GoodWe Solar: get data from the new semsportal (lua script)
CrazyFrog
Post by CrazyFrog »
I have written a lua script to extract the data from the new "Goodwe semsportal" and pass it on to Domoticz.
I hope this helps you.
Questions or tips to improve the script, I'd love to hear them
--- Created by Raymond Wiertz
--- DateTime: 2019-04-21
-- Note: The GoodWe data is refreshed every 60 seconds.
-- Note: Enter your own data at [LOGINNAME] and [PASSWORD]
-- Tracking your token
-- To find out your token, you must execute the CURL command below from the command line.
--- curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login;
-- Place here your token
token = "[YOUR TOKEN]"
-- The curl command below retrieves the get session ID named "ASP.NET_SessionId", the session ID is used to request the final data
command = "curl --silent --output /dev/null --cookie-jar - -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login"
i=1
function UpdateDevice(device, data)
    idx = otherdevices_idx[device]
    if (idx == nil) then
        print('** Unknown device'..device)
        commandArray[i] = {['UpdateDevice'] = idx..'|0|'..data}
        i = i+1
function stripchars(str, chrs)
    local s = str:gsub("["..chrs:gsub("%W","%%%1").."]", '')
    return s
function split(s, delimiter)
    result = {};
    for match in (s..delimiter):gmatch("(.-)"..delimiter) do
        table.insert(result, match);
    return result;
function getValue(s)
    firstPos, lastPos = string.find(s, ":")
    value = string.sub(s, lastPos+1, string.len(s))
    return  value
function timedifference(s)
    year    = string.sub(s, 1, 4)
    month   = string.sub(s, 6, 7)
    day     = string.sub(s, 9, 10)
    hour    = string.sub(s, 12, 13)
    t1 = os.time()
    t2 = os.time{year=year, month=month, day=day, hour=hour, min=minutes,sec=seconds}
    difference = os.difftime (t1, t2)
    return difference
-- Sensor declaration
sensorSolarPanels = "solar panels"
difference = timedifference(otherdevices_lastupdate[sensorSolarPanels])
if (difference > 60) then
    local f = assert(io.popen(command, 'r'))
    s = assert(f:read('*a'))
    f:close()
    -- extract the ASP.NET_SessionId from the curl response
    sessionId = string.sub(s, -26)
    sessionId = string.gsub(sessionId,"[\r\n]", "" )
    sessionId = string.gsub(sessionId, "%s+", "")
    -- update curl command with the session id.
    getData = string.format("%s%s%s%s" , "curl -v --cookie 'ASP.NET_SessionId=", sessionId, "' https://www.semsportal.com/PowerStation/PowerStatusSnMin/",token )
    local f = assert(io.popen(getData, 'r'))
    f:close()
    -- extract the JSON-data from the response
    dummy, startPos = string.find(s, "var pw_info = ")
    dummy, endPos = string.find(s, "}};")
    s = string.sub(s, startPos, endPos-1)
    -- remove excess brackets
    valueString = stripchars(s, "[]{}\"")
    -- and split the records
    splitString = split(valueString, ",")
    -- for debugging only
    -- shows all values and the corresponding record id
    --- for key, value in pairs(splitString) do
    ---   print(key..'='..value)
    --- end
    output_power      = getValue(splitString[182])
    last_refresh_time = getValue(splitString[188])
    eDay              = getValue(splitString[199])
    -- daily_generation  = getValue(splitString[357])
    -- work_mode         = getValue(splitString[189])
    -- warning           = getValue(splitString[194])
    print("last_refresh_time :" .. last_refresh_time)
    print("output_power :" .. output_power)
    print("eDay :" .. eDay)
    --- print("daily_generation :" .. daily_generation )
    --- print("work_mode :" .. work_mode)
    --- print("warning :" .. warning)
    current = tonumber(stripchars(output_power, "kwhKWH"))
    dayTotal = tonumber(eDay)*1000
    UpdateDevice(sensorSolarPanels, current..";"..dayTotal)
Have fun.
biggav
Re: GoodWe Solar: get data from the new semsportal (lua script)
Post by biggav »
Hi CrazyFrog, whats the format of the token?
I have put in everything that was returned see below and get an error in the log further below
token = "{ "code" : 0, "msg" : "","data":{"redirect":"/PowerStation/PowerStatusSnMin/21ddbd72-acf0-42ba-8451-9c960d5c5b8d"} }"
2019-04-22 14:20:18.157 Error: EventSystem: in Goodwe: [string "print('Solar Luna Fired');
..."]:15: unexpected symbol near '/'
I have also tried
token = "21ddbd72-acf0-42ba-8451-9c960d5c5b8d'
then I get the following error
2019-04-22 14:23:00.125 Error: EventSystem: in Goodwe: [string "print('Solar Luna Fired');
..."]:53: bad argument #1 to 'sub' (string expected, got nil)
Was there any other setup required? I have never had the inverter running on my system as it is only a few weeks old.
CrazyFrog
Post by CrazyFrog »
Your token is:21ddbd72-acf0-42ba-8451-9c960d5c5b8d
I have this script running on my Rasberry Pi.
on what for device are you running this scrip.
Tiger362
Post by Tiger362 »
Hi CrazyFrog,
I'm new at this and would like to know how to implement this script on my RPi...
Thanks in advance!
sincze
Domoticz version: 2024.4
Post by sincze »
CrazyFrog wrote: Sunday 21 April 2019 13:46 I have written a lua script to extract the data from the new "Goodwe semsportal" and pass it on to Domoticz.
Have fun.
Tnx for extending my LUA knowledge. :) Great help.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
biggav
Post by biggav »
CrazyFrog wrote: Monday 22 April 2019 10:31 Your token is:21ddbd72-acf0-42ba-8451-9c960d5c5b8d
I'm on a Pi as well, i have tried running the script under events and also by adding it in the luna folder with the same out come.
does this script create the devices and hardware? or is there something i need to do there?
CrazyFrog
Post by CrazyFrog »
you have create your own sensor.
for hardware you have to create a virtual sensor from the type "Dummy (Does nothing, use for virtual switches only)".
then click on "Create Virtual Sensors", name the sensor "solar panels" and choose "sensor type" - "Electric (instant + counter)"
CrazyFrog
Post by CrazyFrog »
Tiger362 wrote: Monday 22 April 2019 10:49 Hi CrazyFrog,
Thanks in advance!
Hello Biggav,
At first you have to create a dummy sensor, you can do this in the hardware section
Create a sensor from the type "Dummy (Does nothing, use for virtual switches only)".
then click on "Create Virtual Sensors", give it the name "solar panels" and choose "sensor type" - "Electric (instant + counter)"
The next step is place the lua script in the correct folder.
go to the folder domoticz/scripts/lua and copy the script here,
gives the script the name "script_device_solar.lua"
Note that the script must always start with "script_device_" and ends with ".lua"
Tiger362
Post by Tiger362 »
Hi CrazyFrog,
Thnx for the info! :)
Do I have to reboot the system now or will it start automatically?
Grtz
Tiger362
Post by Tiger362 »
Hi CrazyFrog,
I know now that the script will run automatically ;)
But I got an error:
Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_solar.lua: /home/pi/domoticz/scripts/lua/script_device_solar.lua:89: attempt to perform arithmetic on global 'endPos' (a nil value)
Can you tell me what to do?
dospider
Post by dospider »
Hello Crazy Frog,
First of all thanks for diving in the problem and a script. I also have a problem with the script.
The logmessage is:
2019-04-24 16:45:52.603 Error: EventSystem: in Goodwe portal: [string "--- Created by Raymond Wiertz
..."]:51: bad argument #1 to 'sub' (string expected, got nil)
Question about token. Does has to be within ' ....'
The username and password not between '...' and the username is it the plantname or emailadres.
It doesn't what i do. Always the same error..
Hope you can find it.
ricvee
Domoticz version: Stable
Post by ricvee »
Hi CrazyFrog,
Works like a charm!
Thanks a lot! :D
ricvee
Post by ricvee »
You only have to set the time-difference to a higher number than 60 seconds!
After a couple of hours I got locked out of the semsportal.
So I set the timedifference now to 300 seconds...
sandeman684
Post by sandeman684 »
Thanks for this script. It needed some modifications for me to work though. Apparently I got back a very different list of values:
2019-04-26 14:03:38.806 Status: LUA: 458=display:Temperature(℃)
2019-04-26 14:03:38.806 Status: LUA: 459=unit:℃
2019-04-26 14:03:38.806 Status: LUA: 460=target_key:Tempperature
2019-04-26 14:03:38.806 Status: LUA: 461=text_cn:温度
2019-04-26 14:03:38.806 Status: LUA: 462=target_sn_six:null
2019-04-26 14:03:38.806 Status: LUA: 463=target_sn_seven:null
2019-04-26 14:03:38.806 Status: LUA: 464=target_type:null
2019-04-26 14:03:38.806 Status: LUA: 465=storage_name:null
2019-04-26 14:03:38.806 Status: LUA: 466=target_index:21
2019-04-26 14:03:38.807 Status: LUA: 467=target_name:Daily Generation
2019-04-26 14:03:38.807 Status: LUA: 468=display:Daily Generation(kWh)
2019-04-26 14:03:38.807 Status: LUA: 469=unit:kWh
2019-04-26 14:03:38.807 Status: LUA: 470=target_key:EDay
2019-04-26 14:03:38.807 Status: LUA: 471=text_cn:日发电量
2019-04-26 14:03:38.807 Status: LUA: 472=target_sn_six:null
2019-04-26 14:03:38.807 Status: LUA: 473=target_sn_seven:null
2019-04-26 14:03:38.807 Status: LUA: 474=target_type:null
2019-04-26 14:03:38.807 Status: LUA: 475=storage_name:null
2019-04-26 14:03:38.807 Status: LUA: 476=target_index:22
2019-04-26 14:03:38.807 Status: LUA: 477=target_name:Total Generation
2019-04-26 14:03:38.807 Status: LUA: 478=display:Total Generation(kWh)
2019-04-26 14:03:38.807 Status: LUA: 479=unit:kWh
2019-04-26 14:03:38.807 Status: LUA: 480=target_key:ETotal
2019-04-26 14:03:38.807 Status: LUA: 481=text_cn:总发电量
2019-04-26 14:03:38.807 Status: LUA: 482=target_sn_six:null
2019-04-26 14:03:38.807 Status: LUA: 483=target_sn_seven:null
2019-04-26 14:03:38.807 Status: LUA: 484=target_type:null
2019-04-26 14:03:38.807 Status: LUA: 485=storage_name:null
2019-04-26 14:03:38.807 Status: LUA: 486=target_index:23
2019-04-26 14:03:38.808 Status: LUA: 487=target_name:HTotal
2019-04-26 14:03:38.808 Status: LUA: 488=display:HTotal(Hrs)
2019-04-26 14:03:38.808 Status: LUA: 489=unit:Hrs
2019-04-26 14:03:38.808 Status: LUA: 490=target_key:HTotal
2019-04-26 14:03:38.808 Status: LUA: 491=text_cn:工作时长
2019-04-26 14:03:38.808 Status: LUA: 492=target_sn_six:null
2019-04-26 14:03:38.808 Status: LUA: 493=target_sn_seven:null
2019-04-26 14:03:38.808 Status: LUA: 494=target_type:null
2019-04-26 14:03:38.808 Status: LUA: 495=storage_name:null
2019-04-26 14:03:38.808 Status: LUA: 496=target_index:36
2019-04-26 14:03:38.808 Status: LUA: 497=target_name:RSSI
2019-04-26 14:03:38.808 Status: LUA: 498=display:RSSI(%)
2019-04-26 14:03:38.808 Status: LUA: 499=unit:%
2019-04-26 14:03:38.808 Status: LUA: 500=target_key:Reserved5
2019-04-26 14:03:38.808 Status: LUA: 501=text_cn:GPRS信号强度
2019-04-26 14:03:38.808 Status: LUA: 502=target_sn_six:null
2019-04-26 14:03:38.808 Status: LUA: 503=target_sn_seven:null
2019-04-26 14:03:38.808 Status: LUA: 504=target_type:null
2019-04-26 14:03:38.809 Status: LUA: 505=storage_name:null
2019-04-26 14:03:38.809 Status: LUA: 506=backup_pload_s:null
2019-04-26 14:03:38.809 Status: LUA: 507=backup_vload_s:0.0
2019-04-26 14:03:38.809 Status: LUA: 508=backup_iload_s:null
2019-04-26 14:03:38.809 Status: LUA: 509=backup_pload_t:null
2019-04-26 14:03:38.809 Status: LUA: 510=backup_vload_t:null
2019-04-26 14:03:38.809 Status: LUA: 511=backup_iload_t:null
2019-04-26 14:03:38.809 Status: LUA: 512=etotal_buy:null
2019-04-26 14:03:38.809 Status: LUA: 513=eday_buy:null
2019-04-26 14:03:38.809 Status: LUA: 514=ebattery_charge:null
2019-04-26 14:03:38.809 Status: LUA: 515=echarge_day:null
2019-04-26 14:03:38.809 Status: LUA: 516=ebattery_discharge:null
2019-04-26 14:03:38.809 Status: LUA: 517=edischarge_day:null
2019-04-26 14:03:38.809 Status: LUA: 518=batt_strings:null
2019-04-26 14:03:38.809 Status: LUA: 519=meter_connect_status:null
2019-04-26 14:03:38.809 Status: LUA: 520=mtactivepower_r:null
2019-04-26 14:03:38.809 Status: LUA: 521=mtactivepower_s:null
2019-04-26 14:03:38.809 Status: LUA: 522=mtactivepower_t:null
2019-04-26 14:03:38.809 Status: LUA: 523=has_tigo:false
2019-04-26 14:03:38.810 Status: LUA: 524=hjgx:co2:8.3190677000000015
2019-04-26 14:03:38.810 Status: LUA: 525=tree:455.921624
2019-04-26 14:03:38.810 Status: LUA: 526=coal:3.3710164000000002
2019-04-26 14:03:38.810 Status: LUA: 527=pre_powerstation_id:null
2019-04-26 14:03:38.810 Status: LUA: 528=nex_powerstation_id:null
2019-04-26 14:03:38.810 Status: LUA: 529=powerflow:pv:1036(W)
2019-04-26 14:03:38.810 Status: LUA: 530=pvStatus:-1
2019-04-26 14:03:38.810 Status: LUA: 531=bettery:0(W)
2019-04-26 14:03:38.810 Status: LUA: 532=betteryStatus:0
2019-04-26 14:03:38.810 Status: LUA: 533=load:1036(W)
2019-04-26 14:03:38.810 Status: LUA: 534=loadStatus:-1
2019-04-26 14:03:38.810 Status: LUA: 535=grid:0(W)
2019-04-26 14:03:38.810 Status: LUA: 536=soc:0
2019-04-26 14:03:38.810 Status: LUA: 537=socText:No battery
2019-04-26 14:03:38.810 Status: LUA: 538=hasEquipment:true
2019-04-26 14:03:38.810 Status: LUA: 539=gridStatus:1
2019-04-26 14:03:38.810 Status: LUA: 540=energeStatisticsCharts:sum:6.5
2019-04-26 14:03:38.810 Status: LUA: 541=buy:0.0
2019-04-26 14:03:38.811 Status: LUA: 542=buyPercent:0.0
2019-04-26 14:03:38.811 Status: LUA: 543=sell:0.0
2019-04-26 14:03:38.811 Status: LUA: 544=sellPercent:0.0
2019-04-26 14:03:38.811 Status: LUA: 545=selfUseOfPv:6.5
2019-04-26 14:03:38.811 Status: LUA: 546=consumptionOfLoad:6.5
2019-04-26 14:03:38.811 Status: LUA: 547=chartsType:4
2019-04-26 14:03:38.811 Status: LUA: 548=hasPv:true
2019-04-26 14:03:38.811 Status: LUA: 549=hasCharge:false
2019-04-26 14:03:38.811 Status: LUA: 550=charge:0.0
2019-04-26 14:03:38.811 Status: LUA: 551=disCharge:0.0
2019-04-26 14:03:38.811 Status: LUA: 552=soc:power:0
2019-04-26 14:03:38.811 Status: LUA: 553=status:0
2019-04-26 14:03:38.811 Status: LUA: last_refresh_time :--%
2019-04-26 14:03:38.811 Status: LUA: output_power :1036(W)
2019-04-26 14:03:38.811 Status: LUA: eDay :6.5
2019-04-26 14:03:38.816 Status: EventSystem: Script event triggered: Solar panels
2019-04-26 14:03:40.984 (RFXCOM) Temp + Humidity (Buiten Kas Daniu 3)
2019-04-26 14:03:49.892 (Thermosmart) Thermostat (Woonkamer Target T)
Therefore I had to change these lines:
output_power = getValue(splitString[533])
eDay = getValue(splitString[545])
And add brackets to:
current = tonumber(stripchars(output_power, "kwhKWH()"))
I cannot find the last refresh time in my list of values.
mennohaeck
Post by mennohaeck »
No matter what I do or how I name the script, there is no output. I checked all the rights and syntax. Funny thing is: no errors as wel. Is there anyone with a bright idea? :?
Hielkep
Post by Hielkep »
nice work!
i did it a bit different then to copy script file to disk.
In Domoticz website, i opened Setup - More options - Events
added new script with + on top of screen,
selected lua > time.
and pasted script into there.
replaced [LOGINNAME] and [PASSWORD] with relevant data
and replaced [YOUR TOKEN] with my token (i left the quotes in place).
made a dummy switch with a different name, replaced in script on line 65 the dummy switch name.
saved it all, activated the script, and it ran! :D
Hielkep
Post by Hielkep »
mennohaeck wrote: Friday 26 April 2019 14:36 No matter what I do or how I name the script, there is no output. I checked all the rights and syntax. Funny thing is: no errors as wel. Is there anyone with a bright idea? :?
is the name of dummy switch and the declaration in line 65 of the name of the switch completely the same?
CrazyFrog
Post by CrazyFrog »
Hielkep wrote: Friday 26 April 2019 16:05 nice work!
Nice, i didn't know this possibility.
Thank you
CrazyFrog
Post by CrazyFrog »
Do you get data?
can you save the code below to your Raspberry Pi in a file testscript.lua
then execute this script with the command: lua testscript.lua
What do you see, do you get lot of data?
Before you execute this code, fill in your own Loginname, Password and Token
-- To get you token use the curl command below, replace [LOGINNAME] and [PASSWORD] for your own id's
-- "curl -d 'account=[LOGINNAME]&pwd=[PASSWORD]&code=' https://www.semsportal.com/Home/Login";
-- copy the token from the response of the curl request above and place it below
-- replace [LOGINNAME] and [PASSWORD] for your own id's
f:close()
f:close()
print(s)
sandeman684
In my last post I mentioned I needed other key numbers, but that was partially incorrect because the domoticz log only showed me the last roughly 100 keys. I had to output them to a file to see them all.
In this way I found that for my case, each of the keys is one higher than in CrazyFrogs script. So now I have:
    output_power      = getValue(splitString[183])
    last_refresh_time = getValue(splitString[189])
    eDay              = getValue(splitString[200])
This works well but indicates that the keys are not fully fixed.
Maybe we should not look for key number but for key value?
