Hi, i'm using Domoticz on Win 10. Trying to get a CC2531 to work. Flashed the stick but cannot find the next step? Already spent alot of time searching what i'm missing..
Seems to be to simple by just add the hardware with the phyton pluging.. Doesn't seem to work..
Second question, does someone know if the Orvibo Door/Window sensors will work?
Third question, how do you pair a Zigbee device? Just by holding a button on the stick or more?
Zigbee2MQTT on Windows 10
Bigted
- Domoticz version: 2020.1
Re: Zigbee2MQTT on Windows 10
Have you installed mqtt and the zigbee2mqtt nodejs package and have that running (http://www.zigbee2mqtt.io)
to pair you enable pairing in the configuration.yaml by setting permit_join to true and then putting the device in pairing mode, once paired enable new hardware in Domoticz to add the device
xploid
I have installed MQTT for SONOFF. The nodejs package no.. because of the manual is written for Linux i don't know where to go on Windows..
xploid
Nobody
Plantje
I am sorry, I am not able to help you. I am just looking for the same thing: ZigBee on Domoticz on Windows 10.
I want to expand my Domoticz setup with ZigBee. Currently I have Z-Wave (Aeotec Z-Wave USB stick) and 433Mhz (RFXCom), which works fine, but ZigBee seems to be the sweet spot when it comes to functionality and costs.
What first steps did you use? Where can I find general steps? If I get any further than you, I will obviously let you know!
xploid
Hi, I made the stick with the right firmware. Maybe we can help each other? I got the tools to make another stick so you don't need to buy those.
After the flash I'm stuck. Also tried on Ubuntu but I'm not used to work with Linux..
Plantje
I think I will go with Deconz to prevent these issues from occurring.
