I have a FIBARO System FGS221 Double Relay Switch 2x1.5kW included and working but I see only one switch.
It's strange and I don't find any parameter and I know it's work because with my old install domoticz with same firmware but another rpi it's ok.
Helllp
Dual Switch not working
jake
Re: Dual Switch not working
please restart Domoticz. Sometimes this kicks Zwave features alive. Make sure you have the option enabled to allow new hardware when you do this restart.Ascari wrote:Hello,
Helllp
- Ascari
- Domoticz version: 4.9
Already done and the same issue.
I will try to deincluse and incluse
Eibersite
And, did you find a solution?
pvm
- Domoticz version: 4.10538
I experience similar issue, both switches are showing in Domoticz but only one (the second one) is working from domoticz. I did upgrade the firmware 2 weeks ago to the latest version. I did not see improvements.
