I'm new to zigbee2mqtt and got myself a CC2531 USB stick with some aquara stuff.
I used the
https://www.domoticz.com/wiki/Zigbee2MQTT manual to install this on my pi
Everything went fine and a paired one device which now shows up in the zigbee2mqtt.service logging
I installed the zigbee2mqtt domoticz plugin, as stated as last step in the manual.
After installing the plugin i added zifbee2mqtt as a hardware device in domoticz, My domoticz started not responding anymore.
I could not access domoticz through the webinterface, although the status stated it was running. Webinterface did hardly load and if it said it was offline.
After manually removing the plugin, i could access domoticz again and remove the hardware also.
Tried this several times, because i was not sure i made the correct settings in the hardware (should i used the ip from the pi, or is localhost/127.0.0.1 also valid?), but i left al default so it should be ok. Still every time domoticz hung.
What could be the reason? Is there a minimal python version necessarry, currently running Python Version: 3.4.2
