Variable fails in Code
Opus
Post by Opus »
a short code and my big problem. I use the variable 'stufe' for memory the step of thunderstorm levels. I get the 4 levels as bit code from 2 switches, connected to a lighning sensor.
If the Ligntning approaching the messages are warnings, downwards changed to 'departure'.
But the variable 'stufe' falls everytime back to '0' between the steps. In that case the code will never work.
How may I store the value of stufe in a secure methode?
Gewitter = 'AUS'
local stufe =0
gemeldet = 0
debug = 1
 --if (gemeldet == nil) then gemeldet = 0 end
 --if (stufe == nil) then stufe = 5 end
 --if (Gewitter == nil) then Gewitter = 'AUS' end
-- Set value of Gewitter AUS, GRÜN, GELB, ROT from bit code:
if     (otherdevices['Gewitter Bit 0'] == "On") and (otherdevices['Gewitter Bit 1'] == "On") then Gewitter = 'AUS'
elseif (otherdevices['Gewitter Bit 0'] == "Off") and (otherdevices['Gewitter Bit 1'] == "On") then Gewitter = 'GRÜN'
elseif (otherdevices['Gewitter Bit 0'] == "On")  and (otherdevices['Gewitter Bit 1'] == "Off") then Gewitter = 'GELB'
elseif (otherdevices['Gewitter Bit 0'] == "Off") and (otherdevices['Gewitter Bit 1'] == "Off") then Gewitter = 'ROT'
if (Gewitter =='AUS') and (gemeldet == 0) then
    commandArray['UpdateDevice'] = "685|0|Keine Wetterwarnung"
    stufe = 0
    gemeldet = 1
if (Gewitter == 'AUS') and (stufe == 1) then
    commandArray['UpdateDevice'] = "685|0|Gewitter sind abgezogen"
    stufe = 0
if (Gewitter == 'GRÜN') and (stufe == 0) then
    commandArray['UpdateDevice'] = "685|0|Wetterwarnung: Kommende Gewitter in 30-100 km Entfernung!"
    stufe = 1
if (Gewitter == 'GRÜN') and (stufe == 2) then
    commandArray['UpdateDevice'] = "685|0|Abziehendes Gewitter in ca. 30km Entfernung!"
    stufe = 1
if (Gewitter == 'GELB') and (stufe == 1) then
    stufe = 2
    commandArray['UpdateDevice'] = "685|0|Wetterwarnung: Kommende Gewitter in ca. 10km Entfernung!"
    commandArray['Markise'] = 'On'
if (Gewitter == 'GELB') and (stufe == 3) then
    commandArray['UpdateDevice'] = "685|0|Abziehendes Gewitter in ca. 10km Entfernung!"
    stufe = 2
if (Gewitter == 'ROT') and (stufe ==2) then
    commandArray['UpdateDevice'] = "685|0|Wetterwarnung: Örtlich wirkendes Gewitter!!!"
    commandArray['SendNotification']='Lokales Gewitter!!!'         -- Meldung an Handys
    stufe = 3
if (debug == 1) then
--print ('gemeldet:'..tostring(gemeldet))
--print ('stufe:'..tostring(stufe))
--print ('Gewitter:'..tostring(Gewitter))
