Python Plugin: Python Plugin Manager
clubeddie
Re: Python Plugin: Python Plugin Manager
Post by clubeddie »
ycahome wrote: Friday 29 March 2019 14:27
clubeddie wrote: Thursday 28 March 2019 20:11
Anyone any idea?
python3-dev? is it installed?
Complete new raspberry, installed with Domoticz and installed Python
Version: 4.9700
Build Hash: a3a45906
Compile Date: 2018-06-23 16:24:51
dzVents Version: 2.4.6
Python Version: 3.5.3 (default, Sep 27 2018, 17:25:39) [GCC 6.3.0 20170516]
I can install PP Manager and see it after restart domoticz in the hardware tab. Installed 3 plugins to check if it works.
2019-04-03 18:21:45.407 (PPManager) Installation requested for Plugin:Meteo Alarm EU RSS Reader
2019-04-03 18:21:45.407 (PPManager) Plugin Display Name:Meteo Alarm EU RSS Reader
2019-04-03 18:21:45.407 (PPManager) Plugin Author:ycahome
2019-04-03 18:21:45.407 (PPManager) Plugin Repository:MeteoAlarmEU
2019-04-03 18:21:45.407 (PPManager) Plugin Key:MeteoAlarmEU
2019-04-03 18:21:45.407 (PPManager) Plugin Branch:master
2019-04-03 18:21:45.407 (PPManager) Installing Plugin:Meteo Alarm EU RSS Reader
2019-04-03 18:21:45.407 (PPManager) Calling:LANG=en_US /usr/bin/git clone -b master https://github.com/ycahome/MeteoAlarmEU.git MeteoAlarmEU
2019-04-03 18:21:45.343 Status: (PPManager) Entering work loop.
2019-04-03 18:21:45.344 Status: (PPManager) Initialized version 1.5.18, author 'ycahome'
2019-04-03 18:21:46.616 (PPManager) Plugin MeteoAlarmEU installed Succesfully
Also succesfull at the other two installations. But there is no additional devices, utility's or what so ever shown in Domoticz?
And is it possible that the list on
https://www.domoticz.com/wiki/Plugins
is not complete, for example, in the list
Google Home & Chromecast is shown, but in the PP Manager it is not available?
Dnpwwo
Post by Dnpwwo »
@clubeddie,
Not everything on the plugins page is available via the Plugin Manager. There is a column on the right showing those that are.
Other entries on the page link to github where they have installation instructions and more detail on functionality.
nono212
Domoticz version: 3.6179
Post by nono212 »
Hello
I am using PPM with Docker on Synology and I have this problem:
2019-05-19 00:24:40.388 Error: (PPM) Git ErrorNo:2
2019-05-19 00:24:40.388 Error: (PPM) Git StrError:No such file or directory: '/run/s6/services/domoticz/plugins'
Can you help please
ycahome
Domoticz version: lat Beta
Post by ycahome »
I don't currently have a sinology docker installation.
Can you tell me the full path of your "plugins" folder?
nono212
Post by nono212 »
Hello
Here is how I have created my container :
docker create --name=domoticz2 -e PUID=911 -e PGID=911 -e TZ=Europe/Brussels -p 8080:8080 -p 6144:6144 -p 1443:1443 -v /volume1/docker/Domoticz_linux/config:/config--device=/dev/ttyACM0 --device=/dev/ttyACM1 --restart unless-stopped linuxserver/domoticz
So the plugins folder is /volume1/docker/Domoticz_linux/config/plugins
but inside the container it is /container/plugins
ycahome
Post by ycahome »
PPM using the current working dir to identify the installation directory (getcwd)
Seems that this is not properly identified inside a container.
Geuvert
Domoticz version: 4.10717
Post by Geuvert »
Version: 4.10717 stable
Platform: Ubuntu server 18.04 LTS
Hi everybody,
Happy user of the plugin manager here.
Makes it much simpler to get started with plugins.
My error log shows some errors related to the plugin manager however.
2019-06-03 10:01:32.445 Error: Python Plugin Manager hardware (2) thread seems to have ended unexpectedly
2019-06-03 12:00:39.802 Error: (Python Plugin Manager) 'onHeartbeat' failed 'KeyError'.
2019-06-03 12:00:39.802 Error: (Python Plugin Manager) ----> Line 754 in '/home/geuvert/domoticz/plugins/PP-MANAGER/plugin.py', function onHeartbeat
2019-06-03 12:00:39.802 Error: (Python Plugin Manager) ----> Line 422 in '/home/geuvert/domoticz/plugins/PP-MANAGER/plugin.py', function onHeartbeat
2019-06-03 12:00:39.802 Error: (Python Plugin Manager) ----> Line 546 in '/home/geuvert/domoticz/plugins/PP-MANAGER/plugin.py', function CheckForUpdatePythonPlugin
Is this normal?
Geuvert
njvdijk
Post by njvdijk »
During installation of the plugin I got the following reply
pi@raspberrypi:~/domoticz/plugins/PP-MANAGER $ chmod +x plugin.py
chmod: veranderen van toegangsrechten van 'plugin.py': Bewerking niet toegestaan
HFman
Domoticz version: V4.1174
Post by HFman »
njvdijk wrote: Thursday 17 October 2019 15:50 During installation of the plugin I got the following reply
try :
cd /domoticz/plugins/PP-MANAGER
sudo chmod +x plugin.py
Raspberry PI 3 - Opentherm Gateway + ESP8826 - EvoHome - ESPEasy CO2 + Fancontrol - RF-Link - zigbee2mqqt -
spider2
Post by spider2 »
I have synology nas and the domoticz log show this:
2019-11-12 18:09:11.562 Error: (Python Plugin Manager) Git ErrorNo:2
2019-11-12 18:09:11.563 Error: (Python Plugin Manager) Git StrError:No such file or directory: '/root/plugins/PP-MANAGER'
2019-11-12 18:09:11.575 Error: (Python Plugin Manager) Git ErrorNo:2
2019-11-12 18:09:11.575 Error: (Python Plugin Manager) Git StrError:No such file or directory: '/root/plugins/PP-MANAGER'
My domoticz directory is this: "/volume1/@appstore/domoticz/var/plugins" and here install the PP-MANAGER
What is the problem?
BarryT
Domoticz version: 2024.3
Post by BarryT »
How can i remove an (installed) plugin?
It seems i have installed the EWPE SMART MQTT plugin for my 2 heatpumps, but 1) getting errors, 2) domoticz crashed directly, 3) after reboot the plugin is totally gone AND i cant install it anymore?
I removed the plugins directory, but that didnt help...
Last update, after reboot:
2020-01-13 20:48:10.885 Error: Plugin Manager hardware (53) thread seems to have ended unexpectedly
clubeddie
Post by clubeddie »
I am unable to install this plugin. Freshly installed Domoticz on a clean Raspberry with Raspbian Stretch.
Normal install through curl and update everything.
When i check about Domoticz i get:
Version: 4.10717
Build Hash: b38b49e5
Compile Date: 2019-05-09 13:04:08
dzVents Version: 2.4.19
Python Version: None
When i check Python version on Raspberry
pi@rPI-Domoticz:~ $ ls -la /usr/bin/python*
lrwxrwxrwx 1 root root       9 Jan 24  2017 /usr/bin/python -> python2.7
lrwxrwxrwx 1 root root       9 Jan 24  2017 /usr/bin/python2 -> python2.7
-rwxr-xr-x 1 root root 3166320 Sep 26  2018 /usr/bin/python2.7
lrwxrwxrwx 1 root root       9 Jan 20  2017 /usr/bin/python3 -> python3.5
-rwxr-xr-x 2 root root 3976256 Sep 27  2018 /usr/bin/python3.5
-rwxr-xr-x 2 root root 3976256 Sep 27  2018 /usr/bin/python3.5m
lrwxrwxrwx 1 root root      10 Jan 20  2017 /usr/bin/python3m -> python3.5m
pi@rPI-Domoticz:~ $ sudo apt install python3
Reading package lists... Done
Building dependency tree
Reading state information... Done
python3 is already the newest version (3.5.3-1).
python3 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
pi@rPI-Domoticz:~ $ python3 -V
Python 3.5.3
Edit:
Fixed first issue with
sudo apt-get install libpython3.4-dev
Now i get:
Python Version: 3.4.4 (default, Aug 20 2019, 08:42:52) [GCC 8.3.0]
Also updated to latest beta
PP-Manager is now installed and shown in hardware. Only when i install a plugin, for example WAN Ip Checker,
In the log i see
2020-01-14 19:49:42.950 (Python Plugin Manager) Installation requested for Plugin:Wan IP Checker
2020-01-14 19:49:42.950 (Python Plugin Manager) Plugin Display Name:Wan IP Checker
2020-01-14 19:49:42.950 (Python Plugin Manager) Plugin Author:ycahome
2020-01-14 19:49:42.950 (Python Plugin Manager) Plugin Repository:WAN-IP-CHECKER
2020-01-14 19:49:42.950 (Python Plugin Manager) Plugin Key:WAN-IP-CHECKER
2020-01-14 19:49:42.950 (Python Plugin Manager) Plugin Branch:master
2020-01-14 19:49:42.950 (Python Plugin Manager) Installing Plugin:Wan IP Checker
2020-01-14 19:49:42.950 (Python Plugin Manager) Calling:LANG=en_US /usr/bin/git clone -b master https://github.com/ycahome/WAN-IP-CHECKER.git WAN-IP-CHECKER
2020-01-14 19:49:42.527 Status: (Python Plugin Manager) Started.
2020-01-14 19:49:42.935 Status: (Python Plugin Manager) Entering work loop.
2020-01-14 19:49:42.936 Status: (Python Plugin Manager) Initialized version 1.5.21, author 'ycahome'
2020-01-14 19:49:44.139 (Python Plugin Manager) Plugin WAN-IP-CHECKER installed Succesfully
But no hardware or whatever is showed. Other plugins same issue?
Westcott
Post by Westcott »
Mine gives errors every day at 12:00 -
2020-01-28 12:00:02.131 Error: (PPmanager) 'onHeartbeat' failed 'KeyError'.
2020-01-28 12:00:02.131 Error: (PPmanager) ----> Line 756 in '/home/pi/domoticz/plugins/PP-MANAGER/plugin.py'
2020-01-28 12:00:02.131 Error: (PPmanager) ----> Line 424 in '/home/pi/domoticz/plugins/PP-MANAGER/plugin.py'
2020-01-28 12:00:02.131 Error: (PPmanager) ----> Line 548 in '/home/pi/domoticz/plugins/PP-MANAGER/plugin.py'
AntonACE
Post by AntonACE »
There is a bug in Wiki page, in the Install section. "PP-MANAGER" written in different cases. Can be a problem for linux beginners.
wube
Post by wube »
Hi Everyone,
Can anyone tell me if Python Plugin Manager can be installed on QNAP Domoticz 4.10717 ? I'm having some issues, I installed all pre requisites: python2.7, python3.8, pip3, python3-dev, via opkg (QNAP Entware). Domoticz doesn't say that PluginSystem has been started. Any advice? Thank you.
Dnpwwo
Post by Dnpwwo »
@wube,
A couple of things:
  • The Plugin System and the Python Plugin Manager are quite different things. The Plugin Manager its actually a plugin itself that can install other plugins on linux systems, it is completely optional.
  • Python 2.7 is not required (neither is pip3 technically)
  • Do you get any PluginSystem message at all? If not then maybe Domoticz for you platform was built without Python support. You may need to build your own and enable it
wube
Post by wube »
Hi @Dnpwwo,
Thanks for your reply. No i don't get any info in log about the PluginSystem at all. Should I contact whoever built it and released to QNAP? Additional info is that i also have python script which should turn on and of TP-Link smart socket HS100 and script works from command line but not when copied to scripts in domoticz and dummy switch populated with command that should start it. Is there any way to determine if this particular domoticz release was built with python support or not? Thanks again. Cheers!
Dnpwwo
Post by Dnpwwo »
@wube,
The Plugin System and Event System both use the same Python instance so it sounds like the problem problem. You can also check the Domoticz 'About' screen from the 'Setup' menu, that will say what Python version is being used.
If Domoticz tries to load Python but can't find it you will see a
PluginSystem: Failed dynamic library load
error in the log. Search the forum for more details on that.
I would contact the image builder to understand why Python was disabled, by default it is normally included.
wube
Post by wube »
@Dnpwwo,
you are absolutely right, i didn't know that. And of course QNAP version of Domoticz does not support python. Info under the button.
Version: 4.10717
Decyph
Domoticz version: 11838
Post by Decyph »
Hey there,
I also have a problem with PP-Manager de reference to the plugins folder is incorrect.
I keep getting the following error in the domoticz log:
2020-04-23 13:15:09.523 Error: (PP Manager) Git ErrorNo:2
2020-04-23 13:15:09.529 Error: (PP Manager) Git StrError:No such file or directory: '/home/domoticz/plugins'
The directory should be: /home/domoticz/domoticz/plugins
The user is domoticz and the installation folder of the application is domoticz as well.
System Info:
ersion: 2020.1 (build 11838)
Build Hash: 372611b76
Compile Date: 2020-03-26 15:21:15
dzVents Version: 3.0.1
Python Version: 3.7.5 (default, Nov 7 2019, 10:50:52) [GCC 8.3.0]
Can anyone let me know what i can do to change the plugins folder path.
I already tried adding /domoticz in front of /plugins in the py file.
