[315Mhz] Doorbell - How to?
BarryT
Domoticz version: 2024.3
Post by BarryT »
i have seen a doorbell wich i want to use.
It is this doorbell:
https://www.bol.com/nl/p/cacazi-deurbel ... 093678808/
In the documentation says its working on the 315mhz freq, so my question is, can i use this one, and if yes, wich reciever do i need?
I have already a rfxcom 433 and rflink with 433 module, a zigbee and a Milight module..
Thanks,
Barry
b_weijenberg
Re: [315Mhz] Doorbell - How to?
Post by b_weijenberg »
I suppose it operates at 433MHz because 315MHz is not allowed in NL.
Check with the latest Pro firmware in the RFXtrx433E or RFXtrx433XL if the button is received in RFXmngr with Lighting4 or only undec on.
RFX-433, RFX-433EMC, RFX-868
BarryT
Post by BarryT »
No, its 315 for sure. 100%
As well my my rflink and my rfxcom doesnt see the sender.
SweetPants
Post by SweetPants »
BarryT wrote: Tuesday 09 April 2019 18:58 No, its 315 for sure. 100%
315 Mhz is not allowed as b_weijenberg said, probably it's a US version/type?. Anyway, you can't use it in Europe assuming you live in Europe. If you bought it at bol.com and it is 315 Mhz, i would return it
BarryT
Post by BarryT »
SweetPants wrote: Tuesday 09 April 2019 19:01
Well, okay but why my rflink and my rfxcom doesnt see this doorbell?
I can check with a spectrum analyzer to see on wich freq it does its job?
Will let you know then later this week.
SweetPants
BarryT wrote: Tuesday 09 April 2019 20:57
Because 433Mhz is not the same as 315Mhz, this will never work
BarryT
Post by BarryT »
I checked with a spectrum analyzer, will show you the results:
indeed, 433..
but, its weird that the rfxcom as well the rflink didnt see this doorbell?
why is that?
doorbell pressed:
normal:
SweetPants
BarryT wrote: Wednesday 17 April 2019 19:47 but, its weird that the rfxcom as well the rflink didnt see this doorbell?
why is that?
doorbell pressed:
Then it probably is not supported, did you check the supported device list of both transceivers?
BarryT
Post by BarryT »
SweetPants wrote: Thursday 18 April 2019 8:30
why is that?
doorbell pressed:
It seems that it is fsk modulation, a protocol wich is not supported by rfx or rflink..
Need to have an arduino with rfm69 chip.
