I just installed a new Fibaro Double Switch 2 (FGS-223).
Everything seems to work fine, however switching the left switch doesn't work in Domoticz. The right switch does work. Manually switching does work for both switches and the power usage is shown correct as well in Domoticz.
However, when I go to the OpenZWave Control Panel via the Hardware page and I click on the switch and subsequently I click on ON or OFF behind the switch that isn't working through Domoticz, and that is actually working.
Is this a bug? And can I fix it myself?
Thanks in advance!
Fibaro Double Switch 2 (FGS-223) only 1 switch works
- madpatrick
- Domoticz version: 2025.2
Re: Fibaro Double Switch 2 (FGS-223) only 1 switch works
Eibersite
Link is not working??
stephanvdplas
- Domoticz version: 2023.1
I have the same issue after adding an extra node to the zwave network. 2 devices (1x fibaro dimmer 2 and 1x Remotec ZRC-90) have ID 0x0000 and type 0x0000. Rebooting doesn't help in my case.
In the OZWCP the dimmer is show as ready and the ZRC-90 as sleeping.
The zwave config xml shows the nodes, but with no device info. I have copied the correct node info from a backup of the xml into the live xml, rebooted the domoticz server. So this is a hint for all: backup your domoticz config frequently and use it to get correct settings back.
- Running LMS, Domoticz and Dashticz on a windows 11 laptop.
- LMS (11 players) / Hue (26 lights, 2 switches) / Z-wave (14 devices) / Toon (unrooted) / Chromecast
- emme
- Domoticz version: latest
ID 0x0000 means the controller was unable to contact the device.
this happened often with batterypowered devices
you should just wakeup the device to have the controller recognize it
For fibaro 222 and 223 a reboot (not a service restart!) will help to view the second switch (remember to enable new device inclusion!)
"We always done this way"
