Button Switches doesn't react in dashticz_v2
Doorus
Post by Doorus »
To let my buttons react, first i must clear my cache in the browser. I use chrome as default browser. I tryed different browsers, all the same.
Does someone recognize this problem? And what can be the solution ?
I use latest beta version Dashticz_v2
Lokonli
Re: Button Switches doesn't react in dashticz_v2
Post by Lokonli »
No, I don't recognise the problem. Can you post your CONFIG.js?
Verstuurd vanaf mijn SM-A320FL met Tapatalk
Doorus
Post by Doorus »
Thanx for your reply,
Here is my config file.
CONFIG.js
(4.05 KiB) Downloaded 59 times
Lokonli
Post by Lokonli »
You mean the three buttons you have defined:
buttons.nunl
buttons.nos
buttons.watts
What behavior do you see?
On my system they behave as they should:
nunl opens in a new browser window
nos and watts open in a popup window.
Doorus
Post by Doorus »
No, it comes to the light switches.
The behavior is, when i touch the button he is 5 seconds on or off and then he´s going automatic to his old status, without turning on-off the lights.
After i have cleaned the cash in chrome the switches are working. When i close dashticz_v2 and reopen dashticz_v2 it does the same again.
The switches are in the red square (see attachement)
Lokonli
Post by Lokonli »
Doorus wrote: Friday 19 April 2019 16:04 No, it comes to the light switches.
Please check your PM.
Lokonli
Post by Lokonli »
Can you try the following: In Domoticz -> Settings -> System set 'Website beveiliging' to Basic-Auth instead of 'login pagina'
Doorus
Post by Doorus »
Thanx a lot.
The setting is working for me :-)
Can you tell me the difference between them ?
