I would like to control my electric fireplace (with remote control on 433MHZ) from Domoticz.
The fireplace is from Ruby Fires type Varese.
When I use the learning mode and Domoticz shows me the message to use my remote, Domoticz is not able to recognize the transmission.
I use Domoticz on a Raspberry Pi with RFLink as the frontend.
I hope someone could help me with this issue
Regards,
Raymond
ruby fires varese
Re: ruby fires varese
Did you check if the device is supported? http://www.rflink.nl/blog2/devlist That it uses 433Mhz does not mean it is.rajsteverink wrote: ↑Monday 01 April 2019 17:36 Hello,
Regards,
Raymond
Thanks Sweetpants for your quick reply.
I have checked the list you mentioned but I can confirm its not on the list.
I was wondering what the procedure is to get it on the list.
Do you have info about that?
Raymond
Raymond
- Domoticz version: mixed
Send request to RFLink Stuntteam to include your device.
As input for their effort they probably will ask you for a logging.
