019 23:45 Hi,
edit: and it would also be nice if there could be bar charts / histrograms for those utility types that use it also in Domoticz web UI.![]()
Same for bar charts/histograms.
The most difficult part is that I don't own every kind of device, so it's hard for me to check how Domoticz handles some kinds of devices.
Just PMed you, we'll figure something out.
Thank you for considering
- Domoticz version: 4.9700
I'm having problems with the geofence function lately.
It worked flawless from the minute i purchased this app, but since the last update(s) it is not reliable anymore.
- mvveelen
Could it be possible to set the "last seen" per device? Or maybe just on the favourites-tab?
RPi3b+/RFXCOM rfxtrx433E/Shelly/Xiaomi Gateway/Philips HUE Lights/Atag Zone One/2 SunnyBoy inverters/AirconWithMe/P1 smartmeter/Domoticz latest Beta
- MadMedic
- Domoticz version: 2020.2
'Same problems here .. even a re-install .. (with a revitalise of the premium functions), did not work.
Testing the notify function with a new code works OK, (yes, the correct code is in domoticz too).
Geofence functions worked flawlesly up to the 3.0. update.
Updates .01, .02 and .03, reboots, etc didn't make any difference .
Already tested the iphone locationsetting for Pilot, is set to 'always'.
I'm lost now. Or better, Pilot looks to have lost sight of me
"Life is too short for bad coffee"
- FearNaBoinne
- Domoticz version: 2021.1
I have 2 iPhones with Pilot on it (mine and my wife).
Geo works fine on mine, doesn't work at all on my wife's...
She is on 12.4 and 3.0.3
I am on 12.1.3 and 3.0.3
RasPi, Raspbian , Domoticz v2021.1, Z-Wave Stick, RFLink, RFXtrx433e, Hue, Tuya (Tasmota/Mosquitto with Discovery), ESP(easy), MySensors.org, OTGW
- MadMedic
Solved it !
Appearantly it was just about deactivating the GSM dummy switch in the devicelist.
Selecting add new devices for 5 minutes from the settingsmenu.
And activating the dummy GSM switch again.
But it remains weird.
MadMedic wrote: ↑Monday 29 July 2019 3:20 'Same problems here .. even a re-install .. (with a revitalise of the premium functions), did not work.
I'm lost now. Or better, Pilot looks to have lost sight of me![]()
- FearNaBoinne
I'll be damned! I tried removing and re-adding the dummy switches for my wife's geo-locations from/to the devicelist and so far it works!
