what is the best practice for dzvents regarding performance.
1 big script with less triggers/timers but with multiple if then tests inside
or
multiple smaller scripts each with their own trigger/timer
for example i have a script which is called every minute to update energy meter devices
inside this script i can do a test if it is the first of the month and if it is call os.execute routine to send telegrams
in this case every minute there is a if then comparison made
i can also let the meter script updating the energy devices every minute and make a seperate script which is only called once a month to os.execute routine to send telegrams
my gut feeling would be the second(seperate) script choice is better.
also if i could choose between
1 script with 1 trigger and 10x if then choices
or
10 scripts with 1 trigger with no if then choices
i do not know which uses more resources, checking the triggers/timers or doing if then's in a script
dzvents performance big script or multiple small ones
poudenes
- Domoticz version: 3.8993
Re: dzvents performance big script or multiple small ones
I created all kind small scripts. Easier to manage
Verzonden vanaf mijn iPhone met Tapatalk Pro
- waaren
+1
Melotron
- Domoticz version: 2020.2
I'm using several smal scripts.
One for each room controlled with different lux. And for leaving the apartment.
And a few other minor one, 14 scripts totally.
Its easy to manage individual and if I mess up a script it's only a smal part off the apartment that gets effected.
Also no big change on performance on my rasp 3b+
Had a rasp b+ up to a year aggo and it was slow as hell.
With alot of blocky scripts too.
I had everything in one long an big script but it was to en cumbersome to work with.
One error and the script was not running.
I even have the living room environment on 1 min timer an going and coming home on different scripts.
But I'm thinking about combining them again.
Try both ways and see how its working for you.
What works for me will probably not work for you LOL
I'm in the middle of a overhaul of my scripts and what was working good for me a yeas aggo looks stupid now lol
Cleaning, organising and adding comments on what they are doing all over the place now.
I'm adding comments on what I should think about the next time I'm going over my scripts too ^_^
//Magnus Svensson.
//Magnus Svensson.
Gravityz
- Domoticz version: 2026.3
ok thanks. that is what i am doing now.
indeed easy to pinpoint problems also but i was worried about the performance
poudenes
I agree with @Melotron. I use 58 scripts to manage my house. Every script have is own function. I can never mess up the rest. Also add sometimes comments so I have some reminders when a script is using something thats also using in a different other script.
Saying that. I also make use of global_data file. Add all my device and give them a nice name so I have always the same device name. When a device is changing (sometimes it will) and get a new IDX. You only have to change that in global_data and all your scripts are working again.
Here a example maybe you love this way, I did and very happy now because of all the 58 scripts. No change everywhere etc:
First is a script so you can see how its build
Second the global_data where all the "helpers" are stored as well
Scene_AppleTV
global_data
Scene_AppleTV
local Version = '2019.05.11'
active = true,
timer = {'at nighttime'},
devices = {[LogitechAppleTV] = { 'at nighttime' }
-- logging = {marker = 'APPLETV Scene ' ..Version..'..........'},
if (domoticz.devices(LogitechAppleTV).active
and not domoticz.devices(SceneAppleTV).active
and not domoticz.devices(SceneGoodnight).active
and (domoticz.devices(iPhonePeter).active or domoticz.devices(iPhoneKay).active))
then
domoticz.helpers.TurnOnScene(domoticz,SceneAppleTV)
domoticz.helpers.TurnOffScene(domoticz,SceneEvening)
domoticz.helpers.TurnOffScene(domoticz,SceneDayTime)
domoticz.helpers.TurnOffScene(domoticz,SceneMovie)
domoticz.helpers.TurnOffScene(domoticz,SceneTV)
domoticz.helpers.TurnOffScene(domoticz,SceneSexy)
domoticz.helpers.TurnOffScene(domoticz,SceneMorning)
domoticz.helpers.TurnOffScene(domoticz,SceneGoodnight)
domoticz.helpers.Disco(domoticz,BulbBalcony1,nil,nil,nil)
-- HALLOWEEN SCENE
if domoticz.helpers.halloween(domoticz) then
domoticz.helpers.RGB(domoticz,BulbLivingroomWall,nil,'Orange',nil)
domoticz.helpers.RGB(domoticz,BulbLivingroomWindow,70,'Orange',nil)
os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -e "Halloween" &')
-- X-MAS SCENE
elseif domoticz.helpers.xmas(domoticz) then
domoticz.helpers.RGB(domoticz,BulbLivingroom1,nil,'Red',nil)
domoticz.helpers.RGB(domoticz,BulbLivingroom2,nil,'Green',nil)
domoticz.helpers.RGB(domoticz,BulbLivingroom3,nil,'Green',nil)
domoticz.helpers.RGB(domoticz,BulbLivingroom4,nil,'Red',nil)
os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -e "Christmas" &')
-- NORMAL SCENE
domoticz.helpers.RGB(domoticz,BulbLivingroomWall,nil,nil,nil)
domoticz.helpers.RGB(domoticz,BulbLivingroomWindow,70,nil,nil)
os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -e "Forest" &')
-- SENSOR DINING ROOM ON
if (domoticz.devices(SensorDiningRoomDoor).active) then
domoticz.helpers.Off(domoticz,BulbDressoirAll)
-- SWITCH KAY LEREN
if (domoticz.devices(SwitchKayLearn).active) then
domoticz.helpers.TurnOn(domoticz,SwitchDiningroom,nil,nil)
elseif (not domoticz.devices(SwitchKayLearn).active) then
domoticz.helpers.TurnOn(domoticz,SwitchDiningroom,50,nil)
--SENSOR DINING ROOM OFF
elseif (not domoticz.devices(SensorDiningRoomDoor).active) then
-- HALLOWEEN SCENE
domoticz.helpers.RGB(domoticz,BulbDressoirAll,50,'Blue',nil)
domoticz.helpers.RGB(domoticz,BulbDressoir2,50,'Purple',nil)
-- X-MAS SCENE
domoticz.helpers.RGB(domoticz,BulbDressoirAll,75,'Blue',nil)
domoticz.helpers.RGB(domoticz,BulbDressoir2,75,'White',nil)
-- KINGSDAY
elseif domoticz.helpers.kingsday(domoticz) then
domoticz.helpers.RGB(domoticz,BulbDressoir1,nil,'Red',nil)
domoticz.helpers.RGB(domoticz,BulbDressoir2,nil,'White',nil)
domoticz.helpers.RGB(domoticz,BulbDressoir3,nil,'Blue',nil)
-- BDAY
elseif domoticz.helpers.bday(domoticz) then
domoticz.helpers.Disco(domoticz,BulbHall1,nil,2,1)
domoticz.helpers.Disco(domoticz,BulbDressoir1,nil,1,2)
domoticz.helpers.Disco(domoticz,BulbDressoir2,nil,1,3)
domoticz.helpers.Disco(domoticz,BulbDressoir3,nil,1,4)
-- NORMAL SCENE
domoticz.helpers.Kelvin(domoticz,BulbDressoirAll,50,nil,nil)
-- SWITCH KAY LEREN OFF
os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -b 50')
os.execute('/home/pi/domoticz/scripts/Peter/speech.sh "The scene AppleTV is activated"&')
-- domoticz.log('------------------------==<[ Scene AppleTV ]>==-----------------', domoticz.LOG_FORCE)
- VERSION 2019.01.25
-- RGB (domoticz,idx,dim,color,sec) (domoticz,idx,100,'white',0)
-- Kelvin (domoticz,idx,dim,kelvin,sec) (domoticz,idx,100,5000,0)
-- Disco (domoticz,idx,dim,disco,sec) (domoticz,idx,100,6,0)
-- TurnOn (domoticz,idx,dim,sec) (domoticz,idx,100,0)
-- TurnOff (domoticz,idx,dim,sec) (domoticz,idx,5,1)
-- TurnOnScene (domoticz,idx)
-- TurnOffScene (domoticz,idx)
-- Effect (domoticz,idx,level,sec) (domoticz,idx,30,0)
-- OnDelay (domoticz,idx,sec) (domoticz,idx,15)
-- OffDelay (domoticz,idx,sec) (domoticz,idx,15)
-- QuietOn (domoticz,idx)
-- QuietOff (domoticz,idx)
-- https://snipplr.com/view/40782/color-to-rgb-value-table-in-lua/
-- https://professorcook.org/lua/colorchart.gif
------------------------------ SLAAPKAMER
BulbMasterBedroomAll = 578
BulbMasterBedroom1 = 540
BulbMasterBedroom2 = 541
BulbMasterBedroom3 = 542
BulbMasterBedroom4 = 543
BulbMasterBedroom5 = 551 -- LEFT for sleeping scene
BulbMasterBedroom6 = 552 -- RIGHT for sleeping scene
------------------------------ BALCONY
BulbBalcony1 = 589
------------------------------ DRESSOIR
BulbDressoirAll = 601
BulbDressoir1 = 602
BulbDressoir2 = 603
BulbDressoir3 = 604
------------------------------ HALL
BulbHall1 = 484
------------------------------ LIVINGROOM
BulbLivingroomAll = 477
BulbLivingroom1 = 478
BulbLivingroom2 = 479
BulbLivingroom3 = 481
BulbLivingroom4 = 480
BulbLivingroomWall = 614
BulbLivingroomWindow = 615
------------------------------ BATHROOM
BulbBathroomAll = 528
BulbBathroom1 = 529
BulbBathroom2 = 530
BulbBathroom3 = 531
BulbBathroom4 = 532
------------------------------ KITCHEN
BulbKitchenAll = 506
BulbKitchen1 = 507
BulbKitchen2 = 508
BulbKitchen3 = 509
------------------------------ KITCHEN SINK
BulbKitchenSinkAll = 517
BulbKitchenSink1 = 518
BulbKitchenSink2 = 519
BulbKitchenSink3 = 520
------------------------------ TOILET
BulbToiletAll = 561
BulbToilet1 = 562
BulbToilet2 = 563
BulbToilet3 = 564
------------------------------ LOGITECH DEVICES
LogitechOff = 26
LogitechAppleTV = 27
LogitechTV = 28
LogitechKodi = 30
LogitechIPTV = 622
------------------------------ IPHONE DEVICES
iPhonePeter = 414
iPhoneKay = 415
iBeaconPeter = 748
iBeaconKay = 741
------------------------------ SCENES
SceneDayTime = 36
SceneEvening = 37
SceneTV = 38
SceneMovie = 39
SceneAppleTV = 40
SceneSexy = 41
SceneMorning = 42
SceneGoodnight = 43
SceneDisco = 639
SceneSleeping = 245
------------------------------ SWITCHES
SwitchKayLearn = 35
SwitchBalcony = 59
SwitchDressoir = 60
SwitchWall = 61
SwitchWindows = 62
SwitchHall = 63
SwitchToilet = 567
SwitchKitchen = 65
SwitchKitchenSink = 66
SwitchCooker = 249
SwitchDiningroom = 70
SwitchBedroom = 71
SwitchBathroom = 74
SwitchHoliday = 680
SwitchNightLight = 679
SwitchEnablePresence = 467
SwitchTEST = 193
------------------------------ SENSORS
SensorMasterBedroom = 709
SensorMasterBedroomDoor = 730
SensorDiningDoor = 76
SensorDiningRoomDoor = 719
SensorKitchen = 77
SensorHall = 469
SensorWC = 701
------------------------------ NEST
Nest = 689
------------------------------ OTHER
LuxDiv = 392
OutsideTemp = 394
IPTVStatus = 708
KodiStatus = 99
------------------------------ COMBINATION ACTIONS
local COLORS = {
['White'] = {255,225,255},
['Red'] = {255,50,1},
['Blue'] = {12,0,179},
['Orange'] = {255,127,1},
['Yellow'] = {255,255,1},
['Green'] = {150,255,142},
['Purple'] = {146,66,244},
['LightGreen'] = {191,255,114},
['Romantic'] = {128,0,1}
helpers = {
xmas = function(domoticz) return domoticz.time.matchesRule('on 01/12-05/01') end,
halloween = function(domoticz) return domoticz.time.matchesRule('on 23/10-4/11') end,
bday = function(domoticz) return domoticz.time.matchesRule('on 11/05,19/08') end,
kingsday = function(domoticz) return domoticz.time.matchesRule('on 27/04') end,
restyear = function(domoticz) end,
RGB = function(domoticz,idx,dim,color,sec)
if (dim == nil) then dim = 100 end
if (color == nil) then rgb = COLORS['White'] else rgb = COLORS[color] end
if (sec == nil) then sec = 0 end
domoticz.devices(idx).setRGB(rgb[1], rgb[2], rgb[3]).afterSec(sec)
domoticz.devices(idx).dimTo(dim).afterSec(sec)
status = 'aangezet'
movement = 'beweging gedecteerd'
end,
RGBON = function(domoticz,idx,dim,color,sec)
status = 'aangezet'
end,
Kelvin = function(domoticz,idx,dim,kelvin,sec)
if (kelvin == nil) then kelvin = 4000 end
domoticz.devices(idx).setKelvin(kelvin).afterSec(sec)
status = 'aangezet'
end,
Disco = function(domoticz,idx,dim,disco,sec)
if (disco == nil) then disco = 1 end
domoticz.devices(idx).setDiscoMode(disco).afterSec(sec)
status = 'aangezet'
end,
TurnOn = function(domoticz,idx,dim,sec)
if (dim == nil) then dim = 99 end
status = 'aangezet'
end,
TurnOff = function(domoticz,idx,dim,sec)
if (dim == nil) then dim = 5 end
if (sec == nil) then sec = 1 end
domoticz.devices(idx).switchOff().afterSec(sec)
status = 'uitgezet'
movement = 'geen beweging gedecteerd'
end,
TurnOnScene = function(domoticz,idx)
domoticz.devices(idx).switchOn().checkFirst()
status = 'aangezet'
end,
TurnOffScene = function(domoticz,idx)
domoticz.devices(idx).switchOff().checkFirst()
status = 'uitgezet'
end,
OnDelay = function(domoticz,idx,sec)
domoticz.devices(idx).switchOn().afterSec(sec)
status = 'aangezet'
end,
OffDelay = function(domoticz,idx,sec)
status = 'uitgezet'
end,
On = function(domoticz,idx)
status = 'aangezet'
end,
Off = function(domoticz,idx)
status = 'uitgezet'
end,
QuietOn = function(domoticz,idx)
domoticz.devices(idx).switchOn().quietOn()
status = 'aangezet'
end,
QuietOff = function(domoticz,idx)
domoticz.devices(idx).switchOff().quietOn()
status = 'uitgezet'
end,
}RPi3 B+, Debain Stretch, Domoticz, Homebridge, Dashticz, RFLink, Milight, Z-Wave, Fibaro, Nanoleaf, Nest, Harmony Hub, Now try to understand pass2php
Gravityz
Very impressive.
if that is working then the few routines i have i global_data will fly.
