Time how much a device is ON  [Solved]
16pxdesign
Post by 16pxdesign »
Hi, I want to achieve this effect using dzVents
https://www.domoticz.com/forum/viewtopic.php?t=18848
I don't know how to set time for this counter, there is no problem when the counter is just counter but when I change it to time version I have a problem. Can anybody help?
Re: Time how much a device is ON
16pxdesign wrote: Friday 03 May 2019 2:52 Hi, I want to achieve this effect using dzVents
Can you please explain in more detail what you try to achieve and what the problem is you face ? For me it's unclear from the above description and after reading the topic.
16pxdesign
Ok so I have dummy counter and I set the counter in Domoticz as time counter. When I try to use a method "updateCounter()" and pass any number it not change any state of this counter. This method works for the normal counter but doesn't want to work with a time counter. So my question is how I can set time counter values in dzVents
16pxdesign wrote: Friday 03 May 2019 19:25 Ok so I have dummy counter and I set the counter in Domoticz as time counter. When I try to use a method "updateCounter()" and pass any number it not change any state of this counter. This method works for the normal counter but doesn't want to work with a time counter. So my question is how I can set time counter values in dzVents
Ok understand now but have to disappoint you. It cannot be done from dzVents. In fact I asked the core developers some time ago how to update this from the API and no one could give me an answer. So either the developer that introduced this (maybe for future use) is no longer developing here or it is a left over from the past.
But if you tell what is it that you want to measure, I might be able to help using another solution than a time counter.
16pxdesign
OK, Good to know, thanks. I got 3 heaters but I need to know how long they work in minutes or hours. I know you got logs but it hard to read total time it been ON or OFF.
16pxdesign wrote: Friday 03 May 2019 23:43 OK, Good to know, thanks. I got 3 heaters but I need to know how long they work in minutes or hours. I know you got logs but it hard to read total time it been ON or OFF.
How do you want to record the heaters on time ?
Could be stored in a domoticz variable, a counter device per heater, One or more text devices, stored in the description field of these heaters and probably in a couple of other ways.
felix63
Domoticz version: 2020.1
Post by felix63 »
I have a similar use case. When a device is switched off I want to update a virtual device - (timer) counter so I can track the time the device has been on. In dzvents I tried but can't get it to work.
felix63 wrote: Friday 30 April 2021 16:38 I have a similar use case. When a device is switched off I want to update a virtual device - (timer) counter so I can track the time the device has been on. In dzvents I tried but can't get it to work.
Could look like below
return
    on =
        devices =
            1324, -- device for which you want to record the On time.
    data =
        lastOn = { initial = 0 },
    logging = {
        level = domoticz.LOG_DEBUG,
        marker = 'timeKeeper',
    execute = function(dz, item)
        local secondsActive = 0
        local iCounter = dz.devices('timeKeeper') -- define as virtual incremental counter
        if item.active then
            if dz.data.lastOn == 0 then dz.data.lastOn = os.time() end
            return
                secondsActive = os.time() - item.lastUpdate.dDate
                secondsActive = os.time() - dz.data.lastOn
                 dz.data.lastOn = 0
            iCounter.updateCounter(secondsActive)
Edit your incremental counter to look like.
edit device.png (51.72 KiB) Viewed 7401 times
felix63
Post by felix63 »
Works, thanks. But I am still completely baffled by (incremental) counters.
felix63 wrote:Works, thanks. But I am still completely baffled by (incremental) counters.
Do you have specific questions on how they work?
felix63
Post by felix63 »
I am trying to find some info on:
- difference between counter, managed counter and incremental counter
- what is the function of counter type 'Time', and how to use it from a script. The following command for instance doesn't do anything on a counter of type time.
 /json.htm?type=command&param=udevice&idx=IDX&nvalue=0&svalue=1
felix63 wrote: Saturday 01 May 2021 10:57 I am trying to find some info on:
counter: When you send something to the counter the existing value is replaced.
incremental counter: When you send something to this one the value is added to the existing value.
managed counter: counter without automatic history. You have to take care of the history yourself using API 's
I asked the core developers months ago how to update this from the API and no one could give me an answer. So either the developer that introduced this (maybe for future use) is no longer developing here or it is a left over from the past.
No one stepped forward until now on how to use this. (if at all possible)
Lostnode
Post by Lostnode »
Hi waaren,
I tried your code and it works for logging on-time for each event.
But what if you'd like a counter that records total time a device has been turned on over a longer period (accumulated time)?
Do you have an example of that as well?
Lostnode wrote: Tuesday 18 May 2021 18:54 I tried your code and it works for logging on-time for each event.
Maybe I do not completely understand what you mean but if you used incremental counter as device type when creating the counter it should already do just that. If not please elaborate on your question.
Lostnode
Re: Time how much a device is ON  [Solved]
Post by Lostnode »
waaren wrote: Tuesday 18 May 2021 22:36
Hi, and thanks for replying. Sorry for not answering sooner.
Well, I learned something new today. Created a new counter but incremental instead. works fine!
Tarzan737
Post by Tarzan737 »
Is it possible to get this in Minutes or Hours?
Zenek1961
Post by Zenek1961 »
Treve
Domoticz version: v4.11474
Post by Treve »
FYI: Waaren will never answer again, he passed away.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
Zenek1961
Post by Zenek1961 »
maybe anybody other knows?
Domoticz version: 2026.3
Yes but you will have to modify the script to have it give minutes or hours to the counter instead of seconds (value SecondsActive).
Be aware you have to make it an integer so be careful with rounding. See https://domoticz.com/forum/viewtopic.php?t=26512
Edit: Also a Counter divider value of 60 (for minutes) or 3600 (for hours) should work..... :oops:
