I've one question i have multiple RPI's with domoticz which all use the same scripts but in Bash I know how to select on which host the scripts runs and than executes the script on the other hosts the script won't be executed.
HOST=$(hostname)
if [ "$HOST" = "domoticz" ];
then
<EXECUTE>
exit
fi
Is the above also possible with LUA? And how could this be configured?
How to check on which device lua scripts runs
- waaren
Re: How to check on which device lua scripts runs
with dzVents (= Lua) and if you use a recent beta, you can identify the name of your system by the atrribute domoticz.settings.location.name which shows the Name you set in LocationRohald wrote: Sunday 07 April 2019 7:27 I have multiple RPI's with domoticz which all use the same scripts. In Bash I know how to select on which host the scripts runs.
Is that also possible with LUA? And how could this be configured?
- jvdz
- Domoticz version: 4.107
... or simply create a similar uservariable on each system and set that to the systemname. Then you can test the content of that user variable in the script.
Jos
Jos
Rohald
Thx works great!!!!waaren wrote: Sunday 07 April 2019 12:39with dzVents (= Lua) and if you use a recent beta, you can identify the name of your system by the atrribute domoticz.settings.location.name which shows the Name you set in LocationRohald wrote: Sunday 07 April 2019 7:27 I have multiple RPI's with domoticz which all use the same scripts. In Bash I know how to select on which host the scripts runs.
