Plugin Xiaomi PowerStrip, ChuangmiPlug
lhitvietnam
Post by lhitvietnam »
Hi, I found the Power strip connection plugins with Domoticz easily here https://github.com/xiaoyao9184/DomoticzXiaomiPlugins
install plugin
 "curl -L https://github.com/xiaoyao9184/DomoticzXiaomiPlugins/raw/master/install.sh | bash"
Screenshot (4).png (18.78 KiB) Viewed 998 times
Screenshot (3).png (31.03 KiB) Viewed 1003 times
Screenshot (2).png (65.27 KiB) Viewed 1003 times
Martins80
Re: Plugin Xiaomi PowerStrip, ChuangmiPlug
Post by Martins80 »
I have installed the plugin and everything works, i can turn on or off the power strips, but i have some errors and the other sensor devices such as temperature, power and current do not update. I have two zimi.powerstrip.v2. Some help?
2020-08-27 12:21:31.454 Error: (CDevice_update) RegletaPC - Temperature: Failed to parse parameters: 'nValue', 'sValue', 'Image', 'SignalLevel', 'BatteryLevel', 'Options', 'TimedOut', 'Name', 'TypeName', 'Type', 'Subtype', 'Switchtype', 'Used', 'Description', 'Color' or 'SuppressTriggers' expected.
2020-08-27 12:21:31.454 Error: (RegletaPC) 'CDevice_update' failed 'TypeError':'integer argument expected, got float'.
2020-08-27 12:21:31.456 Error: (CDevice_update) RegletaPC - PowerStrip_Current: Failed to parse parameters: 'nValue', 'sValue', 'Image', 'SignalLevel', 'BatteryLevel', 'Options', 'TimedOut', 'Name', 'TypeName', 'Type', 'Subtype', 'Switchtype', 'Used', 'Description', 'Color' or 'SuppressTriggers' expected.
2020-08-27 12:21:31.456 Error: (RegletaPC) 'CDevice_update' failed 'TypeError':'integer argument expected, got float'.
