I know there is a handshake for z-wave protocol and I'm wondering if Domoticz uses it.
I do have several Popp radiator control valves and I mentioned that those that are connected through a repeater / extender are less reliable than those that are directly connected to the controller.
Is there a way checking the setpoint has really been applied to the device and if not resend the sertpoint?
Thx!
Z-Wave, Handshake and reliability
Re: Z-Wave, Handshake and reliability
Retry should be done automatically if the acknowledge is not received. Take care default retry time is several ten's of seconds (to avoid re-sending data on slow devices/z-wave networks).
See retry timeout there:
https://github.com/OpenZWave/open-zwave ... ig-Options
So, when you experience timeouts in log for the device as well as unchanged setpoint, a retry have already been done and was not effective...
If you have lots of scheduled items at the same time, you may also distribute schedules over a few minutes. This may avoid some low-z-wave bandwith saturation problems.
- Domoticz version: Beta rel
Thanks for this valuable input!
If I do understand well, there is only one retry that is performed if handshake is not received.
I'm going to try changing timeout.
I do have only one setpoint that fails updating regularly, it might be the setpoint device that is defective (popp trv).
This looks promissing, the "RetryTimeout" parameter was set as a comment by default in the Domoticz config file.
I removed the comment code and set the parameter to 40000 milliseconds
Up to now I programmed setpoint changes every 5 minutes (10 changes in total) without any failure.
Thanks!!
Thanks!!
40000 is the default already, so, when not putting in this parameter, 40 seconds should already be in place. (see: https://github.com/OpenZWave/open-zwave ... ig-Options)
Do you think different about that ?
Patricen wrote: ↑Wednesday 10 April 2019 20:10 This looks promissing, the "RetryTimeout" parameter was set as a comment by default in the Domoticz config file.
Thanks!!
It looked to me that the default value is 40secs provided the option is not set as a comment, but as you said it might be different.
I felt that removing the comment sign improved the situation but it can be a bad feeling...
Well, I would say a "default" means that that values applies if nothing else is set, but hey, I'm not 100% sure either....
I'll try to test with it as well, see what comes out...
